Old 08-03-2010, 06:57 PM   #1
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
Scottie Doesnt Know S13 Coupe Build
I will let the pictures do the talking. This project has been going on for longer than I care to remember. Hope you guys enjoy!
Started with......
Media Blasted
Fitting Body
Origin Lab Doors w/Custom Aluminum Backing Plate
Powerplant
Speartech Harness
GTO Pedal Setup
PRC LSx Radiator w/Custom Aluminum 12" Dual Fans
Suspension Components
Sikky Mount Kit
More to come...
scottie is offline   Reply With Quote
Old 08-03-2010, 06:58 PM   #2
scottie
scottie's Avatar
Dash Solution.....
It is now in the capable hands of Broadfield!
Old 08-03-2010, 09:30 PM   #3
stone184
stone184 is an unknown quantity at this point
Looks absolutely bitchin!
stone184 is offline   Reply With Quote
Old 08-04-2010, 09:36 AM   #4
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
WOW, awesome!! Mad props!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 08-05-2010, 12:02 PM   #5
scottie
scottie's Avatar
Thanks man! I love your build as well. Very simple and detailed. Looks factory yet you know its modded by the overall look/feel. I know mine is completely different so thanks for the encouragement! Hopefully I will have some useful updates in the near future.
Old 08-25-2010, 09:50 AM   #6
scottie
scottie's Avatar
Well the car isnt going to be done for a while at the body but the cluster is finished. HUGE THANKS to Broadfield for his services.
This Setup will Monitor:
RPM
MPH
Gear Selection
ECU Codes
Oil Pressure
Fuel Pressure
Oil Temp
Coolant Temp
Wideband A/F (left)
Fuel % (right)
Black Label LS2 Rails
Old 10-08-2010, 09:23 AM   #7
scottie
scottie's Avatar
Custom Bash Bar (tandem drift protection)
Sikky Kit Installed
Old 10-10-2010, 08:07 AM   #8
Csomme
Csomme is an unknown quantity at this point
I love it<3
Csomme is offline   Reply With Quote
Old 10-11-2010, 10:10 AM   #9
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
awesome.. have any pics on how you mounted the bash bar to your car?
Black240Ct is offline   Reply With Quote
Old 10-12-2010, 08:27 PM   #10
scottie
scottie's Avatar
I dont yet. Once I can get the whole car back to the fab shop, I will post pics of how it will mount. Its pretty simple but hard to explain. Basically going to use base plates and slip fitting to hold the bash bar in place.
Old 10-13-2010, 03:53 PM   #11
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Awesome build !!!
Subscribed !!!
Old 10-14-2010, 07:50 AM   #12
scottie
scottie's Avatar
I installed the injectors & engine harness.
My plan is to route everything to the driver's kick panel. The fan relays, injector relays/fuses and ecu will go in the inside panel where the oem chassis fuse block was locatrd. The new painless harness is "planned" to be mounted in the center under the armrest. This way I can avoid having pesky passengers accidentally kicking my sh*t.
Old 10-14-2010, 06:53 PM   #13
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
wow, i love everything i see. broadfield did a great job like always. you are dropping a pretty penny on this coupe.... im sure it will be worth it!!!
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 09-09-2011, 11:43 PM   #14
scottie
scottie's Avatar
I couldnt decide what I wanted to do with the dash.... leave it alone, wrap it, new vinyl...... then I said Flock it and ordered this....
And simply one of the coolest gadgets to simplify the wiring and my well being as a result. The ARC flat touch panel is killer.
Old 09-09-2011, 11:47 PM   #15
scottie
scottie's Avatar
Since I decided to leave the wide body panels exposed (not molded) I wanted to make it easy to remove buy using bolts vs rivets. And of course you cant just go down to ACE Hardware.
And another much larger box showed up with nothing written on the outside. Hhhmmmm..
Hhhmmm.....
Still not ringing a bell
Ah Ha! Now the wheels are turning...
Old 09-25-2011, 05:54 PM   #16
scottie
scottie's Avatar
And it begins....
Old 09-29-2011, 01:03 PM   #17
scottie
scottie's Avatar
So you want Origin Doors for your S13? There is some work involved. It seems like this is one of the hardest subjects to locate information & pics on. Enjoy.
Old 09-29-2011, 02:07 PM   #18
scottie
scottie's Avatar
Floor pan cut, sectioned and sealed to get my seat as low as possible.
Old 09-29-2011, 07:53 PM   #19
CLM_s13Type-x
CLM_s13Type-x is an unknown quantity at this point
Awesome build man! Keep the updates coming!
CLM_s13Type-x is offline   Reply With Quote
Old 09-30-2011, 09:47 AM   #20
scottie
scottie's Avatar
Car still weighs too much...
Old 10-03-2011, 07:00 AM   #21
scottie
scottie's Avatar
Old 10-03-2011, 11:38 AM   #22
CamryOnBronze
Wow! This is going to be one awesome car!
CamryOnBronze.com
Old 10-03-2011, 01:53 PM   #23
scottie
scottie's Avatar
Thanks for the kind words. If you approve I must be on the right track cuz your car is super clean. One of the few hatches (actually only 3) that I really like/ would own.
Old 10-04-2011, 06:21 AM   #24
scottie
scottie's Avatar
Hard to resist good head(s)
Old 10-05-2011, 06:25 AM   #25
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Wow, really impressed with all the quality work, parts, and the fact you do everything yourself. Mad props man.
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 10-05-2011, 09:24 AM   #26
scottie
scottie's Avatar
Thanks man!
I am going to try this whole fuel cell thing one last time. This one is approved by FIA, NHRA, NASA and pretty much any other racing body.
Big THANKS to Jeremiah for suggesting the Aluminum version. Saves 13lbs over steel and looks pretty cool. It has an internal sump with 3 check valves to ensure pickup always has fuel to the last drop. The leveler is calibrated for GM type output and remote filler neck can be clocked any direction.
Old 10-06-2011, 01:54 AM   #27
scottie
scottie's Avatar
Comp Tru Union pressed into GM rockers ready to go.
LS2 (left) vs LS7 (right) Lifter. Notice how the bearing is better enclosed on the LS7?
Cam/Chain/Pump
Old 10-06-2011, 09:04 AM   #28
CamryOnBronze
So nice dude!
CamryOnBronze.com
Old 10-07-2011, 12:51 AM   #29
scottie
scottie's Avatar
So nice dude!
I should have never made the call to SPL........
Old 10-07-2011, 07:53 AM   #30
CamryOnBronze
It just keeps getting better, haha. SPL stuff is so nice- I'm a believer now for sure, haha.
CamryOnBronze.com
