02-03-2012, 02:19 PM | #1 |
"HUGE" Garage Sale in Central Florida! 240sx 300zx and misc parts!
First of all I would like to welcome everyone to my garage sale thread. I have sold off most of my projects to make room for new ones which is currently a 1972.5 Datsun Bullet side pickup that I'm putting my S15 sr 6 speed swap into and upgrading my S14.5 to at 6.0 liter LS. So please help me fund them. If the items are still listed forsale in the thread that means they are still available. I will edit the list as quick as I can to keep up with the sales. Best way to contact me is via text me @ 386-383-7052 or you can email me at [email protected] <---- also my paypal address If you don't see something forsale and I may have it laying around as i have been building these cars for about 15 years now and have a bunch of parts to say the least. Shipping is available if you pay via paypal. My paypal email address is [email protected] S13 parts *stock tension rods $30 each *front lower control arm $30 *front 4 lug hub each $20 *front spindle each $20 *front stock spring/strut combo $20 *rear 4 lug hub each $20 *rear 4 lug spingle each $20 *rear stock spring shock combo $20 *4 lug factory spare tire $20 *4 lug factory steel wheel *factory jack that fits in rear well $20 *drivers side stock tailight for hatchback $30 *passengers side stock tailight for hatch back $30 *drivers fender extension $25 *passenger fender extension $25 *domelight w/cover $20 *drivers door hinge set $20 *passenger door hinge set $20 *rear hatch privacy cover in great shape dark grey/black $50 *perfect red wingless hatchback with glass $150 (local pickup only) *perfect maroon wingless hatchback with glass $150 (local pickup only) *black center console $30 *analog dohc/sohc gauge cluster wiring harness $20 *HUD projector only (no instrument cluster) $40 *ash tray $20 * 5 speed black shifter bezel (NOT CRACKED!) $30 *factory shift knob $10 *driver side door glass $30 *passenger side door glass $30 *drivers SE door speaker mount with built in cross over $15 *passengers SE door speaker mount with built in cross over $15 *driver power door lock actuator with latch $20 *passengers power door lock actuator with latch $20 *driver power windows switch $20 *passengers power window switch $20 *driver window switch bezel in black $10 *passengers power window switch bezel in black for $10 *driver interior door handle $10 *passenger interior door handle $10 *driver interior door handle in chrome $10 *passenger interior door handle in chrome $10 *black/grey glove box $40 *driver side lap panel that holds hood release in black for $20 *driver kick panel that covers fuses in black $20 *passenger kick panel that covers ecu in black $20 *driver side defroster vent (NOT CRACKED!) $40 *passenger side defroster vent (NOT CRACKED!) $40 * instrument bezel that holds hazard switch in black (switches included) $40 *steering column cover top and bottom in black $25 *grey 75 amp main fuse for battery/alternator $5 *power window amp (mounts under driver door panel) $25 *dual cam auto ecu (no speed cut) $50 *factory radio mounting brackets $20 *ka24de head (no cams) $100 *ka24de bare block $50 *ka24de crank $50 *ka24de stock rods $10 each *ka24de stock pistons $20 each *ka24de 5 speed flywheel $40 *ka24de dust plate (mounts between bellhousing and tranny) $30 *5 speed flywheel bolts (set of 6) $25 *ka24de starter $30 *ka24de a/c compressor $50 *ka24de a/c compressor mounting bracket $20 *ka24de powersteering mounting bracket w/tensioner $25 *ka24de alternator mounting bracket w/tensioner $25 *ka24de used radiator hose set (both upper and lower) $10 *ka24de throttle body $25 *ka24de intake manifold complete with sensor and injectors $100 *ka24de stock exhaust manifold $25 *ka24de stock down pipe $25 *ka24de tps (throttle position sensor) $20 *ka24de knock sensor $10 *ka24de iacv (idle air control valve, cures most idling issues) $40 *ka24de crank pulley (harmonic balancer) $20 *ka24de oil pan (great for tapping for turbo) $50 *ka24de oil pump assembly (lower timing cover) $40 *ka24de upper timing cover ($25) *ka24de valve cover $40 *ka24e valve cover $40 *ka24de fuel injectors (set of 4) $40 *ka24e fuel injectors (set of 4) $40 *ka24de 5 speed bell housing mounting brackets (pair) $25 *ka24de 5 speed transmission cross member $50 *lower rubber shift boot with metal trim ring $30 *ka24de 5 speed speed sensor (vss) $50 *ka24de carrier bearing mounting bracket both pieces $20 More to come, updating list constantly!
Wheels in sig pic forsale. Rear 18x12.5 - 12 fronts are 18x10.5 - 10. Last edited by MiSuNdErStOoD; 02-08-2012 at 02:13 AM.. Reason: Inventory |
02-08-2012, 05:06 PM | #9 |
Wheels in sig pic forsale. Rear 18x12.5 - 12 fronts are 18x10.5 - 10. |
02-08-2012, 05:09 PM | #10 |
Love the name, named my newest bully that... sorry no I dn't have one of those that isn't broken at this time. I believe they are only like $44 or so last time I checked. That was awhile ago though. Good luck.
07-20-2012, 12:47 PM | #14 |
I still have loads of parts forsale. Just lost job and expecting my first baby son, please help me keep my. Family abobe water. Make offers. Will ship, paypal ready. Text me 3863837052
07-21-2012, 11:52 PM | #15 |
Just a heads up me and another guy locally have been scammed by this person. They sent us broken parts claiming they're good... so buyer STAY AWAY...
http://zilvia.net/f/private-sellers/...nderstood.html
powder-coated.com - I do Custom Powder Coating Last edited by CrazyIvan; 07-22-2012 at 11:44 AM.. |
07-22-2012, 11:45 AM | #17 |
You scammed me out of a headlight switch that costs what $30-$40... so I'm going to make sure everyone knows who they're dealing with before they send you any money.
If you're capable of scamming someone for $40 bux I feel sorry for anyone who will send you "real money"...
powder-coated.com - I do Custom Powder Coating |
