Old 07-28-2005, 01:02 AM   #1
sl3mike
sl3mike is an unknown quantity at this point
Send a message via AIM to sl3mike
presure plate s14/s14
I know this is a newb question but i just want to make sure does a s13 presure plate off a single cam fit a s14?
if not i have a ACT presure plate for a s13 for sale 100 bucks. 3 months used no heat spots preaty much brand new will post pix soon if people are interested.
Mike
sl3mike is offline   Reply With Quote
Old 07-28-2005, 01:13 AM   #2
MiniR34
MiniR34 is an unknown quantity at this point
I believe it should.
As far as I know, all wearable clutch components(pilot bearing, flywheel, clutch disc, and pressure plate) of 1989-1998 USDM 240SX's are the same EXCEPT for the release bearing.
Someone please correct me if I'm wrong!
MiniR34 is offline   Reply With Quote
Old 07-28-2005, 03:26 AM   #3
sl3mike
anyone? help me out here.
Old 07-28-2005, 12:44 PM   #4
MiniR34
Do you want to buy my old S14 pressure plate? I have a '95 and I just did my clutch on Sunday.
I bought the Exedy/Daikin kit off ebay and the clutch pedal is a lot lighter with this new clutch, which I guess means that the old pressure plate that I removed is stronger. You can have the old clutch disc too, which looks like it has just as much friction material as my brand new disc.
The reason I changed my clutch was because my release bearing was bad, causing shuddering, so I believe the other components are fine.
