Old 08-01-2005, 03:33 PM   #1
s2kwndl
s2kwndl is a well-known jackass
Send a message via AIM to s2kwndl
power fc problem
i just installed d jetro power fc on my redtop sr20det with a part # 414-n020 problem is there is no signal goin to #2 and #4 injectors... it was working with the stock ecu. we checked the coilpacks, injectors everything was good.thanks!
wendell
s2kwndl is offline   Reply With Quote
Old 08-12-2005, 01:09 AM   #2
luisgonz
luisgonz's Avatar
luisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfection
Send a message via AIM to luisgonz
Check it on a other car and see if its the same problem did you buy it used and what are you using to control it
luisgonz is offline   Reply With Quote
