Old 04-29-2012, 09:14 PM   #1
yanay
yanay is an unknown quantity at this point
rb25 help needed
hey guys cant seem to get any answers on most forums so i thought i could try here..
series 2 rb25
gt3076r
stock manifold modded for external wastegate
3" full exhaust
stock injectors
walbro 255
fmic
chopped factory intake for 3"
i blew up my factory turbo and got a good deal on the gt30 so i thought what the hell..
hooked everything and started her up and i have a very very low idle with lots of popping. as soon as i boost i get a mad hesitation on WOT and if i put the clutch in and pop it in neutral it will die out instantly than not want to start. its been driving me crazy over the last week trying to diagnose it. it seems its running rich at some points and running lean at some.. the only thing i can think of is the 02 sensor is not wired properly.. i have 3 brown wires 1 dark 2 light and the 02 sensor has 2 white and one black. i assumed the dark to dark and light to light but could be far off.
i have a wideband and adjustable fpr on the way and i just need the car to run with 7 psi so i can get it to the tuning shop in calgary.. (250k) to get a dyno tune and injectors thrown in.
ive searched everything and tried so much and im pulling out my hair here.. anyone have ideas?!
yanay is offline   Reply With Quote
Old 04-29-2012, 09:20 PM   #2
Sileighty_85
Sileighty_85's Avatar
Sounds like a Vac/boost leak.
Plus the Stock ECU doesnt like any more boost then stock. It will then pull timing and dump fuel.
and no 7 psi on a GT30 is not the same as a 7 PSI on a factory turbo. Thats one reason why it runs like shit.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-29-2012, 10:23 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Like already said, DO NOT DRIVE THE CAR INTO BOOST WITH THAT TURBO WITH NO TUNING!!! Keep at it and you wont make your tuning session since you're engine will be blown.
CLICK HERE!!!
Old 04-29-2012, 10:31 PM   #4
yanay
hmm okay.. anything else you guys can recommend ? can i tune it as is without extra parts getting put on..? i have my maf 5 inches away from turbo and the filter pointing down. can that cause issues? i just want to get it half ass ready for tuning so im not paying out the ass for them to fix little shit for me at autodream..
Old 04-29-2012, 10:39 PM   #5
Sileighty_85
Umm you think Stock 370cc Inj and stock MAFS are enough to run a GT30.... Jesus.
Search around kid for a proper fuel system setup...
Or just save your self the trouble and drop a grenade under the hood.
EDIT: Also Welcome to Zilvia Hope you enjoy your stay....
後輪駆動車1番
1986 SR86 - 200ish
Old 04-29-2012, 10:52 PM   #6
yanay
doesn't hurt to ask.
Plan is injectors, adjustable fpr and a wideband right away.
Im not asking if i can rip my car around boosting the hell out of it with stock fuel setup. ( i havent boosted past 5 psi with it) and it was 2 pulls)
im simply asking if i can get some help figuring out why i cant idle it. and it sounds like hell just sitting in my driveway or if anyone knows the wiring setup on the 02 sensor or can point me in the direction of what to go over. ive check coils and they are like new. im about to test my maf ive gone over all my vacuum lines and cant find a leak
Old 04-29-2012, 10:55 PM   #7
yanay
the turbo is a precision 5252e i was told its comparable to a gt30
Old 08-26-2012, 05:38 PM   #8
yanay
hey so little update. checked with autodream and they told me it will be fine to run the turbo with the setup i have.
I have been driving the car for months now with no issues 6 psi on the turbo is hitting 11.6 afr at wot 14.6 at idle and 13.9 cruising.
still cant figure out why it wont idle after free revving in neutral tries to die out.
cleaned iacv checked vaccuum leaks etc
