Old 02-27-2021, 08:19 PM   #1
DUDEIDONTHAVEA240
DUDEIDONTHAVEA240 is an unknown quantity at this point
1997 240sx se rb25det
SOLD!
1997 Nissan 240sx SE
Clean California Title, registered
(Car is located in San Diego, California)
Original for sale thread can be found here-https://zilvia.net/f/showthread.php?t=637652
Please check out the old thread imgur album. There are 181 images of the car, items, paperwork, etc. https://imgur.com/a/MzADb
The most recent photos of the car https://imgur.com/a/hlqN5Hc
This car came factory with an automatic transmission, power windows, power locks, power mirrors & no sunroof. I have owned the car since 2009,
originally I wanted a fun daily so I converted it to a manual transmission and swapped in a built KA24DET. I drove that for a while, had a throttle
body screw come loose and blow the motor up. My intention was to re-build a stout rb25det and possibly drag race it on the weekends. I am now a proud
father of two girls and and my priorities have shifted hence the reason for selling. The car was posted for sale 4 years ago as a project,
but all of the work has been finished and the car is now a complete running daily driver. Overall the car is in excellent condition and I am in no rush
to sell it. Lowball offers will be ignored. Carfax report (says 6 owners but only 4 total, 2 are just title updates) http://clicks.email.carfax.com/ls/cl...G2wY9H5V0Q7b5i
Feel free to contact me via this listing, phone/text (619)739-3296 or email at [email protected]
SOLD
Motor/Drivetrain:
-RB25DET Series 1 motor w/ RB25 5 speed transmission
-Machine shop work
(Vat clean, block report, crank report, polish, align bore, deck inline, bore and hone, plugs, balance rotating assembly, fit pin + mount piston, machine and install pump drive (Raw Brokerage Crank Collar), resurface and file fit rings) All work done by Car Parts Machine in El Paso TX.
-All new OEM Gaskets
-Cometic head gasket
-Cometic exhaust gasket
-Nissan N1 oil pump
-Nissan N1 water pump
-ACL bearings
-CP Pistons
-Manley Rods
-ARP head studs
-ARP main studs
-Tomei Poncams 256/256
-Tomei adjustable exhaust cam gear
-Stock turbo and manifold
-Greddy intake manifold with Q45 throttle body
-ACT 350z 350mm clutch
-Exedy billet chromoly flywheel
-Zerolift motor mounts/trans mount/ 1 piece steel driveshaft
-Megan racing engine and transmission mounts
-J30 differential
-Stainless BRM exhaust w/ Magnaflow resonator/muffler
-CXRacing turbo elbow
-Redline 75w90 gear oil in the diff and MT-90 in the transmission
-Mobil1 10w40 engine oil
-Carbon fiber front cover (not mounted) and coil pack cover (mounted)
-HKS SSQV BOV
-ISIS short throw shifter
-N60 MAF
-S15 power steering pump
Fuel:
-AEM 50-1200 E85 compatible in tank fuel pump
-Nismo adjustable fuel pressure regulator
- -8 AN Braided Fuel Hose/Feed
- -6 AN Braided Fuel Hose/Return
-Bulk head fittings installed at the fuel tank cap
-Russell Competition 40 Micron Inline fuel filter installed on feed line
-Runs on 91 octane
Electrical:
-Battery relocated to the trunk with the main power running through the interior of the car
-Custom battery box with mounted fused electrical disconnect
-Prosport oil pressure gauge
-Autometer boost gauge
Cooling:
-Koyo aluminum radiator
-Front mount intercooler w/piping
-Arizona Iced Tea over flow tank
-Aluminum reservoir for power steering fluid, AN fittings installed on tank and on steering rack, nylon black braided lines connect everything
-Has all of the AC components including the RB25 a/c pump. I have all the stock s14 compressor lines but they need to be modified to fit. Everything is in a tote and not mounted except the condenser.
Suspension:
-KYB AGX springs and struts
-SPL aluminum subframe collars
Wheels :
-350z wheels (x4)
-Continental Extreme Contact 225/45/17 tires. Still have lots of tread left
Interior :
-95 240sx seats front and rear
-Kenwood KDC138 Headunit
-Nardi Sport Rally Deep Corn 330mm (black with red stitching)
-NRG short hub black
-NRG quick release 2.5 black/black
-Blue bubble shift knob
Exterior:
-Street Faction front bash bar
-Kouki SE lip
Bad:
-Transmission is making a whining noise when clutch is pressed in. Throwout bearing was replaced and all contact points were greased and the noise remains so I am guessing the transmission needs a bearing or something.
-Headlights need adjusting
-Passenger side door is missing the door swing stop
-Struts squeak and need to be replaced or upgrade to coilovers
Not included in sale but can be added:
-PTE 1600cc injectors x6
-Weld Prostar 15x8 (x2) w/ Mickey Thompson ET Streets 26x10.5
DUDEIDONTHAVEA240 is offline   Reply With Quote
Old 03-01-2021, 12:44 PM   #2
Persona
Persona's Avatar
Persona is an unknown quantity at this point
My man! This car is sweet. Sharing your post and listing with some friends who have been looking for a 97 hardtop.
Persona is offline   Reply With Quote
Old 04-19-2021, 09:53 AM   #3
DUDEIDONTHAVEA240
Thank you for the help. It looks like you have yourself a clean kouki as well.
Update for the car: I cleaned out the fuel filter, changed the oil to Mobil1 10w40 and fixed the power steering cap so that it no longer has a leak.
Old 04-23-2021, 07:36 AM   #4
Whitey13
Whitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enough
Can you shoot me the VIN when you get a chance?
Whitey13 is offline   Reply With Quote
Old 05-01-2021, 03:04 PM   #5
DUDEIDONTHAVEA240
Here is the link to the carfax report. http://clicks.email.carfax.com/ls/cl...G2wY9H5V0Q7b5i
Old 06-26-2021, 02:35 PM   #6
DUDEIDONTHAVEA240
Sold
Car is SOLD thank you
Old 06-27-2021, 12:33 AM   #7
serah31500
Trader Rating: (18)
serah31500 is an unknown quantity at this point
Feedback Score: 18 reviews
It’s on Facebook now for 20k lol
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO.
serah31500 is offline   Reply With Quote
Old 06-27-2021, 01:07 AM   #8
mechanicalmoron
Originally Posted by serah31500 View Post
It?s on Facebook now for 20k lol
Too cheap.
Cool cars seem to be solid investments right now.
Old 06-29-2021, 08:33 PM   #9
serah31500
Trader Rating: (18)
Originally Posted by mechanicalmoron View Post
Too cheap.
Indeed it is. People don?t realize what it costs to build a rb properly?I can?t believe this thing sat here unsold for so many years.
