Old 11-12-2015, 08:33 AM   #1
rickyhaze
rickyhaze is an unknown quantity at this point
1992 Nissan 240SX KA-T with Silvia FRONT END
Year - Make - Model: 1992 Nissan 240SX with Silvia FRONT END
Price: $9,500
Title Type: Clean
Contact: 404-723-0835
I've put a ton of work into this car and used to use it as my daily driver. This thing runs strong and has been VERY dependable for me in whatever I've needed it to do. For example, I had to drive down to Savannah, Ga a coupe times and then drove back to Atlanta with ZERO problems. This also has a PASSING EMISSIONS test, CLEAN TITLE, ZERO RUST and ZERO LEAKS so you are good to go. The Odometer has 255,xxx miles on it but the gauge cluster was replaced along with the dash prior to me buying it. And the engine has been rebuilt as well with ONLY 2,390 miles on the rebuild. I get looks and thumbs up anywhere I go with this thing, it's a real head turner. I'M NOT LOOKING FOR ANY TRADES, JUST CASH.
*Like I said before I used to use this as my daily driver to go back and forth from work, run errands, ect. I have since then got a new vehicle and drive this about once a week. So the miles will not go up very much if at all. Everything runs great just keeping the miles low and garage kept for right now.
ENGINE:
-KA24DE-T Running 20psi (Rebuilt engine with only 2,390 miles)*
-Biagio external wastegate turbo (Rebuilt with 2,390 miles)*
-TIAL adjustable wastegate
-Blitz blow off valve
-PWR Intercooler
-ARP head studs
-New Cometic Street Pro steel head gasket
-Forged pistons
-Forged rods
-Forged crank
-JGY fuel rail & injectors
-Stock head, cam, valves & springs
-Stock intake & throttle body
-NGK R5671A-7 spark plugs
-Heavy Duty MSD spark plug wires
-New water pump & thermostat
-New Aluminum coolant tank
-Power steering cooler
-Mishimoto radiator
-New belts
-Re-sealed front cover & oil pan
-MSD blaster2 coil
-New Optima Yellow top battery (Relocated to the trunk)
-Megasquirt MS2 stand alone ECU (With an excellent tune on it currently)
-Polyurethane motor mounts
DRIVETRAIN:
-JGY light weight flywheel (Resurfaced)
-New ACT NX4-HDR6 clutch (2,390 miles on it)*
-SR20 transmission w/ Amsoil (43,xxx miles with fresh fluid since the engine rebuild)
-New Megan Racing short throw
-Limited slip diff w/ Amsoil (Fresh fluid since the engine rebuild)
-Polyurethane transmission mount
WHEELS AND TIRES:
-Continental Extreme Contact DW tires (2,390 miles)*
>235/45R17 Front
>255/40R17 Rear
-XXR 535 wheels (2,390 miles)*
>17x8.25 Front
>17x9.5 Rear
SUSPENTION:
-Nissan Sumitomo 4-piston front calipers
-Oversized rear rotors
-Sportline 85173 springs
-Adjustable struts
-Adjustable front tension rods
-Adjustable rear upper control arms
-Adjustable rear toe rods
ADDITIONAL GOODIES:
-Silvia front end
-Silvia S15 steering wheel
-Silvia S15 Shift Knob
-S14 seats
-Power window conversion
-Custom exhaust with electric dump(So you can go open and loud or closed and silent with a push of a button)
-Python 5303P Alarm System
-Smoked tail lights
-Working Power steering
-Working JDM Climate control (A/C went out but tested it and it is only the compressor, so change that out and you'll be good. Heat is hot and works amazing though!)
-Xenon headlights
-Innovate LC-1 air/fuel gauge
-Autometer Gauges:
>voltage
>oil pressure
>oil temp
>fuel pressure
>vac/boost
>pyrometer
rickyhaze is offline   Reply With Quote
Old 11-12-2015, 09:00 AM   #2
boostcreep5150
boostcreep5150 is an unknown quantity at this point
How much power
boostcreep5150 is offline   Reply With Quote
Old 11-12-2015, 09:18 AM   #3
rickyhaze
Originally Posted by boostcreep5150 View Post
How much power
I don't have it dynoed but with current estimates on power would be a little over 300 at the wheels and about 400 at the crank. It's easily good for 125+ hp per cylinder at 28psi on race fuel or E85
Old 11-17-2015, 11:42 AM   #4
rickyhaze
Bump Bump Bump
Old 11-17-2015, 12:31 PM   #5
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
Forged crank? Details?
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 11-19-2015, 08:51 AM   #6
rickyhaze
Sorry, guess I should have clarified, crankshaft is OEM but the OEM cranks are forged.
Old 11-24-2015, 10:35 AM   #7
rickyhaze
Sale Pending
Old 11-25-2015, 04:20 AM   #8
rickyhaze
Car is sold.
