Question about bleeding clutch slave cylinder
ok i gotta bleed my clutch slave cylinder for my 95 s14 sr20, the resovor has black fluid. ok my question is can i use motul dot 5.1 brake fluid? or do i have to use the motul dot 3 brake fluid? and also would you recommend changing my clutch line to the stainless steel ones? are those easy to install?
![]() Join Date: Sep 2002
You can use 5.1. Just not DOT 5.
My 240 vBgarage |
Oh yeah. Why would you want to spend the extra on high temp fluid when the fluid doesn't see the temps that the brakes do???
My 240 vBgarage |
#5 | ||
![]() Yeah...you can use DOT 5.1...it's interchangeable with DOT 3 & 4...see below links for explanation.... http://www.stoptech.com/whitepapers/brakefluid1a.htm http://www.xs11.com/tips/maintenance/maint1.shtml Just DON"T USE DOT 5!!!...you''ll end up regretting it!!! Quote:
Anyhow, if you plan on swapping out the fluid you might as well go all out. Do the master & slave while you are there & go stainless steel. You can order them from TAKAMOTORSPORTS.com. Bout the only problem you're gonna have is you'll have to use your HE-MAN style muscles to bend the clutch line around so it mates up with the stainless steel line. I just watched my buddy Jason, (you met him), do it earlier today on his S14. Wasn't too difficult...just nerve-wreaking..sp??...you don't want to snap or kink that line. Anyhow, hit me up if you have any questions... D-man... AKA: ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... ![]() |
#6 |
Can't beat free. Good luck with getting it done. Make sure you check your free play too.
My 240 vBgarage |
