Stalling on boost in the rain
Okay so I have a really weird problem:
Car is TOTALLY fine when it is dry or mildly raining. If the car is totally soaked (as in driving in the rain for 30 mins or more), the car will stall when transitioning into boost. Like totally stall. Engine sputters and bucks, then dies and dash lights come on. Air filter is protected and shrouded from water (welded up the previously open holes in front of the wheel well). I don't think the maf is ingesting a large amount of water. Car drives fine on part throttle and cruising in the rain. Just boost in the rain. Relevant Motor specs: SR20DET Z32 MAF Wiring harness done by me, should be good, seems dry when car dies profec B spec-II boost controller power fc l-jetro full race manifold, gt30, tial 44mm wastegate water methanol injection from aem kit |
Could be moisture collecting at the coilpacks? Maybe you have small cracks that create more noticeable shorts when under load (boost) and enough moisture is present.
Bringing a thread back from the dead!
I fixed this. g14novak was right, water was blowing out the spark, but it was the combination of rain (moisture in the air) and my water methanol. I was using the largest jet which worked great in the usually dry climate I live in, but when the humidity and mist from the rain was high enough there was simply too much water in the intake charge. I fixed this by disabling the meth in the rain. I've yet to figure out a better solution that senses water content in the intake charge and drop meth injection. I'll update this if I figure out a better way of solving this problem other than disabling the water meth. |
