08-31-2011, 11:52 AM | #1 |
5 speed v8 SC ! "Kit,I'forged 19"s,suspension and more"
Specs
1992 SC400 with 112k original miles Black on Tan. 1UZ-FE (V8) Supra R154 trans had 78k miles when pulled from the car "I just replaced the last one due to a few bad synchros. S-AFC (tuned) Custom equal volume long extractor headers (Rush AU) Carsound cats, x-pipe, flowmaster mufflers Walbro 255LPH high pressure fuel pump 1.5 way LSD from 94Supra N/A with 4.27 gearing Custom one-piece driveshaft Suspension: 8-point full roll cage Daizen Front Control arm bushings Daizen Rear Control arm bushings Daizen Front and Rear Sway bars Daizen front and rear sway bar bushings TEIN HA coilover system Daizen rear camber control kit Exterior: Just got it out of the body shop, the car has zero dings or scratches. door cards Origin front bumper Origin rear bumper Vertex rear spoiler HID low and highbeams V-speed side skirts Painted Carbon Fiber Hood with hood pins Interior: Cage "unpainted but prepped n ready for paint" 98 Supra TT front leather seats Clarion 2din CD/MD player "have single din setup,waiting for some time to put it in" Custom Laser blue dash needles(by lextech lighting). Nakamichi factory system replaced climate control lights with 97+ scheme optional cupholder added Rollers and Stoppers: I-forged 19x8.5F 19x10R "need to be refinished or powdercoated" Tires = 245/35/19F 275/30/19R Supra TT front brake upgrade with cross drilled rotors (Brand new) Lexus SC brakes rear (Brand New) Goodridge SS brake lines (all four corners) Others: A/C system converted to R134 from R12 New Supra spare All Parts new when swapped: CRD custom bellhousing CRD custom flywheel CRD custom ring gear Exedy Clutch Exedy pressure plate Spigot Bush (this is from a turbo MKIII) Throw Out bearing (this is from a turbo MKIII) slave cylinder & push rod (this is from a turbo MKIII) Slave cylinder and bolts (this is from a turbo MKIII) release bearing (this is from a turbo MKIII) pivot ball (this is from a turbo MKIII) (6) M12 x 1.25P x 50 long original Toyota bolts -bellhousing to motor (OEM)CRD supplied (3) M10 x 1.25P x 45 long original Toyotal Bolts - Bellhousing to motor (OEM) CRD MKIII turbo slave cylinder (this is from a turbo MKIII) *R154 transmission from soarer TT (this can be from a turbo MKIII)*MKIV soarer TT tailshaft (this is from a late model MKIV pilot bearing (from a turbo MKIII) Flywheel flex plate bolts (8) M10 x 1.25 pitch x 26 long High Tensile Bolts. (OEM) SC300 clutch pedal 58804-24030-03 SC300 clutch pedal box sub assembly 47101-24060 SC300 brake pedal SC300 brake pedal box sub assembly 31301-24050 SC300 clutch pedal pad 31321-14020 SC300 brake pedal pad 31321-14020 SC300 shifter boot SC300 shift knob SC300 shifter trim bezel (specify with or without heated seat) supra 6speed master cylinder 31410-14310 SC300 hardline for master cyl MKIII turbo hardline for slave cyl Interested in Trades mostly "swapped cars or nice SUV/Truck" but if your interested in a cash deal I'm sure we can work something out. I just put almost 4,500 into the car between paint and body work and another 450 to have the rims straightened out new pads, trans was 400 etc. So please be realistic ! For those that have a hard time with being realistic I'm looking for a trade or offer around 12k Dirty but no leaks or anything. Last edited by TougeLabs; 09-01-2011 at 09:24 PM.. |
09-03-2011, 09:23 AM | #6 |
the guy selling it before you had a harder time lol looks good compared to when he was selling it looks like you dropped some $$$ on fixing the issues, cant believe that guy with the jeep is unsure about trading for this hed be getting a steal
