12-07-2015, 09:12 AM | #1 |
glowing turbo
Hey guys. I am new to the S chassis. Always liked them and until recently never been able to afford one. Found a guy through a friend with an SR swapped 92 coupe. Coilovers, open downpipe, good bit of front suspension work, aftermarket radiator, bov, coolant reservoir, and some other odds and ends. The car came with a turbo elbow I have yet to install and it came with a Freddy intake. When deciding to purchase it, previous owner stated he had an issue that after 30 minutes or so the car would run hot. He did head gaskets, studs, and a bunch of other stuff trying to fix it and thought it was the turbo. I towed it home and found some clamps look but no significant leaks. Day after thanksgiving I was driving to work and all of a sudden I see the temp gauge rising. First time in a month of owning it. Turns out one of the hoses under the intake busted. Pulled intake, replaced hoses, and decided now would be the time to install the Freddy intake. All installed with a IACV relocation kit and having a few issues. First being idle concerns which I have to still do some work on. I changed the oil to confirm it wasnt milky. Took car for a quick spin. Ran good. Spooled nicely. Next thing I know I'm seeing smoke from under the hood and the exhaust. Thought there was some oil spraying up from under the hood onto the windshield and hit the wipers. Leaned up in the seat at the same time and realized I had a fire under the hood. Quickly pulled over, shut the car off and popped the hood. Manifold and turbo were GLOWING red. With the smoke I seen I am thinking I have blown a turbo seal and the oil got into the center housing causing the turbo to get hot. This would explain the smoke and the glowing. The fire started because the manifold wrap the previous owner installed couldn't withstand the heat.
Basically my question is if a bad oil seal would be the cause of what I experienced. I do not have much S chassis experience, mostly Z chassis. Any and all help would be appreciated. Thank you in advance. |
12-07-2015, 02:00 PM | #4 |
The glowing red is probably caused by the exhaust gases. That's about the only thing in the engine bay that will get something red hot. My best guess is that you're running lean, either because of a weak fuel pump, bad regulator, or busted mass air flow. Could also be timing is off, something along those lines. A lean condition would create that intense red-hot heat.
12-07-2015, 02:04 PM | #5 |
I just didn't think that simply swapping a greddy style intake would cause this issue. I have yet to read an installation that stated anything with having to check timing etc when swapping the manifolds. Car never did this prior to the coolant hose busting.
12-07-2015, 03:09 PM | #6 |
More air = more fuel. I don't see any mention of changing injectors or tuning.
The car needs a tune also. Do you have a wideband? This is vital to understanding what is going on with the engine. It would help eliminate some factors so you can narrow it down. |
12-07-2015, 03:21 PM | #7 |
I have a gauge but no sensor. Came in the car like so. The reason I am thinking I have a blown oil seal in the turbo is the grey smoke I am burning when I drove it. Turbo spools fine. But there is a huge trail of smoke behind the car. It does it at all times now. Car runs great, just smokes like crazy. I looked at the exhaust where the elbow meets the downpipe and realized there is a small leak there and after the exhaust starts to get hot, I get smoke from there that smells like oil.
12-07-2015, 04:05 PM | #10 |
Given you don't know if the block has 120k miles or 20k miles....it could be rings or it could be a pinhole in the oil return... If the spark is coming late it could be combusting in the turbo
12-07-2015, 06:00 PM | #11 |
If you glow a manifold, your timing is wrong, or you are making way more power than you have fuel for. Fuel cools of the exhaust (EGT) so does water injection, ethanol, methanol. But you are on straight gasoline right? So the EGT is skyrocketing either because you ran the engine hard (make power) without enough fuel (cooling), OR, Your timing is retarded and pushing heat to the exhaust system. The oil may be related somehow but it is mostly likely a result OF your high EGT and not the cause.
Steps I would take 0. compression test the engine to make sure a piston hasnt broken into pieces, allowing blow-by to push oil out of the engine 1: make sure you have enough fuel for the power you are making, i.e. Watch the wideband. 2. Set the ignition timing properly, use the FSM or find one of my many posts where I explain how I do it 3. Replace the ECU/CAS if the wideband says a good number (11:1 or 12:1 for example) and the ignition timing appears right, and the compression test is good. Alternatively you can diagnose each cylinder individually for a timing problem. I have seen this happen on a POwer FC, after 30 minutes of hot run time, suddenly one or two cylinders would glow red, the ECU was bad. |
12-07-2015, 07:25 PM | #12 | |
Could have melted the seals, when it went red hot. I'm not sure what it is but I'd get that af sensor and a turbo rebuild, and go that route. |
12-07-2015, 09:12 PM | #14 |
The oil burning and smoke started on first startup post coolant repair and manifold swap. Will check timing. Compression shouldnt be an issue as the engine runs extremely smooth all the way throughout the RPM range. I initially thought my issue was the loose clamp on the oil return. Again however, the oil burning was there before driving the car. Had a friend at work today check the shaft play in the turbo since its my day off, and he says its got a good amount of play, so rebuild/replacement was inevitable . Will see if i have a bung I can install a wideband sensor in. Will check compression.
12-08-2015, 01:58 AM | #16 | ||
Anyway you are right on the car needing a tune, but it has nothing to do with fueling, and it needs to be sorted BEFORE getting tuned. |
12-08-2015, 07:04 AM | #17 |
Never had an issue until after this hose ruptured. Replaced and swapped intakes per every write up available. Nothing anywhere states anything about needing to tune, change timing, fuel, or anything. None of that was messed with. No sensors were changed. Fuel system is the same with no change other than being put on another manifold. CAS was only unplugged to allow removal of the manifold. Again, compression will be tested even though the car runs entirely too smooth for me to think there is an issue there.
12-08-2015, 07:46 AM | #18 | |
12-08-2015, 07:49 AM | #19 |
You need a wideband. Nobody runs even the cheapest $2 redtop without a wideband. It doesnt make any sense and would prevent 98% of this posting. Guessing that the compression is good by the way it drives is also a mistake- even if it is good, you still want to be taking a measurement, and writing it down, at least once per year.
