Old 06-04-2013, 11:15 PM   #1
1nasty240sx
1nasty240sx is an unknown quantity at this point
s13 Need Help s13 silvia gauge cluster install
So I have a 91 240sx which has the dohc gauge cluster. I am switching from hud/digital to a silvia s13 analog gauge cluster. My question is if I get a dohc cluster wiring harness will it work with my s13 analog silvia cluster? The Silvia cluster came with wiring should I use that or buy a analog wiring harness? Anyone that has done this can you lead me to the right direction as I do not feel like splicing my original harness to fit the silvia gauge cluster.
1nasty240sx is offline   Reply With Quote
Old 06-05-2013, 05:47 AM   #2
So Make Like
So Make Like's Avatar
So Make Like is an unknown quantity at this point
the hud/digital cluster uses a different sub-harness than the analog cluster. if you want to use an analog cluster, you will need the appropriate sub-harness.
So Make Like is offline   Reply With Quote
Old 06-05-2013, 10:31 AM   #3
1nasty240sx
thanks that is all I needed to know!
