Old 01-07-2013, 09:32 PM   #1
JSpecBnr32
JSpecBnr32's Avatar
JSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud of
Send a message via AIM to JSpecBnr32 Send a message via MSN to JSpecBnr32
Garage Sale! S13/S14, KA24/SR20, R32/Z32, 350Z PARTS GALORE!!!!!!!!!
KA24DE(E) PARTS
-2x KA/SR Shifter w/housing........................................... ....................$30
-Just shifter $15...............just housing $15
-3x Ka24de stock injectors......................................... .........$15 each
-brand new lower radiator hose.............$20
-Ka Alternator. . .. . .. . .. . .. . .. . .. . .. . ...$30
-Lower Radiator hose water temp sensor and housing. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$10
-Ka24de Aftermarket Aluminum Emissions Block off plates. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$25
-Ka24e Mafs w/plug (works with sr20det too). . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$40
-2x 5sp S13 Ka Speed Sensors. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$40 each
-Ka24e Power Steering Pump. . .. . .. . .. . .. . .. . .. . .. . .. . .$30
-TOB (throw out bearing) shaft housing w/ pivot ball (works with sr too). . .. . .. . .. . .. . .. . .. . .. . ...$20
SR20DET PARTS
-Greddy Sr20det Hotpipe w/ Greddy BOV flange (Greddy Type RS BOV listed below). . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$old
-Mint freshly sandblasted Raw Aluminum s13 sr20det valve cover ready for paint or polish. . .. . .. . .. . .. . .$100
- S13 sr20det Idle Air Control Valve..........................................$ol d
-Phase2 sr20det Ground Wiring Kit New.......................................$30
-sr20det Fuel Rail w/ SARD 550cc injectors....................$300
-STI OEM 550cc injectors…………………………………†¦â€¦â€¦â€¦â€¦$220
-sr20DET turbo outlet t25............................................... ...........$30
-S13 Sr20det TPS sensor............................................ ...................$40
-sr20det Water pump pulley............................................ .........$20
-sr20det s13 valve cover gasket............................................ .$10
-Oem Clutch Fan Assembly (clutch and blades). . .. . .. . .. . .. . .. . .. . .. . .$25
-SR and KA Power Steering bolts......................................$7 each
-T25 wastegate. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$20
-Sr20det Lower Radiator hose. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$20
-S14 sr20det injector harness. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$30
-S14 Sr20det complete uncut engine harness ready to be modified for your s13 or s14. . .. . .. . .. . .. . .. . .. . .. . .. . ..$200
-Brand New Oem Nissan Sr20det Rear Main Seal. . .. . .. . .. . .. . .. . .. . .. . .. . ...$20
-T25 Metal OEM Turbo Gasket. . .. . .. . .. . .. . .. . .. . ...$10
-OEM Sr20det Throttle Body 3" Coupler for Smic or?..........................$15
-Upper Radiator Neck. . .. . .. . .. . .. . .. . .. . .. . .. . .$30
-2x Blown T25's ready for a rebuild. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$50 each
-OEM sr20det Fuel Pressure Regulator. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$15
-OEM cast iron Turbo Manifold. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$30
S13 PARTS
-180sx kouki type X right circle turn signal......................$30
-Baby Blue 180sx left front headlight cover...........................$15
-5sp manual s13 Driveline. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$OLD
-2x passenger side window (one tinted one not)…………………………$40 each
-s13 coupe power sunroof glass oem…………………………………$50
-Auto s13 Driveshaft…………………………………⠀¦â€¦â€¦â€¦â€¦â€¦â€¦..$20
-Front Bumper Support……………………………………⠀¦â€¦â€¦â€¦â€¦â€¦.$30
-Foam insert for front bumper support…………………………$15
-ka24e exhaust manifold w/heat shield……………………………..$20
-steering column w/o ignition…………………………………… ……..$30
-2x s13 rear view mirror's.......................................... ..........$20 each
-s13 Gas Door.............................................. ........................$20
-s13 Center Dash vent.............................................. ...........$10
-s13 hatch right rear complete speaker cover...................$15
-s13 hatch L and R just covers...........................................$ 15 both
-2x s13 under column dash panels............................................ ......$15 each
-Front left and right inner fender liners…………………………………$15 pair
-s13 hatch left taillight …………………………………………†¦â€¦â€¦.$25
-s13 coupe left taillight…………………………………†¦â€¦â€¦â€¦â€¦â€¦..$25
-s13 oem catback exhaust w/ muffler cut off (straight pipe)………………….$30
-S13 oem catback exhaust w/ flange that bolts to cat cut off……………………$50
-s13 passenger side door w/ manual window (primer grey)……………………………………… ….$60
-s13 4lug donut w/ tire………………………………………⠀¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦.$25
-s13 stock front and rear suspension…………………………………⠀¦â€¦..$50
-A pillar trim pieces Left + Right (inside)………………………………….$3 0 pair
-2x Outter A pillar trim pieces Left + Right…………………………………..$30 pair
-Left Drivers side hatch rear quarter panel glass……………………………….$50
-Coupe rear inside trunk taillight plastic liner………………………………..$10
-Coupe rear glass……………………………………… …………………………………$80
-Coupe rear trunk hinges……………………………………†¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦..$15
-s13 drivers side power mirror assembly..........................$20
-grey s13 Power Mirrors L+R. . .. . .. . .. . .. . .. . .. . .. . .. . ..$40 pair
-s13 right pop up headlight plastic cover...........................$15
-s13 JDM drivers side kick panel w/ fuse layout...............$15
-s13 gas pedal assembly.......................................... ..........$15
-s13 Rear/middle tranny mount exhaust hanger brackets...$10 each
-2x s13 hatch rear wiper motors.......................................$15 each
-3x s13 inner tie rods.............................................. ..........$15 each
-3x s13 3 prong headlight harness's..................................$10 each
-s13 passenger front window............................................ .$40
-S13 rhd clutch line.............................................. ..............$10
-Power Antenna. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$20
-Complete Fuel Pump Assembly w/ pump and cage. . .. . .. . .. . .. . .. . .. . .. . ...$50
-RHD shifter Bezel. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$30
-Radio Brackets w/ lower plastic storage bin. . .. . .. . .. . .. . .. . .. . .. . ..$30
-Misc. Buttons (Headlight motor, Hazard, Rear Defrost). . .. . ..$5 each
-Drivers side Sun Visor. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$15
-Door Plastic Speaker Inserts. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$20 pair
-Rear 4lug hubs. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$40 pair
-Oem front brake line (one only). . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ....$10
-Rear Hatch Tail Light under garnish black. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$40
-Full set of 4lug hubs +rotors. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$60
-Pair of front s13 knuckles w/ 4lug hubs (ready to be modified for angle!!!). . .. . ...$50
-Left front Lower Control Arm w/ ball joint. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$30
-Rear pair of s13 oem mudflaps. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$20
-2x L+R outside Door Handles. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$40 pair
-inner door panel cup. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$5
-manual window roller handle. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$5
-Power Folding mirror button w/ plug. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$15
-oem horns. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$10
-3x Fuse Panel covers w/ fuse diagrams (one black, one blue, one brown). . .. . .. . .. . .. . .. . .. . .$10 each
S14 PARTS
-s14 E-brake assembly.......................................... ..............$30
-s14 Ash Tray.............................................. ........................$20
-s14 Zenki Grill............................................. ........................$30
-s14 Side Markers........................................... .....................$20
-s14 se OEM electric radiator fan......................................$40
-Oem ka24de downpipe…………………………………… ………….$30
-Front Swaybar w/ end links……………………………………… ….$50
-Passenger side Kouki s14 front fender (needs body work near corner light area has damage)………$30
-s14 glove box assembly w/ mount....................................$40
-s14 steering colum grommet........................................... ..$10
-S14 Non-Abs Brake Booster. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$30
-One s14 OEM tension Rod. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$20
-S14 Tie Rod Inner + Outter. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$20
S13/S14 PARTS
-5sp tranny crossmember………………………………… ……………………….$40
-Clutch Pedal Assembly (need this for your 5sp swap!!!). . .. . ...$old
-oem traction rods.............................................. ..........$20 pair
-Megan Racing rear subframe/toe arm brace..............................$60
-s13/s14 lower radiator grommets....................................$10 pair
-Master Cylinder 5/8ths. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$25
-Slave Cylinder. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$5
-OEM rubber Exhaust hangers. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$5 each
Z32 PARTS
-Rear Aluminum Uprights/Knuckles (great upgrade for s13/s14 owners). . .. . .. . .. . .. . .. . .$60 pair
-N62 z32 Mafs w/ plug.............................................. ..........$100
-New OEM z32 fuel Filter. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$10
-F+R OEM Brake Rotors 4x. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. $15 each or $50 for 4
-Brand New OEM Outter Tie Rods. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$40 pair
R32 PARTS
-Steering column w/ ignition and key………………………………….$70
-center console……………………………………⠀¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦.$30
- Upper center console (in between dash and center console piece)………..$20
-Front Sway Bar w/ end links……………………………………… ……………………………$60
-Front Right Tension rod bracket……………………………………⠀¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦$30
-glove box………………………………………†¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â €¦â€¦.$30
-Power Steering Rack w/ tie rods and ends and PS lines……………………….$80
-Dash………………………………………⠀¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦..$ 60
-Left and Right LCA’s/UCA’s/ Knuckle hub assemblies(Lower Control Arm/Upper Control Arm)……………………..$80 pair
-N60 Rb20/Rb25 Mafs w/o plug........................................$60
-r32 Cluster w/ no tach..........$40
- r32 mechanical Speedo Cable. . .. . .. . .. . .. . ..$30
-2x R32 fuel pumps. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$40 each
UNIVERSAL AFTERMARKET PARTS
- NEW Greddy Type RS BOV . . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$150
-Greddy E-Manage Blue Piggy Back Engine Management system, complete with harness, cords and box practically new. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$150
-Nice Aftermarket Hood Dampers. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$30
-Apexi 4' Titanium N1 Muffler. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$100
-FET Turbo Timer TB-304 w/ wiring harness. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$40
-Gold Ebay Adjustable Fuel Pressure Regulator w/ gauge. . .. . .. . .. . .$35
-New MSD Blaster 2 Ignition Coil. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$50
-2x Random Cone Air Filters........................................... ..........$10 each
-new 90 degree 2.5" 4 ply JDM sport red coupler............$20
-3X new 90 degree 2.5" single ply black coupler...................$10
-Custom Sub Box for 2 10's. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .$50
-12" Pyle Red Label 800watt 4 OHM sub woofer. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ...$50
350Z PARTS
-Right Front Lower Control Arm. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . .. . ..$60
Pics Upon Request, Adding more parts constantly so check back, If there is something that you need and you don't see it listed message/txt me and I just might have what your looking for. PRICES ARE ALL Or Best Offer!!!!! Also interested in trades
Call/txt (425)-760-7339
myspace.com/sx_drifter
JSpecBnr32 is offline   Reply With Quote
Old 04-16-2013, 05:00 PM   #2
jscherf92
jscherf92 is an unknown quantity at this point
water neck s13 or s14? s14 and ill take it.
jscherf92 is offline   Reply With Quote
Old 04-17-2013, 01:30 AM   #3
KOUKIboy
KOUKIboy's Avatar
KOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-known
Can I get a pick of the Kouki fender with the damage???
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87
KOUKIboy is offline   Reply With Quote
Old 04-17-2013, 10:34 AM   #4
ersus
ersus's Avatar
ersus is an unknown quantity at this point
Send a message via MSN to ersus
pics for Gold Ebay Adjustable Fuel Pressure Regulator
ersus is offline   Reply With Quote
Old 05-17-2013, 09:46 PM   #5
Yahshua92
Yahshua92 is an unknown quantity at this point
how much to ship s13 coupe left tail light assembly to 85730?
Yahshua92 is offline   Reply With Quote
Old 05-18-2013, 01:52 AM   #6
2LiterTurbo
2LiterTurbo's Avatar
2LiterTurbo is an unknown quantity at this point
Sent you a PM.
2LiterTurbo is offline   Reply With Quote
Old 05-21-2013, 10:33 PM   #7
stavirb25
stavirb25 is an unknown quantity at this point
You still got s13 sr20det upper water neck?
stavirb25 is offline   Reply With Quote
Old 06-01-2013, 11:26 PM   #8
driftschool
driftschool is an unknown quantity at this point
if you still have the T25 turbo outlet pipe shoot me a message with your number, need to buy asap
driftschool is offline   Reply With Quote
Old 06-02-2013, 11:33 PM   #9
CharCharXD
CharCharXD's Avatar
CharCharXD is an unknown quantity at this point
$20 shipped for all 3 injectors
CharCharXD is offline   Reply With Quote
