240sx near complete project
ITEM: 1993 nissan 240sx coupe
PRICE: 12,000 SHIPPING: none CONTACT INFORMATION : Todd Daniels 906-440-9930(text preferred) LOCATION: Houston Texas PAYMENT OPTIONS: Cash, Paypal, wire transfers SALE TYPE: Vehicle Build thread link! = 2jz s13 coupe build - Houston240sx.com Forums ----------------- DESCRIPTION: Well unfortunatly here it is. i have been debating making this thread for a while. but here goes. For sale, my coupe, everything on this car has been purchased as a new product. much thanks to Autrey at DWS. But seeing as i have even one day off a week i can no longer take the time to finish this or have the money to finish it. Storage units add up after time lol. Any questions please call or text me, in addition to posting here(so others may see). i am also in no rush to sell. And also not looking to part out. I dont have the time to take things off. ive put close to 22,000 into this project and i am taking a large hit for the price i am selling it for. I just cannot afford it and no longer have time to finish it. If it comes down to it ill just keep it and let it sit for a few years. Thanks for looking! and now to the good stuff! VIN:JN1MS34P4PW306973 Most complete list of mods Engine 2jzgte -aristo BC adjustable cam gears OEM timing belt OEM timing tensioner OEM supra water pump OEM thermostat Driftmotion pulley set Cusco solid engine mounts Driftmotion engine/trans brackets Oil cooler and lines(black) Greddy/grex thermostatic oil adapter Sr20 mishimoto radiator Driftmotion intercooler Ebay downpipe for aristo New full gasket set Headgasket+arp studs(not installed) Engine management Stock aristo ecu and wire harness(un touched or cut) Fuel setup 6AN fuel lines from tank walbro 416 e85 compatible pump(400lph) Aeromotive FPR kit for aristo Body Silvia front 30mm over fenders(d1) Carbon d1 silvia hood Aerocatch hood pins/latches Sideskirts(bomex?) Front bumper Silvia tined side markers Silvia headlight brackets Suspension BC coilovers 10k/12k Spl pro v5 titanium traction rods Spl pro v5 titanium toe rods Spl pro v5 titanium camber arms Spl pro v5 titanium eccentric lockout Spl pro v5 titanium front caster rods Spl solid aluminum subframe bushings Nismo power brace Whiteline adjustable rear sway bar Whiteline adjustable front sway bar (Both with full bushing sets) Cleaned and painted subframe Steering New oem steering rack Energy rack bushings DIF Solid steering rack bushing Z32 inner tie rods Spl pro v5 titanium outer tie rods Brakes Wilwood 6 piston front -13" vented and slotted rotor Wilwood 4 piston rear -12.2" vented and slotted rotor Oem Z32 master cylinder Braided ss brake lines Drivetrain Driftmotion/action stage 4, 6 puck disc and 2800lb pressure plate Driftmotion lightweight flywheel Kaaz 2way lsd(20disc) Kaaz lsd oil Arp flywheel bolts Arp pressureplate bolts oEM locking flywheel locking tab Wheels/setup Ichiba 5 lug coversion +25mm spacers (front) Cobra reps 10.5x17+ 20 Rear 255/45/17 Front 245/45/17 Tires are 100% tread nittos Nrg rose gold extended lugs Interior Nrg v3 gunmetal quick release Nrg short hub adapter Nrg deep corn wheel Prosport evo gauges -oil pressure -coolant temp -boost gauge -oil temperature -wideband and sensor Dash cap (to cover cracked dash) Car has never been driven, and engine has fresh timing set and turns over smooth. any questions ask! Only things required to finish this are a Drive shaft, intercooler piping and BOV. there may be some other small things that i may be forgetting. I also have the stock ecu and engine harness for the 2jz. PICTURES: ![]() [IMG]http://i10 0.photobucket.com/albums/m29/todddaniels/null-59.jpg[/IMG] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Rim to rotor clearance ![]() Stock vs new ![]() ![]() ![]() ![]() ![]() ![]() ![]() Test fitting(tape) ![]() Last edited by ToddDaniels; 10-20-2013 at 07:57 PM.. Reason: Lowered price! |
