12-26-2016, 01:14 PM | #1 |
Semi Peripheral EFR9174 E85 @17psi Dyno #ThisistheWolf
Before people Blast me for not cranking up the boost. I'm done breaking transmissions....and so I've asked Abel to bring power and Tq down. This lets me drive the car harder and worry about the next clipping point or following a driver rather than worrying about slipping the clutch extra every time I shift.
Engine Specs: FR Performance Built 13B REW Semi Peripheral Port/Street Port Non-Balanced but weight Matched PTS 2mm 2 piece seals Glease Man Billet Series Manifold Dual EGT's (not running) EMAP (Running) All the Above was at 8lbs of Back Pressure:icon_tup: Dual Turbosmart Comp gate 40's off turbine Housing 17Lb Springs Not running EBC Yet ECU: Adaptronic Modular PnP Fueling: Custom Set up: CJ-M Dual Pump Hanger with Walbro E85 Lift Pump Radium Dual Bosch External Surge Set up W/2 Fuel Filters All AN-8 Lines (6) Injector Dynamics ID1700X Full Function Engineering Primary Rail W/(4) Secondary Injectors Running 3 stages of Injector If anyone is interested in the Dyno Logs... I can send em no prob:icon_tup: Response is beautiful and easily the best I've ever felt on an FD. Andy Wyatt came and set up the new ECU himself. And Abel Ibarra took over the Full Boost Maps!! car drives like a dream.. even at the slightest bit of throttle. No issues driving at 1400RPM..and I'll try and get some video of it asap. I'll probably be going back to the 8374 to gain the bit of low end we had before.. Tune for what you need... not for all out power :icon_tup: Dyno Video https://www.youtube.com/watch?v=Y-rRS5tHnc4 Track Testing https://www.youtube.com/watch?v=4vUqpHHVxv8 In Cabin https://www.youtube.com/watch?v=DojvZHrEuPo
IG:@AAPARKAH #ThisIsTheWolf |
12-28-2016, 03:49 PM | #3 |
Why not invest a little in a stronger transmission? Considering the rest of the build it seems like that's all it really needs now. It's not THAT expensive all things considered lol.
01-11-2017, 01:08 AM | #6 | ||
Disregard my Turbo Choice... Why?...because I'm rotary...and we generate a whole lot more exhaust gas than our piston counterparts. Rule of thumb is....Take whatever a turbocharger is rated at... and for a 2 rotor...13B.. Divide it by 1.3. So if a turbo is rated for 800 WHP....it'll do 615. Cool? Loud? Flames? YES!!....but less efficient haha. Stick with what everyone is using on 6 cyl or 4 cyl on this forum....just with an EFR and you'll be very impressed and never look back!!!
