Old 10-17-2005, 06:05 PM   #1
reverend_sean
reverend_sean's Avatar
reverend_sean is an unknown quantity at this point
Head damage, is it repairable?
So I was cleaning up a DET head that I purchased and realized that there is damage to a cam seat(journal, race, ?). I know nothing about the life of the head. Is this kind of damage repairable, is the head totally shot, could it be run if the rough parts were smoothed out and polished? The scoring does go into the the metal a tiny bit, but not a ton.
'89 S13
reverend_sean is offline   Reply With Quote
Old 10-17-2005, 06:21 PM   #2
reverend_sean
here is a link to more pics.
http://www.kodakgallery.com/BrowsePh...photo_count=5&
'89 S13
Old 10-18-2005, 10:05 AM   #3
reverend_sean
doesn't anyone have a clue? Little help here guys. bump for no love
'89 S13
Old 10-18-2005, 11:53 AM   #4
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
well that's caused by particulate matter entering the oil system from the spun rod or main bearing in the lower end... grinding away at the cam and head, releasing more material into the system and then cycling through again. Um. Yes and no on the fix. You can try and get your cam journals align honed and get that mess worked out but it's not cheap and its difficult to tell from the pictures how deep the scorring is. That will determine it's use. You can get that part welded up and the journal align bored and honed but that would probably run around $500 and you could just get another head core. I thinks you got screwed. Hope you have a good refund policy where you got the head from.
TheWolf is offline   Reply With Quote
Old 10-18-2005, 01:07 PM   #5
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
i wount not bother fixing it .. dont think its duable at all since without being able to put different size bearings and then check oil clearance it pretty much impossible. id replace the head.
PS i do have one for sale if you need it.
Al_S14 is offline   Reply With Quote
Old 10-22-2005, 12:27 AM   #6
reverend_sean
It is actually a DPR head. Sucks even more!!!
'89 S13
