10-24-2019, 03:37 PM | #1 |
Mega SR Partout!! Everything must go...
***Pictures Added, parts added and prices adjusted
No BS parts in this build. I’ve decided to go another powertrain route for circuit racing. The best way to contact me will be by message or call Jeff @ (254) 251-0108 Pictures of the car and engine can be seen @ Cheeky_s14 on insta All smaller and lighter stuff can be shipped to lower 48 free of charge. Larger items PM or Text me for shipping. I can also send more pictures of anything you want to see via text message. -“SR22DET” S13 BLOCK- less than 1k miles since build 90mm Darton Sleeves 90mm 9.0:1 CP Pistons Eagle H-Beam Rods ACL Race Main and Rod Bearings ALL ARP Bolts S14 oil pick up New Crank-New timing components Balanced SOLD -SR20DET HEAD Package- $675 -Jim Wolf Technology S4 Cams ($560 MSRP alone) -ARP Head Studs (torqued once) -Tomei Rocker Arm Stoppers -Stoptech Dual Valve Springs & Retainers -TURBO KIT- -Powerlab/Boostflow Twin Scroll Manifold -Twin Scroll Garett 3071R -Dual Tial MV-S 38mm Wastegates -2x Dump tubes -3" Powerlab Downpipe -Mazworx SS Oil/Water Line kit -Vibrant Intake Tube and Filter *clears AC compressor $2200 -TRANS- -Stock SR 5speed -$250 -B&M short shifter (best money spent ever!)-$190 -Competition Clutch Twin Disk 725 series w/ARP flywheel bolts (500 break in miles and 1 track day) $900 -SR Spec Lightweight Steel Flywheel $100 -ENGINE ACCESSORIES- Chase Bays P/S Reservoir Kit SS lines-SOLD JGS Engine Mounts (S13 or S14)-$100 I love these mounts and they are awesome bc they are rebuildable using Jeep mounts TF Works Accessory Pulley Set-$50 Tomei oil pan w/Greddy magnetic plug-$270 -FUEL- Radium Fuel Rail includes -6an fittings-$190 Aeromotive FPR-$50 Tial 50mm BOV w/vibrant tubing cold Pipe- $175 -COOLING- Mishimoto X-line 3 row Aluminum Radiator W 2x Flexlite Electric Fans and shroud - SOLD Mishimoto Silicon Radiator Hose Set included with radiator Chase Bays Coolant Reservoir-$50 -ELECTRONICS- Haltech Platinum Pro ECU w/wiring specialties Pro Harness Haltech Boost Solenoid Haltech Air Temp Sensor Haltech 3 Bar Map Sensor Haltech Wideband kit Haltech 6 Can Hub Haltech patch loom kit All pig tails included Well over $3k invested -$1500 Alternator (less than 10 hours) SOLD Starter $50 Ignitor Chip $50 Coil Packs $25 each Chase Bays Grounding Kit SOLD Crank Angle Sensor $60 Power Steering Pump $50 All brackets $25 each
'98 S14 '09 Range Rover Supercharged (Daily) Last edited by JrockS13; 11-23-2019 at 09:12 AM.. Reason: Updates |
10-27-2019, 01:11 PM | #5 |
Myself and Josh Mcguire at Sparkys Speed Shop built the motor aside from the machine work. I’ve already started selling components. The car will never be for sale lol
'98 S14 '09 Range Rover Supercharged (Daily) |
10-29-2019, 06:16 PM | #9 | |
*pictures added
11-04-2019, 09:31 AM | #13 | |
Prices and Sold Items Updated
