Old 02-26-2016, 06:37 PM   #1
M374llic4
M374llic4 is an unknown quantity at this point
Send a message via AIM to M374llic4
My newest project. KA24E-T with a goal of 450-500hp
I sold my supercharged KA24DE-R a few months ago to buy a Titan (it was my only car at the time, and I lived in a condo which would fine you if they saw you open your hood) but now have a house with an empty garage. I love the truck, but god damn do I miss my 240s and boost, so I bought this today. The first few pics are how she looks at the moment (currently a project, going to tear everything down, inspect, and replace anything that looks off and put in eagle rods). The nicer pics are how she looked when she was built a few years ago.
This is only the 2nd time that I have owned a 240 while actually having another DD (have owned 14, well 15 now, 240s), and this seems like it could turn out awesome after some TLC. I am hoping that after adding rods and probably a bigger turbo along with the standalone (MegaSquirt), and the not pictured intake plenum, I can get somewhere around 450-500hp. I also have a Devils Own meth/water injection kit in my garage I never used that I might try to incorporate. Probably going to also use the full potential of the Megasquirt and go MAP, electronic boost control, and multiple 'on the fly' fuel map switching.
Recommendations based on what you see in the parts list are also welcome. I do not plan on having her up and running for several weeks, possibly months if that is what it takes to make her solid and the beast she deserves to be again (was last dyno'd at 350hp / 370tq by Martin of Enthalpy I was told).
It is nice to be back. : D
Here is the current parts list
Engine
Block bored .20 0ver
Block and head decked
Block magnafluxed and checked
Valve job with including valves, guilds and seals
ARP Head studs
12pc Valve Spring set
Cometic head gasket
Mechanical lifter set
Custom Intake Plenum (not pictured or installed yet)
Custom grind Mechanical Cam from O&J Performance Orlando
286 Duration 490-495 Lift (The engine machine work was done by rev masters in old winter garden.)
Clevite bearings
Aries 8.8:1 pistons
JGS exhaust manifold
Tial 38mm wastegate w/ 10.3 psi spring
Greddy rs bov recirculated
Garrett t3/t04e 360 degree thrust bearing turbo with the same miles as the engine
750cc top feed injectors
Fpr / walbro 255 fuel pump
Wire tuck
N62 maf
Megan aluminum radiator
White bunny hybrid clutch (d21 flywheel/280zx clutch)
3 inch full exhaust from the turbo back
Custom outlet pipe
Custom intercooler piping FMIC
Dual electric fans with factory clutch fans
New clutch master and slave cylinders
Managment
(used to have this, but am going standalone - probably DIYPNP Megasquirt)
Enthalpy tuned factory ecu
AEM truboost
AEM wideband
Electirc oil preasure, voltage
Water temp
Brakes/WHeels
Front j30 calipers and rotors
Rear brembo rotors/ hawk pads
Goodridge stainless brake lines
New break booster
Newer master cylinder
XXR 962 17x9 all the way around 215 45 17 rubber in very good shape more than 75% tread life left
25mm spacer front
30mm spacer rear
Suspension
Tein super street coilovers
Tein pillow ball mounts
Energy suspension master bushing kit
New ball joints
New rack and pinion with inner and outer tie rods
Isis rucas and other parts (not yet installed)
exterior
180sx rear valances
Bomex aero mirrors
Custom hood spacers for ventilation.
Last but not least, what really matters, the pics. (Keep in mind the first pics are of how she looks currently, and the later ones were from when she was built 4-5 years ago.
http://imgur.com/a/z3v5x
M374llic4 is offline   Reply With Quote
Old 02-26-2016, 10:53 PM   #2
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Good work so far. You'll be heating up the streets in no time.
SoundEfx is offline   Reply With Quote
Old 02-26-2017, 02:58 AM   #3
ScrapnSidwayz
ScrapnSidwayz's Avatar
ScrapnSidwayz is an unknown quantity at this point
Very nice build man. What main studs did you use for those power levels? I am building my single cam and I'm debating whether to buy new OEM studs or upgrade to ARP main studs. I'm unsure what power levels the OEM main studs are reliable too.
ScrapnSidwayz is offline   Reply With Quote
Old 02-27-2017, 08:08 AM   #4
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
hell yeah, I made 400whp on a pretty simple ka24et setup
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 02-27-2017, 01:02 PM   #5
mikey976
mikey976's Avatar
mikey976 is an unknown quantity at this point
Send a message via AIM to mikey976
subbing, this place needs more Single Jingle love
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig
mikey976 is offline   Reply With Quote
Old 02-27-2017, 02:02 PM   #6
PoorMans180SX
PoorMans180SX's Avatar
Do yourself a favor and ditch the turbo designed in the 70's...
Looks good.
Old 02-28-2017, 12:19 AM   #7
ScrapnSidwayz
Sweeeeeeeet. I'm shooting for 350-400whp at the most so it is good to know the OEM main bolts can hold it.
Old 02-28-2017, 12:46 AM   #8
Malik
Malik's Avatar
Malik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant future
good luck... I always root for the single cam.
Malik is offline   Reply With Quote
