06-11-2015, 02:32 PM | #1 |
FS- rb20det s14 Kouki front
For sale is my 1995 Nissan 240sx.
It has an RB20DET all stock. Has: -wiring specialties wiring harness -new oem Nissan head gasket -new oem Nissan head bolts -new oem Nissan oil pump -new oem Nissan timing belt -new oem Nissan timing belt tensioner -all new oem Nissan gaskets -stock t28 turbo -front mount intercooler -greddy blow off valve -greddy wideband -greddy electronic boost gauge -drop springs -aftermarket rear sway bar -5 lug conversion -z32 front calipers and rotors -xxr 526 wheels 18x10.5 all around -bmagic 30mm front fenders -Kouki front end -oem USDM front lip -oem Jdm side skirts -oem jdm rear bumper -forcewerks jdm rear valance replicas -Kouki rear wing Bads: -Shocks are blown and need to be replaced -dash is cracked -speedo doesn't work -iacv is bad/needs to be replaced Lmk. Car is in good conditions, just had a paint job and tires are decent. Except for the rear 😈 interior is 8/10 and exterior is 9.5/10. I have a new carpet I will throw in also. I also have some adjustable cam gears to throw in which I never installed. Car could use a better cooling setup, ie-fan/vents, as it tends to get a little hot during the summer. Then again it's over 100degrees here so yeah. I'm sure I'm forgetting some things but should be enough info. $8,900 Obo. Not looking to trade. 9one5-276-2449 |
