Old 10-16-2005, 10:30 AM   #1
sdtouge
sdtouge can only hope to improve
plexiglass windows s13 coupe
anyone installed some lexan/plexiglass windows on there coupe? or hatch for that matter? i was just planning on ordering some sheets cutting them out to size and riveting them in. should be some decent weight savings.
thanks
matt
sdtouge is offline   Reply With Quote
Old 10-16-2005, 10:49 AM   #2
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
wont make much of a diff on a coupe
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 10-16-2005, 12:00 PM   #3
sdtouge
i heard you can loose like 75 pounds or 100 pounds on some cars from doing this.
that is a good difference to me.
Old 10-16-2005, 12:10 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
The only windows you could really replace on the coupe is the 1/4 windows. Those windows are personally too small to even bother with. Fastback windows are bigger and could actually make a difference. You aren't going to get 75-100lbs of weight savings out of a coupe like that though.
Old 10-16-2005, 02:40 PM   #5
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Yea, and it doesn't looks as great. If you DO plan on going thru with it, if you get a hefty ticket for having it, you'll reconsider. Then again, its always nice to save weight, right?
If you go with Plexiglass, the areas where you rivet them on will crack, and spread. Sooner or later, the entire sheet will crack, and become useless. If you prefer lexan, its alot thicker. make sure you heat up the rivet areas, if not, it'll crack up a bit. It works ALOT better, but, when driving, all you'll hear is the lexan wiggling (sounds like thunder, just not as loud) from the wind that hits it.
GOOOOD LUCK!
SochBAT is offline   Reply With Quote
Old 10-16-2005, 05:28 PM   #6
sdtouge
thanks for the tips. i defniantly need the help.
matt
