05-08-2016, 04:10 PM | #15 |
What size injectors? How many miles is on the motor? I see it's only on 10lbs. Do you have a tune for higher boost? Does it have an oil leak? Does it smoke?
-Moderation |
05-08-2016, 06:00 PM | #20 |
that turbo is only good for 380~ rwhp it has nothing to do with the engine.
Word of advice: the bottle looks like it sits directly on the paint, scratching it up. I dont know how good the quality of the paint in the bay is (you did not mention it) but that alone makes me think its not so good. Another tip, its very cheap/easy to remove that sticker from the fuse box and put something cleaner looking on it (will help immensely with the image of the car's bay). If you "need" to keep using that liquor bottle, I would at least show a shirt under it protecting the paint. I'd like to see a dyno graph only for the sake of comparing that high mount you have, it probably spools 300~rpm sooner than the typical front mount setup with the same turbo. Difficult to set that up, it adds alot of value to the swap, I would be promoting that with a big fat dynojet graph showing how good the engine spools. |
05-08-2016, 06:13 PM | #21 | |
As for the turbo debacle, previous set up was a GT35R. Sorry for the confusion. Hope all is well. Cheers! |
