Old 01-07-2019, 12:46 PM   #1
_n3
_n3's Avatar
_n3 is an unknown quantity at this point
RB Nistune, Apexi AVC-R, UEGO Wideband, z32 MAF, z32 rotors, RB25 misc parts...
Shipping everything here USPS generally speaking. Prices are not including shipping+pp fees. Will discount multiple parts.
I have a Nistune setup, and bought parts for that, but decided to go standalone so I don't need the z32 maf, avc-r, and a few other things. o2 housing didn't fit my custom downpipe, so i never used it. Items are used unless stated otherwise.
  • $offer Pair of RED Bride Brix 1.5 with Bride rails (fit S13 driver+passenger)
  • $offer Bride Zeta III with Nagisa rails
  • $400 Z32 ECU with Nistune Type 2 Board
    This is a Z32 ECU, which was reccommended instead of the original RB25DET ECU to be paired with the Nistune Type 2 board. The modifications were made to the board so that you don't have to do them in the wiring, which was just cutting a trace, bridging a connection, and adding a resistor. (Z32 TT has two o2 sensors instead of one that the rb25 has, so it was bridged.) I forget what other modifications were done, but you can check on their site to see, as they have a PDF on how to do it. Board was socketed, and type 2 board was installed by an IPC J-STD-001 certified installer. (Me) Comes with Offbrand "conzult" cable used for interfacing and flashing with it. I've read it isn't the best versus the PLMS cable since it doesn't mitigate noise. Depends on your electrical setup. (https://www.plmsdevelopments.com/ind...consult-cables) Does not come with nistune software license. I was able to debug and crack the nistune software myself and use it. Just the chipped ECU and cable.
  • $60 Z32 MAF with brand new pigtail
    I believe MAF is used but screens are not broken anywhere.
  • $SOLD Apexi AVC-R Electronic Boost Controller
    MORE AVC-R Pics: https://mega.nz/#F!edEBjaba!COX2fTeDeB2m5c1jXlvl4g
    Blue/Silver. Comes with two hardesses. (One I had was chopped up and dirty, so I bought a brand new one, and just extended the connections with new wires. Didn't chop it up.)
  • $150 AEM UEGO 4.9 Wideband. NEW Sealed in box. PN: 30-4110
  • $100 AEM 3-port Boost controller. NEW Sealed in box. PN: AEM-30-2400
    Edit: I just checked and the box seal is broken. I never opened this but since the seal was broken I opened it to check the contents, and the boost controller is still in its bag, which is sealed. Not sure how the actual box seal was broken.
  • $120 Forge Motorsports BPV. (Recirc) Used for <2000 miles
    Model: FMDVK04S - Fits Ford Focus ST, Volvo S60, Volvo V70R, OPC Insignias, Buick Regal Turbos
  • $120 Duralast 24-DLG Battery. Bought a couple years ago, got a free optoma yellowtop, so it's been on the tender inside temperature controlled since then. Very little use. (Local pickup near Cleveland)
  • $SOLD RB25 speed sensor
  • $40 RB25 slave cylinder
  • $100 s13 ISR Performance RB swap o2 housing NEW
  • $80 s13 pop up assemblies including the motors (both sides)
  • $20 s13 inner and outer tie rods. bushings are torn..
  • $20 s13 rear brake assemblies. needs rebuilt.
  • $60 300zx/z32 rotors
    two front rotors. brand new from 88rotors.
  • $40 Jensen VM9410
    Comes with harness. Flip up screen. Backup camera and video inputs. Nice unit. I'm running no radio at all now though. also comes with remote. (not pictured)
  • $20 FTDI OBD2 flash cable NEW This one has a "Trifecta EZ-Flash" sticker branding sticker on it. Same cable as any other FTDI one though.
  • $10 8mm spacers.
'92 240sx
Last edited by _n3; 06-24-2019 at 05:04 PM.. Reason: links to pic changed to emb'd pics
_n3 is offline   Reply With Quote
Old 01-16-2019, 01:12 AM   #2
_n3
_n3's Avatar
bump for gr8 justice
'92 240sx
Old 02-03-2019, 11:31 PM   #3
_n3
_n3's Avatar
'92 240sx
Old 02-15-2019, 09:59 AM   #4
Josh400
Josh400 is an unknown quantity at this point
Do you still have the speed sensor ?
Josh400 is offline   Reply With Quote
Old 05-23-2019, 10:27 PM   #5
_n3
_n3's Avatar
Anything not listed as sold I still have. (Which right now is everything)
Send me a PM if you're still interested.
'92 240sx
Old 06-02-2019, 09:35 PM   #6
dinopjetrovic
dinopjetrovic is an unknown quantity at this point
hey is the Z32 MAF sensor OEM? if so, email me at [email protected] because I'm very rarely on this forum, thanks.
dinopjetrovic is offline   Reply With Quote
Old 06-03-2019, 04:29 PM   #7
_n3
_n3's Avatar
It doesn't have the orange badge on it. If I would guess, it might be the ISIS/ISR one. That or the badge fell off. Do you know of any indicators I can check?
It is pending sale though.
'92 240sx
Old 06-03-2019, 07:37 PM   #8
rfs324
rfs324 is an unknown quantity at this point
Pics of the uego wideband?
rfs324 is offline   Reply With Quote
Old 06-04-2019, 11:26 AM   #9
_n3
_n3's Avatar
It's bnib.
Sent from my PH-1 using Tapatalk
'92 240sx
