Old 05-29-2016, 07:31 AM   #1
girv
girv is an unknown quantity at this point
S13 sr redtop Cylinder 3 HELP
S13 redtop sr20det. Bc 264 cams, titanium valves, springs, retainers. 750cc injectors 60 trim top mount set up.
So I snapped an exhaust rocker on Cylinder 3 a few weeks ago. Fixed everything, put it all back together, did a compression test and Cylinder 3 still won't fire. I have good compression, I swapped coil packs, new plugs, I can't figure out what's going on. I took the plug out a few times and it seems to smell like fuel but not a ton, could I fried and injector when I snapped the rocker? I was doing a burn out and I had the motor wound out pretty good,, any help would be really appreciated
Sent from my SAMSUNG-SM-G890A using Tapatalk
girv is offline   Reply With Quote
Old 05-29-2016, 08:06 AM   #2
jedi03
Ohm out the components or swap them to another vylinder
Old 05-30-2016, 08:02 AM   #3
Kingtal0n
Kingtal0n's Avatar
post compression test results
engine only needs: compression, fuel, spark
Old 06-03-2016, 03:23 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
What compression #s are you seeing?
CLICK HERE!!!
