Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
11-19-2010, 12:24 AM | #1 |
ksport hydro ebrake diy install - z33
dont have a 240 anymore; so i'll be playing with my 350z...
here's a basic write up. - brake lines fabbed - mount bracket fabbed - ksport bolted down - lines ran - line brackets fabbed and mounted ran out of light; didnt have time to install the lines and bleed the system; next week. pics: mount bracket: a 1/4" piece of 8x5 aluminum that i found around my dad's house; good to have a father that use to be a commercial shrimper ss brake lines: IN -7/16"unf 90* bend with a 90" m12x1 - 6' of line OUT - 3/8"unf 90* bend with a 90" m12x1 - 7' of line
duh mah! wheels and suspension! Last edited by AzNCmB; 07-09-2011 at 08:12 PM.. |
11-19-2010, 07:57 PM | #3 | |
here's one of my friends', my oem z33, and my ksport side by side...
duh mah! wheels and suspension! |
11-22-2010, 05:23 PM | #7 |
thanks guys, please stay up to date with the original post...im not done yet, I havent had a chance toinstalled the lines and bleeded the system because of work...
if anyone is interested, i can probably fabb up another mounting plate for a nominal fee...
12-15-2010, 09:48 AM | #9 |
sorry
updates coming, been very busy with events, wheel flying off n shit, and adding another s14 to my collection
12-19-2010, 04:07 AM | #10 |
Hey AzNCmb 3 questions for you:
1. What seat is that? 2. Are you still going to use the stock Ebrake 3. Once you plumb the new line into the MC and Reservoir, does that replace that 1 hard line? Your setup looks very clean! |
12-21-2010, 11:46 AM | #11 | |
but to answer your questions: 1. splparts.com bucket seat(discontinued) 2. no stock ebrake and ALL hardware have been removed. 3. yes, the custom ss line will replace ONE of the hardlines. i'll have everything posted up by the end of this week
01-09-2011, 08:42 PM | #12 |
update - Bleed & Remove oem ebrake
***UPDATE***
last update was nov. 18 2010, i've driven the car daily...drove it to houston on nov. 28 for a drift event, drove home, and have been driving and having fun with the car ever since. I'm from new orleans... ***important bleeding proceedure*** since the last update, all i did was bleed the system according to fsm, but before then, i had to unbolt the ksport and flip it right side up so that no air would be trapped in the master when bleeding. before driving to houston, all i did was secure the lines with some radiator hosing so that they wouldnt rubb n cheff after some time. also removed all of the oem ebrake parts. lines, shoes, clips, springs, evvrything!
02-07-2011, 09:29 AM | #14 |
worked a little bit but still needs re-tightening after heavy use
they're for sale if interested, $100 pm me n lmk thanks
05-28-2012, 09:56 PM | #18 |
Im actually looking into getting one of these.. so from looking at the pictures... you just replace 2 of the lines with this brakes lines ??? Or do you have to have some sort of way to get them to tap into the brake lines? The photos of the installation of the lines them selves didnt have an after photo of finished so im just sort of lost on that part.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
05-30-2012, 06:07 PM | #19 | |
no, you have to get custom lines made, the custom lines and the ebrake connect to make one whole flow. With the ebrake being in the middle bridging both the lines(one in and one out line). you do not tap into your oem lines at all.
