Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here. |
01-24-2005, 07:45 PM | #1 |
MUST READ before getting a drop-in HID kit!
This is a great write-up on why drop in hid kits suck. Not only the glare for other drivers, but the bad light pattern that is projected/reflected onto the road.
Credit goes to JMDLyfestyles on hidplanet.com I really hope this thread can help you guys. Ur making the road more dangerous than it already is by adding a HID kit to your car. so please do HID the right way by doing a retrofit. HID kits are illegal do to the glare that they cause. Glare is Light that is emitted in a Uncontrollable path. When light is traveling in a uncontrollable path it can hit other vehicle operators affecting there vision because of the High amount of uncontrollable light that is being Emitted from a HID kit in a standard Halogen housing. If you have ever turned a flashlight on right in front of your face while it is dark out, that is the same feeling that the other drivers on the road experience from a standard HID kit. OEM Vehicles such as Mercedes, BMW, Audi, Lexus are all equipped with HID or Xenon Headlights. Some use reflector housing’s without projectors. Others use HID projectors. The Lexus IS300 is a Prime Example of a HID reflector housing. It does not use a Projector. It uses a Specially designed Reflector housing that is meant to use HID. This does not create the Super sharp cutoff. But it does control where the light is being Emitted. Other vehicles such as the Honda S2000 Use HID projectors, These Projectors are meant to use HID. They are Specially Designed and have been tested Hundreds of times to get the right projection of light while maintaining a Good Cutoff. Here are pictures of Halogen housings mated with a HID kit 9006 6000k HID Kit... mad glare This teg is a prime example of Glare. This is what it looks like to oncoming traffic Disaster pix. HID kit in Halogen Housing NOW THE GOOD poop..lol This is what HID is suppose to look like.. Pictured is a STi Talk about a Razor Sharp Cutoff. Pictured is a S2000 OEM setup another S2000 Retrofit… YUMMY Article stating why the kits are illegal. http://www.nhtsa.gov/cars/rules/rulings/glare.html Comparison.. Pictured is a Acura TL-S with HID from the factory vs H4 6000K civic See the difference? Its not just honda's either. Here is a mid 90's Lexus with a HID kit.. To date, NHTSA has investigated 24 HID conversion kit suppliers; all investigations have resulted in recalls or termination of sales. RM Racing Astex USA Kmax International FET, Inc. J. Liu LLC Gourmet Garage JC Whitney Lighting Research SPW Industries, Inc. Pacific Micro-lite McCulloch Motors, Inc. Santeca Electronics JF Manufacturing Streetglow, Inc. Outback Products, Inc. Nu Performance GR Motorsports, Inc. Global Premier New Clor Importhookup.com DG International MTC Lighting Umnitza Liteglow American Products Company http://www.hidplanet.com/forums/viewtopic.php?t=3509
01-24-2005, 09:18 PM | #3 |
yea, they have ok cutoff and light spread, but nowhere near as good as a HID projector. Halogen projectors are actually designed differently than HID projectors, but they aren't as bad as most reflectors when putting drop-in kits in them.
You can see in that picture, the light spread from them is very narrow compared to HID projectors, and there is a big hotspot too.
01-24-2005, 09:44 PM | #5 |
LOL. Nice pics SilviaDriver.
If you think about it. The H4 bulb has two filaments. The are positioned going across the bulb and emit the light outward from the filament. The HID produces light through the arc in the bulb which goes from the base of the bulb to the tip. Anyone get what I'm saying. This is all just me thinking about it though. I don't really have any proof. I still like HID's though. I wonder if any manufacturer would make a HID housing for pop-up/rectangle whatever they're called lights in the future.
My 240 vBgarage |
01-24-2005, 10:31 PM | #6 |
That's some good information. Yeah I believe it is the arc of voltage that causes the light, so many volts are used just to start it...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
01-24-2005, 10:41 PM | #7 |
Yes, I look like that
I sincerely hope you copied and pasted that first paragraph... Here, I will fix it for you:
HID kits are illegal due to the glare that they cause. Glare is Light that is emitted in a uncontrollable path. When light is traveling in a uncontrollable path it can hit other vehicle operators, affecting their vision, because of the high amount of uncontrollable light that is being emitted from a HID kit in a standard Halogen housing. If you have ever turned a flashlight on right in front of your face while it is dark out, that is the same feeling that the other drivers on the road experience from a standard HID kit. OEM vehicles, such as Mercedes, BMW, Audi, Lexus, are all equipped with HID or Xenon Headlights. Some use reflector housings without projectors. Others use HID projectors. The Lexus IS300 is a prime example of a HID reflector housing. It does not use a projector. It uses a specially designed reflector housing that is meant to use HID. This does not create the super sharp cutoff, but it does control where the light is being emitted. Other vehicles, such as the Honda S2000, use HID projectors, These projectors are meant to use HID. They are specially designed and have been tested hundreds of times to get the right projection of light while maintaining a good cutoff. Here are pictures of Halogen housings mated with a HID kit 9006 6000k HID Kit... mad glare ...carry on now |
01-24-2005, 11:21 PM | #9 | |
01-25-2005, 12:04 AM | #11 | |
01-25-2005, 12:24 AM | #12 |
I just got a set of 5300k hids on my s14 zenki and it works pretty well in terms of visibility. Its not messy like the pictues above. Overall, im satisified by the outcome of the hids i got and really improved the light output compared to stock. I think aiming your headlight is the key to making the light more clean.
01-25-2005, 12:29 AM | #13 | |
silviasr20det: aiming the lights correctly is not the key. You cannot change the characteristics of the headlights simply by aiming them.
01-25-2005, 01:04 AM | #14 |
I don't think it's a matter of the amount of light. It's the source. If you put higher wattage bulbs in a H4 housing the light pattern is basically the same just brighter. I think it's the positioning of the source like we stated earlier.
My 240 vBgarage |
01-25-2005, 04:39 PM | #16 | |
I second that
1995 240SX SE - Sold |
01-25-2005, 05:18 PM | #17 | |
all halogen projectors are created differnetly. i believe the 240 projectors are created better than integras and other cars which is why they can handle them somewhat better than other cars. but i can always be wrong ill flip them when im not so lazy and have more time on my hands. |
01-25-2005, 05:33 PM | #18 | ||
Admin Asshole
