Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 06-08-2015, 07:32 PM   #1
Mega3181
Mega3181 is an unknown quantity at this point
Dirt track setup help
I run an s14 at the local dirt track oval racing. My question is should I weld my diff? Currently has a lsd from factory but in trying to get some more traction to help get the car around the corners.
Also any other set up tips you guys are running.
I'm going to switch the gearing to 4.6. Still messing with tires. And will do a 240/232 cam set up to shoot for more mid range power.
Cars a beast but not winning yet, key to winning is getting around the corner, I can out run everyone on the straights
Mega3181 is offline   Reply With Quote
Old 06-08-2015, 07:44 PM   #2
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
*Cries internally...........
kashira kureijii is offline   Reply With Quote
Old 06-08-2015, 08:01 PM   #3
Ratpack_Chad
Ratpack_Chad's Avatar
Ratpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the rough
This is awesome, do you have any video?
Ratpack_Chad is offline   Reply With Quote
Old 06-08-2015, 08:07 PM   #4
Mega3181
Videos
http://www.youtube.com/playlist?list...a8kre9kCm5GMQX
They are doing a documentary on the race track and following me around the last race, had about 7 cameras on the car but can't share them until they say it's cool
Old 06-08-2015, 08:12 PM   #5
Mega3181
This one was close
http://youtu.be/QrBrGtU0yiU
There was a greasy line in the middle, I found it. Was close to becoming one car, but not a scratch on either
Old 06-08-2015, 08:25 PM   #6
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
You need positive rear stagger. And easy-up front shocks. ALSO stiffen the LR spring 50-75 lbs and soften LF spring 25-50 lbs
JSimpson is offline   Reply With Quote
Old 06-08-2015, 09:41 PM   #7
Mega3181
Spring rates
How do you change the spring rates? They are stock spring?
Old 06-08-2015, 10:23 PM   #8
JSimpson
You get new springs in different rates
Old 06-10-2015, 03:34 AM   #9
newkid99
newkid99 is an unknown quantity at this point
Agreed, are you in second or fourth gear around the track in your video?
newkid99 is offline   Reply With Quote
Old 06-10-2015, 05:47 AM   #10
Mega3181
Gear
2nd to 3rd for gears, ideal I want 3rd gear and never shift
Tried 235 55 r16 on the rear and 2nd goes longer, but I find I can't real people in anymore. So going back down in tire size, change to 4.6 gearing, and work on the stagger to go around
Old 06-10-2015, 04:20 PM   #11
the head
the head's Avatar
If you are running dirt oval, have you tried corner weighting your car like a Mod chassis? throw a bit of additionall ballast to the outside rear for a more serious hook? dirt is a ton about weight transfer.
Old 06-10-2015, 04:52 PM   #12
deedub
deedub is an unknown quantity at this point
Hard parker nerd alert.
deedub is offline   Reply With Quote
Old 06-10-2015, 05:09 PM   #13
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Wish we could trade diffs. I want a R200v for my daily just because shorter gear ratio. I would say to actually go shorter than what you have. I dont work with SR's so I am not sure how much extra you need in order to stay in third but I would recommend maybe trying to swap with a NA Z32 Differential. However if second is just shy of where you need it and you find yourself having to upshift shortly before a corner and having to downshift again, I would say the 350 diff would be better suited to allow you to just stay in second.
Z33 - MT - R200V - 3.538
S14 - SR20DET - MT - R200V - 3.692
Z32 - R200V - 4.083
Still a VLSD but shorter gears. I mean, I would recommend trying out a welded diff to see if you like it but if you don't, go with this route.
Just my $0.02
Sorry for all the edits. Been awhile since I have talked ratios, had to figure out the math of it again but I got it now.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 06-10-2015, 06:10 PM   #14
accoupe
accoupe is an unknown quantity at this point
All the cars at the dirt oval here run a welded diff. I say go for it!
accoupe is offline   Reply With Quote
Old 06-10-2015, 06:53 PM   #15
kashira kureijii
What the hell is a hard parker???? It that like slidey parking?
Never heard that term before.
Just thought it was sad to see an s14 beat on, on a dirt track.Seems like something a go-cart,pickup, or tractor could do in a less depressing manner.
Poor car
Old 06-11-2015, 12:32 AM   #16
JSimpson
QFT. Teenagers and their JDM dreams... Might have better luck having crazy eyes from Deeds go align his car with 37 degrees of camber and a stock ka. So jdm "bro"...
Also on the oval you want weight on the LR NOT the RR. In order to make a car have grip you give it positive cross weight via increasing RF and LR weight. Weight in cars works as an X, if you add to one front it will also add to the opposite rear. A typical dirt sprint car will run 52% crossweight. The LR tire is the one that determines how much forward drive the car has, the RR is only for sidebite.
Old 06-11-2015, 11:04 AM   #17
Mega3181
Poor car
Cars wrote off, not street able, it was this or the wrecker!
Old 06-11-2015, 01:06 PM   #18
kashira kureijii
I see, well then i guess its fine then
Old 06-16-2015, 11:39 AM   #19
the head
the head's Avatar
Poor car
Better that than beat to balls drifting it into curbs.
Old 06-16-2015, 12:50 PM   #20
JSimpson
Amen
Old 09-14-2015, 10:09 PM   #21
Mega3181
Need setup help
So,since last year I e switched to 4.3 gears. Welded diff, camber on the front tires. And working on stager with the tires. But now il looking for that little extra
I'm thinking a 240/232 cam swap,is next.
And advancing the shit out of the timing.
Is there anything else I can consider to increase power just that little bit?
Old 09-10-2019, 01:15 PM   #22
Nickjames510
Nickjames510 is an unknown quantity at this point
I’m in the middle of doing the same thing. I just picked up a All stock S13, I will be putting on paved oval next race season. Would like to find 4.4-4.6 lsd to swap in it.
Nickjames510 is offline   Reply With Quote
Old 09-11-2019, 07:47 PM   #23
S14rebuild
Bro.....this thread is 4 yrs old...WHO THE FUK ARE YOU REPLYING TO?
