Garage sale! sr20 s13/14 cd009 parts
Decided to go through some boxes I had laying around for years and put some stuff up for sale.
I can take more specific photos of anything if someone is interested. Will ship, and located in northern New Hampshire. S13 top speed 3" test pipe. $40 Oem q45 tb. $100 SOLD! Hks bov. $60 Greddy bov. $140 SOLD! T28 turbo inlet. $40 Sr20 tstat inlet. $20 04 350z 6 spd ecu. $100 S14 xcessive skid plate. $75 Sr20 rps max clutch. $225 Sr20 exedy stage 2 clutch. $200 Sr20 oem flywheel. $25 Sr20 toda flywheel. $200 S13/14 evo 8/9 brakes with adapter. $550 SOLD! 326 lug nuts. $200 Rjs harnesses 2x blk 1 pnk. $40 each Isr turbo outlet. $100 Walboro 255. $90 Sr20 manifold/turbo gasket. $20 Sr20 manley valve spring & retainers. $220 S14 rear wheel bearing. 2x. $75 each Nrg quick tilt. $150 Cd009 slave cylinder. $40 Sr20 isr thermostat. $25 Q45 billet throttle body. $150 SOLD! Xcessive q45 tb flange. $30 SOLD! Five O 1000cc injectors. $350 Cd009 front cover gasket. $5 Sr20 to cd009 adapter from Maverick Motorsports. $350 S13/14 Nagisa seat rails New style RH. $190 SOLD! Old style LH. $165 S14 sr20 koyo rad. $150 Flex a lite dual 12" fans. $200 Pbm hydro. $130 SOLD! S14 oem sway bar with links. $60 S13 greddy rear strut bar. $100 SOLD! Nrg slim hub. $80 Omp adj wheel spacer. $100 Sr20 tomei ras. $50 S14 zenki bumper lights. $20 45mm itb velocity stacks. $65 10/10/21 update. 240sx to z32 brake lines $90 ![]() ![]() ![]() ![]() ![]() 10/10/21 update ![]() Last edited by OLC__BRIAN; 10-31-2021 at 08:07 AM.. |
Who makes the billet Q45? I am assuming it utilizes a factory TPS?
It was just an off brand name, I bought it a few years ago, I'm pretty sure it uses the factory TPS. But I do have a factory TPS so ill check it out tomorrow and let you know if that is what it uses.
#5 |
Cool, shoot me a PM. I am assuming it is Aluminum and not steel. Does it leak?
#7 | |
Future Moderator
![]() Join Date: Jun 2007
Do you have the hardware for the skid plate?
#8 | |
The front uses the oem tension rod bracket bolts. The rears I misplaced but they're just three 5/16s bolts. Ill pick some up at the hardware store, should be going there tomorrow. |
#10 | |
As far as I know the ssqv is original, I got it used probably 8 years ago so I can't say with 100% certainty. Ill add a few photos of that as well. ![]() ![]() ![]() ![]() |
