Old 10-31-2017, 11:15 PM   #1
Socal240sxSr20det
Socal240sxSr20det is an unknown quantity at this point
SR Scratch on fresh engine deck
So unfortunately while taking my engine back from the machine shop I scratched the engine surface. Bottom end is built, and it was decked. I would normally send it with copper spray, but I plan on using a Tomei head gasket which is precoated. Do you guys think this will cause an issue? It does catch on your nail.
Socal240sxSr20det is offline   Reply With Quote
Old 10-31-2017, 11:17 PM   #2
Socal240sxSr20det
I can't post pics i guess, so here is the link.
https://imgur.com/a/HDSeI
Old 11-01-2017, 08:44 AM   #3
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
It doesn't protrude into a passage so you should be fine.
[email protected]
hanzbrady is offline   Reply With Quote
Old 11-01-2017, 08:47 AM   #4
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
I'm assuming the gasket is multi layer as well, so you should as mentioned, be fine.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 11-01-2017, 01:46 PM   #5
Socal240sxSr20det
Thanks everyone, should i try and debur it all or just install the gasket normal procedure.
Old 11-01-2017, 01:47 PM   #6
hanzbrady
hanzbrady's Avatar
You can go ahead and buff it down with some sand paper and then use a scotch brite pad to help smooth it out.
[email protected]
Old 11-01-2017, 02:11 PM   #7
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
I scratched my block near cylinder 4 between the cylinder and the water jacket. I was really concerned about it but I've got her back together and she's sealed. I didn't sand it or try to smooth it out, I was even more worried about deforming the surface of the block. For what it's worth I'm using a Tomei headgasket and I used copper spray also.
Frank_Jaeger is offline   Reply With Quote
Old 11-02-2017, 08:28 AM   #8
mct3351
mct3351 is an unknown quantity at this point
That's for the oil draining back into the block from the head so it isn't pressurized. It probably won't leak but if you want put a dab of ultra grey on it right before you bolt the head down similar to what you do at the front cover.
mct3351 is offline   Reply With Quote
