Old 11-05-2012, 01:49 PM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
Turbo2nr's 600hp Street Car build (Vmount/wiggins/custom fab )
So i can finally say im back ! so a little history.
had my last red s14 for about 5years,
I loved this car to death , it wasn't anything too crazy, kouki, ka-t, standalone, suspension,rims brakes blah blah blah.. it was awesome tho..
then in November of 2010 tragedy hit, my car was involved in an accident,
sadly i could not fix her, strut tower was shifted in almost 3".. i had to part her out..
then i dont know what got into me (probably the influence of ex girlfriends..) i decided i will grow up and get a BMW.. i then bought this 4dr 335i 6mt
pretty nice car.. i did usually bmw d-bag stuff, angles eyes, chip/downpipes/intakes.. car was pretty quick but no fun.. I missed the s14 .. Every time i saw one my hear ached.. i went to cali and came back with a clear head and decided its time to sell the bmw..
Just so happened i decided to look for s14 again and i found one.. in long island.. red.. kouki.. ka-t, just like my old car.. it was set i need it!
so finally got the bmw sold! Now im back..
everyone meet Renee
goal for this build : modern day race car in 90 era car.
first set of mods are:
kouki tail lights
fortune auto 500 coilovers
rear multi link arms
re-barrel rims.
__________________________________________________ ________
goal with this motor is around 600whp if it blow ( which i dont think it will) 2jz is up next.
specs on the car:
Engine
96 original KA24DE
Bored and plate-honed block
8.8:1 Weisco forged pistons with Weisco file-fit rings
Crower forged rods and rod bolts
Clevite main and rod bearings
Micropolished and balanced crankshaft
Ported head
Cometic Headgasket
ARP Head Studs
ARP Main studs
Koyo radiator
Flex a Lite Fans
relocated battery
Turbo:
Garrett GT35R CHRA, ATP .70AR ported comp housing, ATP .82 turbine housing
ETD turbo mani, wrapped, along with downpipe
Tial 38/40mm wastegate
Oil feed components are custom lines, Function7 flanges, and a Tuner Toys tee.
Brand new stainless steel braided water lines to the turbo
HKS Super Sequential BOV
Fmax FMIC and chromed piping
Apexi Dual N1 Exhuast
Apexi AVCR
Apexi SAFC
new NGK 8mm plug wires and NGK iridium plugs
Fuel:
Nismo 740cc sidefeed injectors
HKS FCON -V
HKS AFK
255 in tank
Transmission:
Competition clutch twin disk
1pc alumium drive shaft
j30 vlsd
Steel braided slave cylinder line
B&M Short throw shifter
Filled with Redline MT90
Front end:
'98 front end, OEM red
NEW kouki headlights
kouki lower front lip
JDM kouki grill
Suspension:
Tein S-tech springs
Tein tie rods
Moog ball joints
Whiteline FLCA bushings
Whiteline tension rod bushings
Energy Suspension swaybar bushings
Greg Dupree subframe spacers
Brakes:
Full 300zx front brake conversion, PDM lines, slotted and x-drilled Brembo rotors
Wheels:
old school Work VSs, powdercoated glossy black
New BFG KDW DRs on the rear.
Nitto 555s on the front
car made 366whp @ 356 ft/lb when previous owner dynoed on 14psi, also did a 12.6@115mph ( shifting really easy not launching)
With that being said, for summer im focusing on looks and suspension. I just swapped out the zenki tail lights for kouki tail. I plan on ordering Fortune auto coilovers this week.
I'm debating on which company to use for suspension arms, im between powered by max/spl/fortune auto.. i will defiantly order those soon.
then im going to rebarrel the rims: right now the vs-mx's are :
18x8 +34 (1.5" lip/ 18x9 +38 (2" lip),
going to get some 3"/4" lips new size and offsets will be:
18X10 +8 245/35 and 18X11 +17 265/35.
that should hold me down until next year when i get the real rims i want.
i also plan to re tune the fcon and raise the boost up a little, i just want around ~420whp for the summer.
ill keep this build active as i get parts in and progress is made.
Small ricer update!
Installed led corner bulbs and led cluster bulbs
all bulbs are from super bright leds.com
the corner bulbs are the 16x led 194 bulb,
194 LED Bulb - 15 SMD LED Wedge Base Tower | LED Landscape Lighting | Super Bright LEDs
Cluster bulbs were the 9 led bulbs
194 LED Bulb - 9 SMD LED Wedge Base Tower | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
made a huge difference. With the led their is a spot in the cluster that is washed out, i have to find a way to fix this as it bothers me to death!
stock cluster
new bulb vs old
new sexiness
[IMG][/IMG]
these should go really nice with the defi i cant wait to install it!
Also did an oil change as well , the oil was very dark and low, glad i changed it before beating on the car.
Plans for this week:
- install HID 6000k
- install new bumper
- start defi gauge setup
- order new ac trim ( im a clutz and broke the other one at tarmac fail..)
- order new shift knob
- order barrel for rims
hopefully ill have a better update next week
builds picking up!
Getting real..
Gotta love impulse buys!
and let the fun times begin, ok ok ill stop slacking and hopefully give a good pic update this weekend.
i didnt do much but install the dmax corners but it looks like poop because i need to change my peeling headlight housing :/ ill be doing so this weekend, and possible fender harness tuck and defi install =0
ok mini update, i got it my coils and ruca, so install this week .. i really didnt want to start anything major with the car this weekend as i really wanted to driver her..
so i did ricer things.. i finally got around to installing my hids
also my head light housing was fading so i baked them open and swapped out the housing to nice shiny ones i had laying around..
i also cleaned up the engine bay and i drove her around ..
how she looks as of now before the big changes:
cool pic:
some inspiration: Jack from JDM Engine depot s14
now while driving around sat night, "testing" the car i seen that my tune has some issues...
after a good beating session on the high way with a evox and 370z my car was running super rich 9.8-10.5 off boost, it was struggling to idle and wanted to flood out. Below 50% throttle it would be way to rich, and the wide band would be just toggling between 9.8- 11.5 randomly..
as i stop beating on the car and drove it normal, it began to act normal again, it stopped stalling out when coming to stop and clutch in.. the a/f returned to 12.7-13.5 lo throttle cursing speeds.
the lower drive ability part of my maps sucks! i can see that it needs a retune. So it looks like after this round of mod, im going to have to bite the bullet start the fuel system and cams, and go for a re tune.. goal - 500-550whp...
update coils are in!
i will go lower once i re lip my rims and get the fenders pulled..
pics of install done @ TARMAC SPL - thanks D!
old vs new
D putting in work
also did pbm ruca
all done!
driving impressions-
Dampening was set 18 clicks form soft all around. I did the full stiff -> full soft as recommended before final adjustment of Damper.
Living in NYC and having experience in a s14 with harsh coils I was nervous in the beginning.. My first impression when driving down the block away from the shop was “wow these feel almost like the tien springs/stock strut combo” they felt more firm and responsive. Taking some dips on the road at fairly low speeds and the car remained stable, it wasn’t bouncy at all. The coils rebounded pretty quickly at local driving speeds ~15-30pmh. Compared to other coilovers they would get pretty bouncy at those speeds on wavy pavement. The joints/cracks in the road I didn’t notice them! That was a huge huge surprise to me. I was so happy that the coils rode so comfortable on local streets. I did purposely go over a few pot holes to see how harsh it was compared to the spring and struts combo. To my surprise it wasn’t that bad. It wasn’t as forgiving as a spring and strut but it didn’t make my back hurt over the bump either.. But needless to say I will be avoiding all pot holes..
On to Highway impressions-
My commute from the shop to my home is around 30miles, nyc high ways are unforgiving, pot holes, uneven pavement, cracks, un level areas that look and feel like some one put a speed bump on the high way for no apparent reason -__-
Cursing around 60mph the car is super responsive, lane change and weaving left to right is super responsive, as soon as I turn the wheel the car moves. It doesn’t lean it just goes with out delay. The ride isn’t bouncy at all. Its not to firm as in low speed testing, it rebounds nicely over uneven pavement. Driving around 60-70mph I didn’t feel the joints in the high way, it felt good not to have the car twitch over every line. I did slightly feel when the asphalt met cement and back to asphalt. But its nothing to complain about, Fortune Auto coilovers are way more forgiving then other coilvovers. The swift springs make the car feel soo composed, honestly it felt stable like my 07 335i on the high way, a nice comfortable ride and handle nicely, its very composed the car isn’t all over the road and it doesn’t tend to pull into the crown of the road like some overly stiff coilovers. The response is crazy, my last s14 had full suspension and arms spl outer tie rods/tension rods/ full rear arms, sub frame bushing ect. And in response this new car feels like this car with just coilovers! Amazing. Fortune auto did a great job with the Digressive valving on this coil.
My only only compliant was that over a big bump on the high way the coilover rebounded pretty hard, but It is expected as they are coilovers.. and the other negative would be on extremely low speed less then 10mph on a wavy piece of road the coils do feel a little bouncy but nothing that is to harsh. Again they are coilover and it’s the nature of them.
Over all im super satisfied with the coilovers and picking Fortune auto, Terry was a big help throughout the whole process of matching spring rate s and taking time to explain to me how the coilovers worked. He predicted them to be just like how they are! The swift springs are amazing defiantly worth the money. Even Damium was surprised at how well these coils rode in comparison to all the other coils hes tired.
I will keep updating this thread as I get more seat time with the coilover and also how it stands up over time. Right now the ride height is 25” from the floor to fender arch. I will be lowering it soo to around 23”. I will give another assessment of the car at that height to compare it at a lower setting. Also I will adjust the dampening to a softer and harder setting to see the difference.
Over all id recommend these coils, its super comfortable, firm and sporty when it needs to be and it fits on the car perfectly.
Thanks to Fortune Auto and terry for the FA510, and thanks to Damium at Tarmac for the install and all the help with adjusting and dialing in the coilovers.
tested fitted my zeta.. unfortunately i have the wrong rail -__-
fixed my gauge cluster.. one of my bulbs wasnt lighting up
looks so much nicer!
gauge set up almost complete
zeta goes in this week once my rails come..
also my navan rear valance should also be here and my lips for the rims should finally come in! next few weeks is going to be good!
Put in some "work" today
A little preview, still need to clean up barrels and polish faces and clean bolts.. but you get the basic idea..
little teaser..
rear set 18x11+12
got some pulling ahead of me :rock:
i can see it coming together..
yes i know moar low! getting my fenders pulled and lowering the car another 1" this week and installing my jdm bumper. Should look decent soon.
btw federal ss595 run big, a 235 isnt even stretched on a 9.5 and a 265 no stretch on a 11" wtf?? i guess now i have to go for the meaty look :/
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 11-08-2012, 10:28 AM   #2
turbo2nr
turbo2nr's Avatar
Some more updates!
Ride height achieved..
Big thanks for TARMAC SPL for the fender pull + height
pretty big difference
havent done much yet, whats next on the list:
- put on center caps
-pbm toe arms
-alignment
-aerocatch hood pins
-glossy red vinyl wrap hood
-fix lip/ wrap in vinyl for added strength
-swap out kouki sides for gp sports sides
-wingless
-turn up boost to around 20psi
car needs moar power now, im going to have to start buying the rest of the stuff for motor..
alex being my super hot greek wheel model <3 <3
So i finally got the center caps on wheels look 10x nicer now:
also discovered why my car feels slower, Watergate gasket is leaking -__- now comes the fun times of replacing it ..
also purchased some items heres a preview :
before:
After
gp sports side and my greddy lip, i also have the gp sports rear bumper and front bumper, its should look familiar as its from a members build on here ;-)
now to save up for some paint.
minor update
so cars running ok, i have a exhaust leak on the turbo side which i cant find -__-
also from being low i have a hole in my flex section in my downpipe, and my wire harness was getting chewed through (even after tucking it away) looks like i have to notch the chassis next..
still waiting for paint and i need to find N1 ducts for the kouki bumper. I also removed my spoiler so im wingless now.
so as for now ive just been driving it..
pics because everyone loves pics..
playing around with my broken greddy lip.. soon to be fixed
s14 kouki ka-t
Old 11-08-2012, 10:29 AM   #3
turbo2nr
turbo2nr's Avatar
update
this weekend i spent some time fixing and finding issues with the car..
things replaced:
oil
spark plugs
coolant temp sensor
tps sensor
Also i had D from TARMAC help me out, he found out that on my fcon harness i had a broken tps wire, which was causing my tps sensor to jump around. so we fixed that thinking it would help my running rich issue..
so after all that the car was still idling at 9.7:1 , it would stumble around 2-2700rpms, but after that it would be ok, driving a little better 11.9-12.5.
on boost the car runs good, 11.5-10.8 no hesitation or flat spots.
as i drove the car for a little i did notice drive ability get better .. which leads me to believe that the fcon has some kind of adaptive learning but im not sure. It still doesn't run 100% tho but the flat spot went away.
then we thought it may be a bad o2 sensor on the wideband causing it to run like crap. so we swapped out my wide band o2 for a good working one and still the same
while going through all this i did find out that my wastegate gasket is burnt and needs to be replaced and has a slight leak, also my turbo seems to be a tad bit loose on the manifold but not enough to cause a leak ( or at least i think not) but i dont think a exhaust leak pre turbo can cause such a big difference in a/f readings..
the other weird thing is that when i changed my plugs they were fouled, i put new ones in and drove around with it reading "rich" but when i looks at the plugs/o2 sensor after putting them in they did not have any black residue on it to indicate it running extremely rich. idk im stumped..|
im going to fix the exhaust gaskets/leaks and transmission and see if any thing changes.. if not then im going to take the car to the tuner and have he re program the fcon..
at a meet with tarmac
i also need to put my damm aero on..
Finally some good progress
went to good ol Tarmac to do some work.. goal today was to fix transmission and exhaust leak.
started off by pulling off the exhaust, i had more leaks then a sinking ship, exhaust was loose in 2 places, down pipe was loose in 2 places, wastegate re-circulation tube was also loose/broken. pulled all that off.
transmission came out no issues tho.. i didnt take much pics but heres one of my twin disk chilling.. its sooo cute
while trying to tighten the wastegate we came to see that all four bolts on my turbo was loose as well.. we proceeded to tighten those as well.
while fixing the exhaust leaks, we decided no more re-circulation open dump ftw. I forgot how good that sounds.. slapped every thing back together and the car runs like a champ and i have reverse! :mysmilie_1725::mysmilie_1528gif:
now since all the hard stuff was done time for the fun stuff ... finally got around to installing my nismo N1 vents
making the whole
test fitting first vent
these things fit soo tight , we had to remover the front bumper so that we can get them to snap into the front bumper..
me and oder comparing aero
all done!
all in all a very productive 15hrs of wrenching
next up car goes to the body shop on Monday for make over:borat:
oh the problem with the car running like crap kinda fixed it self, we figured out that i had a broken tps wire on my f-con harness, we fixed that and once i drove the car around for a bit it started to re-learn the bottom end of the tune. guess the F-CON has some kind of self learning idk.. also i disconnected my map sensor and blew it out , it had some white powder oxidation on it. As of now the car is running good
ver.3 coming soon
s14 kouki ka-t
Old 11-08-2012, 10:29 AM   #4
turbo2nr
turbo2nr's Avatar
vr.3
at petrolwerks meet with tmspl
hood and vents going back for paint , body shop didnt have time to get it done.
it was awesome to cruise around with everyone
BAM!
-hood stays carbon, to much work to get it to look good in red and i think it gives me some street credit lol
wheels are sold new wheels soon.. it never ends -_________-
some pics from this weekend
so no real progress , still waiting on wheels got delayed now we are looking end of october -__-
mean time ive been buying parts so far i have
pbm toe
drift freak mounts
z32 rear brake setup
which i will be installing soon..
but in other news over the winter im changing my whole turbo/fuel setup so this should be interesting.. ill update soon as new go fast goodies come in
also my current turbo setup will be for sale soon if anyone is interested:
jgs manifold
38mm wastegate
atp 3582r
3" downpipe/dumpipe
intake pipe
basically whole turbo side..
parts starting to roll in, also got the aem and downpipe but i didnt get to snap a pic of it..
need to get:
1.06 divided housing for 35r
tial 44mm wastegate
tial bov
bigger intercooler
start fuel system
i finally got off my lazy ass this weekend despite working 7days and put in some work.
had a buddy come over and started to rip the engine bay apart.
so the full race mani is hitting the bolt for the power steering resv. looks like i need to unbolt it and it should slip on. i still need to change my exhaust gaskets tho.
i should be sending my turbo out this week hopefully to get upgraded and my new tial mv-r should be coming in today woot!
i have some surprise baller parts coming in next week
s14 kouki ka-t
Old 11-08-2012, 10:31 AM   #5
turbo2nr
turbo2nr's Avatar
So before i sent the turbo out for a upgrade i took some test fit pics
Pure Turbos - a vendor here is hooking me up with a 82mm billet wheel and a 1.06 divided t3 back housing , Cant wait until i get this back!
also picked up some parts:
new tial 44mm mv-r
aem 5 bar
id2000cc
and custom intake manifold .
while i had the turbo off i figure i put some heat foil down
before
after
this dei self adhesive heat foil is pretty good.
more updates as parts continue to come in/back
s14 kouki ka-t
Old 11-08-2012, 11:26 AM   #6
babyjesus
babyjesus's Avatar
babyjesus is an unknown quantity at this point
dang, this build is rad man! keep it up
thelittlebigblock.blogspot.com
babyjesus is offline   Reply With Quote
Old 11-08-2012, 12:41 PM   #7
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Made $$$$ spent
Great looking car
Old 11-08-2012, 06:47 PM   #8
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
Looking good,
Pinggg is offline   Reply With Quote
Old 11-08-2012, 07:07 PM   #9
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Great looking car, great looking build, keep it up
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 11-08-2012, 08:57 PM   #10
sex14
sex14 is an unknown quantity at this point
man ive been looking for a zeta 2, where did u find yours just curious are those an authentic piece?
sex14 is offline   Reply With Quote
Old 11-08-2012, 09:07 PM   #11
HyperTek
When i saw the white vents installed, i was thinking "ohh man i dont know if i will like this..".. but than i saw them painted and they look awesome.
Nice story and build!
Keep it Classy
Old 11-09-2012, 07:06 AM   #12
turbo2nr
turbo2nr's Avatar
its actually a zeta 1, i got it used from a local guy, later i plan on getting red zeta 2 tho.
haha i was on the wall with the nismo n1 vents on a s14, but it turned out well, the greddy lip ties it all together.
now the slow process of waiting for parts to come back beings.
btw end of the month i should have some nice new wheels if works ever decided to ship them lol
s14 kouki ka-t
Old 11-09-2012, 10:09 AM   #13
blo0d
blo0d is an unknown quantity at this point
this build is what the fuck im talking about! perfect balance of power, handling, exterior, interior and stopping upgrades... true daily status earned!
blo0d is offline   Reply With Quote
Old 11-09-2012, 11:55 AM   #14
WholeGrainS13
WholeGrainS13 is an unknown quantity at this point
damn nice car man. build looks good. looks like youre missing some cams though. i have a set of brand new kelford 213-c's if youd be interested. should help getting to 600 easy
WholeGrainS13 is offline   Reply With Quote
Old 11-09-2012, 12:29 PM   #15
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Good shit Drew!
2muchboost is offline   Reply With Quote
Old 11-09-2012, 12:55 PM   #16
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Could u post a upclose shot of those welded in injector grommets...I'm doing the same thing and i turned off 4 new aluminum grommets from round stock today and im just trying to get a general idea of how they will sit....actually thinking about starting to fab them to what ever size/style bottom people need so they can use the various top feeds...just weld them in and go
Memberofthe600hpkaclub is offline   Reply With Quote
Old 11-09-2012, 03:07 PM   #17
s14tan
s14tan's Avatar
s14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choices
Good stuff man.
Glad you came back!
s14tan is offline   Reply With Quote
Old 11-09-2012, 03:20 PM   #18
Weedm
Weedm's Avatar
Weedm is an unknown quantity at this point
i agree with your decisions.
Weedm is offline   Reply With Quote
Old 11-09-2012, 09:14 PM   #19
RastaS14
RastaS14's Avatar
RastaS14 is an unknown quantity at this point
Very nice S14K build. Post vids of the car in action once the new setup is complete!
RastaS14 is offline   Reply With Quote
Old 11-10-2012, 08:03 AM   #20
turbo2nr
turbo2nr's Avatar
seems like the builder just built up the area with weld.
it worked fine for him and the previous owner tho. also the orginal builder of this manifold picked up 30whp on the same psi. so im really looking foward to install this asap.
pretty nice job on the inside of the plenum as well
now i just need my damm injectors and turbo to come back and i can start puttng it all together.
btw anyone know a good s.s. power steering line conversion kit. with the full race mani on, it sits right up to the p.s. rubber line.
my pump looks like this
i need one that comes out in a 45deg angle like this
where can i get that piece??
s14 kouki ka-t
Old 11-10-2012, 10:49 AM   #21
drscooper
drscooper is an unknown quantity at this point
man this sexy bitch has some meat on here! just how l love my women! lol
great build man cant wait for more!
drscooper is offline   Reply With Quote
Old 11-10-2012, 08:28 PM   #22
Yeah I got.his other manifold actually...and yes they are super awesome...I had some round stock turned down to.the perfect size and basically replicate the oem injector isolator...ill be selling them for 50...and.that's material and shipping cost only...and ill even drill to what ever size bottoms you have lol...always made me mad that damn big doughnut
Old 11-12-2012, 08:00 PM   #23
bigyellowevo
bigyellowevo is an unknown quantity at this point
Great Build.
bigyellowevo is offline   Reply With Quote
Old 11-29-2012, 08:27 PM   #24
turbo2nr
turbo2nr's Avatar
FINALLY!! IT CAME BACK!
gtx3582r upgraded:
82mm billet wheel
ported comp housing
polished comp housing
divided 1.06 t3 turbine housing
i cant wait to get this sucker on the car. i got to wait for the mani to come back from thermal coating
s14 kouki ka-t
Old 11-29-2012, 08:44 PM   #25
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Turbo looks good!
Old 12-13-2012, 07:22 AM   #26
turbo2nr
turbo2nr's Avatar
fuel lines came in
-8 feed
-6 return
in line fuel filter
new fpr
id2000 should be back today =)
expect a big update this weekend
s14 kouki ka-t
Old 12-13-2012, 08:04 AM   #27
future
future's Avatar
Trader Rating: (42)
We shall be waiting
Old 12-14-2012, 06:57 AM   #28
turbo2nr
turbo2nr's Avatar
rest of the parts are back
i.d. 2000
full race mani back from ceramic coating
i should have the turbo side assembled this weekend, then the car is off to Tarmac SPL for the fuel setup along with a few custom parts.
stay tuned things starting to pick up!
s14 kouki ka-t
Old 12-14-2012, 07:39 AM   #29
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
That manifold is B-E-A-UTIFUL!!
scottie is offline   Reply With Quote
Old 12-14-2012, 07:41 AM   #30
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
Holy nutsack batman! that turbo!
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
