12-30-2019, 02:43 AM | #1 |
Sr20 sleeved Benson or other ?
Hello everybody . Merry Christmas . I am looking for advice for mounting a sleeve in my sr20det engine. I have heard of DAN BENSON RACING who looks good. I am afraid of water leakage problems later. So I'm looking for the best. If you have a sleeved engine or a close friend who is riding with it for advice. thank you friends
12-30-2019, 08:55 AM | #2 | |
Dan Benson looks and sounds good, I checked his page and he doesn't have a torque plate listed for sr20. Call around to a few shops if you're unsure to see who they use for machining, any shop that wants your business will gladly give you the time of day. Sent from my SM-G965W using Tapatalk |
12-30-2019, 09:55 AM | #3 |
yes sorry i don't speak english well, i'm french. actually I will line the 4 cylinders for objective to exceed 600whp with VE head
I made a quote at Dan Benson, with the answer $ 1,400 for sleeved sr20, boring, ans shipped to France. I contacted Dan Benson because he had done the sr24det Dsport project 2011 I think with success. I also know that Mazworx does it but with less positive feedback |
12-30-2019, 12:53 PM | #5 |
its a matter for the machinist to properly hone and press the sleeve in...its not rocket science but can be easy to mess up...as long as they measure correctly and you build the motor properly you shouldn't have any issues due to the sleeve/install
01-02-2020, 08:55 AM | #7 |
machinist to properly "drill" out the old sleeve/space for the sleeve, a press to get it in as it should be a tight fit...liquid nitrogen would just be there to help...if you heat the block and freeze the sleeve it will allow more of a gap than would normally occur and make it easier to install...not necessary imo but would allow for tighter fitting
01-02-2020, 02:43 PM | #8 | |
