Old 01-23-2015, 04:50 PM   #1
revsx
revsx is an unknown quantity at this point
S14 Flashing Air Bag Light
Ok I know this is an issue obviously, but I just put in my new steering wheel and hub which required the removal of the clock spring. Now my airbag light is flashing which is rather annoying. Is it going to constantly flash or do I need to reset it so it just stays on constantly?
revsx is offline   Reply With Quote
Old 01-23-2015, 05:04 PM   #2
MidnightKouki
MidnightKouki is an unknown quantity at this point
I used to have this problem.
Now I don't.
Instagram: @Yokosukanights
MidnightKouki is offline   Reply With Quote
Old 01-23-2015, 05:05 PM   #3
MidnightKouki
But in all seriousness just remove your cluster and take the bulb out.
Old 01-23-2015, 05:11 PM   #4
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
Everyone just takes the bulb out.
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 01-23-2015, 05:13 PM   #5
revsx
Yeah thats what I figured Thank You!!
Old 01-23-2015, 05:25 PM   #6
S14DB
AFC #1
S14DB's Avatar
Since you have removed the airbag. You can remove the fuse in the fuse block by the pedals to disable the system.
There are Hubs that bypass the SRS and there are resistors that can be installed to fake out the SRS computer.
This is all for off road use only. None of this should be attempted on a street car.
Old 01-29-2015, 09:49 AM   #7
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
If airbag is removed, you can remove the fuse, or simply unplug the SRS computer. It's located under the center armrest.
Old 01-29-2015, 04:12 PM   #8
S14DB
AFC #1
S14DB's Avatar
Not on an S14. It's under the rear seat.
