Old 12-03-2017, 06:05 PM   #1
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
boost leak?
So i am having this issue with my sr20 where it only makes around 1 or 2 pounds of boost at around 4000 rpm and i was wondering if its because i have a boost leak. ill link the video im also curious if a boost leak would have the same effect as a vacuum leak meaning it sounds cammed when the engine is warm
https://youtu.be/hLVBrDx3DwU
oLemurs is offline   Reply With Quote
Old 12-03-2017, 06:23 PM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Your boost gauge is hooked up pre-throttle body so you should change that so you can get a vacuum reading with the throttle plate closed.
Your car isn't going to make boost just free-revving.
Old 12-03-2017, 07:09 PM   #3
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
You are only running about 10inHg on vaccum, should be more like 20-22. I would definitely say you have a boost leak.
- you arent going to make any boost sitting idle, gotta drive it to do that.
- Is your MAF setup draw through or blowthrough?
- are you familiar with how to do a boost leak test?
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 12-03-2017, 08:54 PM   #4
oLemurs
oLemurs's Avatar
im not sure if it is draw thgough or blow through, but here is what the intake looks like. i do not have the supplies to do a boost leak test yet but i should probably buy them
https://imgur.com/gallery/Zg2Y5
Old 12-03-2017, 09:11 PM   #5
oLemurs
oLemurs's Avatar
i hooked it up to where the egr was, also thanks for letting me know it wont make boost out of gear
Old 12-03-2017, 09:50 PM   #6
unicoder
unicoder's Avatar
It's draw through, since your MAF is before the turbo.
Always start with the boost leak test, it will save you hours of headaches
Old 12-03-2017, 10:37 PM   #7
oLemurs
oLemurs's Avatar
got it, just ordered a bunch of stuff for the test
Old 12-05-2017, 05:47 AM   #8
cotbu
cotbu's Avatar
No boost with no load unless you have launch control / antilag
Sent from my LG-H631 using Tapatalk
