Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 04-07-2011, 06:01 PM   #1
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
rebuilding z calipers trouble
ok so first a story.
I had my 26mm aluminum front calipers powdercoated. Than I rebuilt them with the rebuild kit from PDM. while I was rebuilding them I noticed a bunch of glass bead in the piston cups ( which would lead to that the brake oil lines were not taped or the tape failed during the cleaning process. ) no big deal right ? take the 4 bolts off each caliper, pop out the piston's, and wash them down with compressed air and a lot of brake cleaner. simple plan.
problem. 2 bolts ( the inner 2 of the 4 ) snapped inside on one caliper.
I went to nissan today to get replacement bolts ( I was prepared for dry insertion btw ) and they said that the caliper's are never supposed to be taken apart and now both caliper's are fucked.
any truth to this ? or is there a place or nissan dealership that can help me get the 2 bolts I need to put my caliper back into 1 peice ?
thanks for any help, if theyre fucked theyre fucked just say so.
Big Zee is offline   Reply With Quote
Old 04-07-2011, 06:09 PM   #2
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
No, who ever told you that is a fucking retard.
I just took mine apart and had them sprayed.
Talk to this guy about finding new bolts.
http://zilvia.net/f/advertiser-annou...-specials.html
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 04-07-2011, 06:14 PM   #3
Sileighty_85
Sileighty_85's Avatar
Lowes/Home Depot
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-07-2011, 06:19 PM   #4
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
or McMasterCarr
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 04-07-2011, 06:24 PM   #5
Big Zee
Big Zee's Avatar
awesome thanks guys!
I just sent Mr. Russell a PM so hopefully he can source a couple bolts for me.
Old 04-07-2011, 06:31 PM   #6
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Take the other bolts off and measure them and I can source them for u
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 04-07-2011, 06:58 PM   #7
lflkajfj12123
Nissan is correct in saying they're not supposed to be taken apart... for the most part
the bolts you can buy from anywhere
Old 04-08-2011, 06:01 PM   #8
Big Zee
Big Zee's Avatar
^ yea, but the manner in such the assclown's did so is more what got my gears grinding.
whats done is done though now it's finding the solution to the trouble
Old 04-08-2011, 06:20 PM   #9
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
They're not supposed to be taken apart because they never made replacement o-rings for the fluid passages between the two halves. Z1motorsports has these o-rings for when you want to put the calipers back together.
DeleriousZ is offline   Reply With Quote
Old 10-17-2012, 06:20 AM   #10
teddyjr
teddyjr's Avatar
teddyjr is an unknown quantity at this point
Thanks!
I've been stressing (not really) about the caliper joint seals now that I've sent my halves to powder-coat. They were siliconed by the previous mechanic. I'm getting the whole rebuild setup from Z1 as suggested. Stress is all gone now.
Thanks for the tip - didn't know those guys since I Skyline. Glad I searched before asking!
teddyjr is offline   Reply With Quote
