Old 03-25-2017, 10:23 PM   #1
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Z32 BMC flare fitting
Hi there, I'm doing the z32 BMC on my s13 with z32 brakes, but I'm not sure on where to get the middle flare fitting. Does anyone know? I already tried cutting them out of my stock one and it didn't work. Thanks!
nisileighty is offline   Reply With Quote
Old 03-26-2017, 12:52 AM   #2
SR20PWRALTY
SR20PWRALTY is an unknown quantity at this point
I actually stick a hex key into the fitting and wiggle it out.
SR20PWRALTY is offline   Reply With Quote
Old 03-26-2017, 06:17 AM   #3
jdl1527
jdl1527 is an unknown quantity at this point
I'm going through the same swap as you right now, when you say that you tried cutting out the old one, but it did not work, what do you mean?
Sent from my Nexus 6P using Tapatalk
jdl1527 is offline   Reply With Quote
Old 03-26-2017, 11:30 AM   #4
nisileighty
When I was cutting it the Dremel went too far and nicked the fitting causing it to not create a proper seal
Old 03-26-2017, 01:11 PM   #5
jdl1527
Ah, a better way would be to use the dremel to cut access behind the fitting and then use a punch or drill bit to hammer it out
Old 03-26-2017, 02:23 PM   #6
nisileighty
Right, realize that now lol. Do you know of anywhere you can buy those fittings?
Old 03-26-2017, 04:46 PM   #7
jdl1527
No, looked long and hard, your old BMC should have 3. If not, like I said I'm going through the same thing, I can send you one once I get mine out.
Old 03-26-2017, 08:00 PM   #8
nisileighty
You'd be a life saver man. I'll float you a few bucks if you could mail me a few. Go ahead and shoot me a text at 206 566 9749. Thanks!
Old 03-26-2017, 10:40 PM   #9
SR20PWRALTY
Grab a hex tool or "L" wrench that fits in the fitting whole and wiggle it out from your old BMC. There no need to use a Dremel.
