![]() Join Date: Jun 2006
![]() Feedback Score: 20 reviews
RB25DET Kouki S14 **FULL PART OUT**
Hello everyone, Ive decided to begin parting out my RB25DET Kouki S14. It was nut and bolt build to a pretty high specification, very thorough. The car was finished up to the point of paint and body, ran and drove, but never hit the road. Ive begun dismantling in modules, and will first offer for sale in this manner. If there isnt any interest in that, I will begin piecing out. If you want information on something not listed or want to call dibs on something, just message me. Located in Central New Jersey, 08817. Ill start with Suspension and body.
Suspension/Brakes This suspension/brake setup has been dismantled and will now be offered in separate pieces. Ill update with pictures and prices over the weekend. Everything was removed in a way that it can be installed very quickly and easily. Its basically everything underneath an S14, from brake house to wheel studs. Every surface is powder coated or painted, every bolt has been replaced or upgraded. This took about 2 hours to remove from the car. Im listing this all together, as there is a lot of custom powder coating to make everything match. This is essentially a bolt in show car suspension/brake package in the easiest way possible. This entire setup can be installed in less than a day, every nut and bolt is included. Please read through the specifications. This is a build thread I made years ago, pretty thorough and shows most of what went into the suspension portion of the build. Tons of labor, powder coating, painting, burning, stripping, esc, esc. https://zilvia.net/f/showthread.php?t=340727 EBAY strut brace not included, only for holding up suspension Front/Rear APEXi N1 EXV Coilovers (new) Front: ---OEM lower control arms-----------------------------------SOLD Energy Suspension bushings (new) Moog ball joints (new) Powder coated (silver) ---S14 knuckle---------------------------------------------------SOLD Powder coated (matte black) ---5 lug hubs (painted silver)------------------------------------AVAILABLE ---Yamato garage tension rod (QA1 rod ends) (new)-----------------------------------SOLD Powder coated (ruby pearl) BallerBolts 12 point zinc plated bolts (arm to control arm) (new)----------------SOLD OEM Bolts (NEW) (Arm to body) -----------------------------------------------------SOLD ---OEM Strut to Knuckle bolts (new) ---------------------------------------------SOLD Rear: ---OEM S14 subframe -----------------------------------------SOLD Painted (gunmetal) Energy Suspension bushings (new) ---J30 limited slip differential (Final Drive 3.9)——————-SOLD Redline fluid (fresh) (new) ---S14 axles (cosmetic restoration)————————————SOLD Ballerbolts (axle to diff) (new)--------------------------SOLD ---S14 Knuckles -----------------------------------------------SOLD Custom powder coated (black) Energy Suspension bushings (new) ---Z32 handbrake assembly -------------------------------------SOLD Powder coated backing plate (gloss black) ---R33 Skyline GTS handbrake cables (the proper cables for Z32 conversion)----------------SOLD ---5 lug hubs------------------------------------AVAILABLE Painted (silver) ---OEM lower control arm -------------------------------------SOLD Powder coated (silver) Moog ball joint (new) Energy Suspension bushings (new) ---Yamato rear upper arm (new)--------------------------------SOLD Custom powder coat (ruby pearl) ---Yamato toe control rod (new)------------------------------------SOLD Custom powder coat (ruby pearl) ---Yamato traction rod (new)-------------------------------------------------SOLD Custom powder coat (ruby pearl) ---Ballerbolts fasteners (including eccentric lockout kit) (new)------------------SOLD ---ST Suspension rear sway bar (new)--------------------------------------SOLD Brakes:-------------------------------------------------------SOLD ---Evolution 8/9 Brembos (new seals) Front Powder coated silver (ruby pearl decal) Powder cleared Stainless caliper adapter (new) ---STI Rear brembo (only true bolt on brembo for S14) Powder coated silver (ruby pearl decal) Powder cleared ---All new brake hardware (front and rear) ---Racing brake ET-500 pads (front and rear) (new) ---Custom Agency Power conversion brake hoses (front and rear)(new) ---Rotora Brake rotors (front and rear) * (new) *was sent 2 left rear rotors, so one or both rear rotors need to be replaced [IMG] ![]() ![]() Front and rear Brembo brake package (specs above) As mentioned above, there are 2 left rear rotors (shipping error) so one or both rear rotors will need to be replaced. The setup was installed and bled, but never driven on. $1050 shipped without rotors $1200 w/rotors plus shipping [IMG] ![]() ![]() ![]() ![]() ![]() Apexi N1 EXV Coilover (Installed, never driven on) $700 [IMG] ![]() [IMG] ![]() Yamato Garage complete adjustable suspension arm package (every arm on an s14) QA1 rod ends, Full BallerBolts.com fastener package (12 point yellow zinc w/ U-nuts) (Installed, never driven on) SOLD [IMG] ![]() ![]() ![]() ![]() S14 front and rear lower control arms. Powder coated silver. Factory splash guard. New MOOG ball joints. New Energy Suspension bushings. New Ballerbolts and OEM fasteners. SOLD [IMG] ![]() ![]() ![]() ![]() ![]() S14 ST Rear sway bar (installed, never driven) SOLD [IMG] ![]() ![]() S14 axles (cosmetic recondition) SOLD [IMG] ![]() J30 LSD Diff SOLD [IMG] ![]() Z32 Handbrake assembly. Powder coated backing plates. R33 Skyline GTS handbrake cables (New) The true S14 bolt in cables. $250 SOLD [IMG] ![]() ![]() Last edited by doyle4281; 12-06-2019 at 08:25 PM.. |
$1600 for complete front end
Most of these parts were removed from my USDM kouki daily driver, original paint, even original ID tags on the panels. There is a slight chip in the left tailight, but otherwise fantastic conditions. Absolutely no hint of grey fading, as is common with the tailights. USDM kouki hood-------------------------------$425 USDM kouki fenders ----------------------------$425 USDM kouki headlights w/ corner --------------SOLD JDM kouki signals (new)--------------------------SOLD JDM kouki grille-------------------------------------$100 JDM kouki wing-------------------------------SOLD USDM kouki taillights ----------------$350 Origin Stylish front bumper (new)-------------$250 Origin Stylish sideskirts (new)----------------$225 Nismo replica rear bumper(new)-------------$225 [IMG] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Exhaust Blitz NUR Spec R . Like New condition, installed, never put on the road. Includes Blitz silencer if noise is a concern. Very nice piece SOLD [IMG] ![]() ![]() ![]() Wheels: Price: $1700 ———-SOLD This is a brand new set of Work Emotion XD9 wheels, special order in color MGM (Matte Gunmetal). These were not a standard color, and took 6 months to get, unlikely there are many more in this color. Tires were mounted and balanced, never driven on. The tires are old, so they likely have reached their expiration date. Specs are below, please contact me if you have any questions. Work Emotion XD9 Front: 18x9 +20 Falken F452 245/40/R18 (Likely past expiration date) Rear: 18x10 +18 Falken 452 265/35/R18 (Likely past expiration date) **Special Order MGM color** [IMG] ![]() [IMG] ![]() ![]() ![]() ![]() Gauge Clusters: R33 Skyline GTS Gauge Cluster. Great compliment to RB conversions. Factory harness with deutsch connectors installed. This makes it easier to change to different clusters without having to cut the harness again. Can be removed if permanent connection is preferred, and just use the connectors for something else, they are valuable. $150 shipped [IMG] ![]() ![]() JDM S14 Kouki Gauge Cluster w/ factory harness (white face) $125 shipped SOLD [IMG] ![]() ![]() JDM S14 Zenki Gauge Cluster (Black Face) $100 shipped [IMG] ![]() ![]() Last edited by doyle4281; 11-26-2019 at 11:40 AM.. |
#9 | |
Future Moderator
![]() Join Date: Jun 2007
Let me know if you part the rear suspension.
#15 |
The suspension setup has been dismantled and will now be offered in separate pieces. Ill update with pictures and prices over the weekend. Some parts have already been sold or sales are pending, but please message me concerning anything you see or want to reserve. Thanks
#30 |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
Bump for a great seller! Very cordial and prompt communication, very reasonable and did not hesitate to answer questions. Very willing to work out shipping on big item. Item arrived as described. Sellers like doyle4281 are hard to come by these days
Skurr ![]() |
