Old 07-16-2019, 02:28 PM   #1
inopsey
Arrow s13 coupe partout sr20 s14 oem
im parting out my 89 with coupe hud dash and sunroof
lots of parts not listed
EVERYTHING IS OBO
WILL SHIP EVERYTHING
OEM HUD windshield mint 4 months use
ka block (89) rebuilt head and new timing chain, no piston slap on cylinders under 2000km on rebuild.
crack less hud dash
s13 front seat belt buckles from manual seatbelts (coupe) $45 ea
s13 hatch manual seatbelt conversion with a and b pillars sold
s13 cluster surround-$old
s13 chassis harness, power windows and sunroof-$675
s13/s14 SPL RUCA-$old
s13 kick panels $35 ea
walboro fuel pump-$old
s13coupe c pillars for manual seatbelts-$90 ea
s13 stereo brackets and din cup-$old
mudflaps for s13-
s13 custom 1/8" mdf s13 6.5 front door speaker adapters 20$
s13 tcu-$old
s13 window amp-$95
s13 grey headlight cover-$70
s13 pop up headlight motor $old
s13 cruise control unit (mechanical part) $75
s13 sunroof assembly sunroof motor, switch etc
s13 grey floor mats-sold
s13 brake master cylinder newer condition no leaks 50$
s13 ka clutch fan -$75
s13 glove box no front cover-10$
rear view mirror 35$
S14 chassis parts
s14 KW v3 coilovers rear only $sold
kouki s14 abs differential sensor-850
s14 tension rod brackets-$80 each
s14 inner and outer tie rods-$old
ruca-$40
toe-$30
traction-$30
rlca-$30 need ball joints
sr parts
s13/s14 sr20 coilpacks-$25 each
s13 sr20 oem coilpack harness-$30
s13 sr20 clutch fan-
blacktop knock sensor 60$ shipped lower 48
s13 sr20 ac compressor sold
sr s13 stock clutch $55
ka parts s13 and s14
s13 manual brake petal $50
s13 motor mounts-$70 /set
s14 auto tranny 100k miles
s13 and s14 ka starter $50
s13 and s14 ka altenator $60
s14 obdII intake manifold $195
s14 obdII egr solenoid and valve $old
s14 obdII aicv 55$
s14 auto tps $old
s14 injectors and fuel rail-$65
s14 kouki dryer can $95
Old 07-17-2019, 10:54 AM   #2
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Pictures of the c pillars for Manuel seatbelts for coupe?
andisan is offline   Reply With Quote
Old 07-17-2019, 02:09 PM   #3
IketaniS13
IketaniS13's Avatar
IketaniS13 is a well-known jackass
Are the mud flaps still available? There was no price or sold in OP.
IketaniS13 is offline   Reply With Quote
Old 09-17-2019, 08:27 AM   #4
inopsey
bump.... ....
Old 09-17-2019, 08:28 AM   #5
inopsey
those are sold
Old 09-17-2019, 07:51 PM   #6
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Where Kanada are you located? How much for the center cluster lid that hold shifter boot?
kennedy8383 is offline   Reply With Quote
Old 09-18-2019, 11:45 PM   #7
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
WTF is up with photobucket and the blurry pics??
RalliartRsX is offline   Reply With Quote
Old 09-19-2019, 06:26 AM   #8
Krazy719
Krazy719 is an unknown quantity at this point
How all the weather stripping & all outside trim going around windows
Krazy719 is offline   Reply With Quote
Old 09-24-2019, 10:22 PM   #9
inopsey
it isnt cracked and doesent leak, all is original except the drivers side rubber that goes around the side mirror
Old 09-24-2019, 10:23 PM   #10
inopsey
thats sold
Old 09-25-2019, 04:08 AM   #11
cycloneskate
cycloneskate is an unknown quantity at this point
Do you still have the s13 coupe dome light that's in the pictures? Im in 92584
psh why pay someone else when you can do it yourself?
cycloneskate is offline   Reply With Quote
Old 09-25-2019, 09:13 AM   #12
GuestUser
GuestUser is an unknown quantity at this point
What condition is the chassis harness in?
GuestUser is offline   Reply With Quote
Old 09-26-2019, 12:59 AM   #13
Alexisdiaz
Alexisdiaz is an unknown quantity at this point
How much for the sunroof assembly? Shipped to 85028
Alexisdiaz is offline   Reply With Quote
Old 10-01-2019, 02:13 PM   #14
inopsey
that has the switch for the sunroof and will be sold with the sunroof glass and rails
Old 10-01-2019, 02:15 PM   #15
inopsey
its uncut but an alarm had been installed, all power options on the harness and from a coupe.
Old 04-25-2021, 11:53 PM   #16
inopsey
bump because pics are working again
Old 04-28-2021, 06:45 PM   #17
90_S13
90_S13's Avatar
90_S13 is an unknown quantity at this point
I'll take the manual brake pedal and is that an s14 or s13 radio?
90_S13 is offline   Reply With Quote
Old 05-02-2021, 06:15 PM   #18
inopsey
thats a s14 radio. pm you
Old 05-17-2021, 12:24 PM   #19
inopsey
bump.........
Old 06-04-2021, 04:10 PM   #20
steel30coupe
steel30coupe is an unknown quantity at this point
Got a pulse generator for an auto?
steel30coupe is offline   Reply With Quote
Old 06-04-2021, 04:11 PM   #21
steel30coupe
Radiator overflow tank?
Old 06-10-2021, 10:16 PM   #22
inopsey
i dont have that
Old 06-14-2021, 05:57 PM   #23
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Do you still have the climate control unit?
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 06-21-2021, 07:24 PM   #24
Broke as a joke
Broke as a joke's Avatar
Broke as a joke is an unknown quantity at this point
is the pop up light shroud still available?
V-tec
Broke as a joke is offline   Reply With Quote
Old 06-22-2021, 12:43 AM   #25
wezurii
wezurii is an unknown quantity at this point
sent you a pm
wezurii is offline   Reply With Quote
