Old 10-20-2019, 05:32 PM   #1
jtrav23
jtrav23 is an unknown quantity at this point
Ka24e no idle (fresh engine)
Hoping someone will be able to help me out. I just refreshed my ka24e and put it in a new chassis, now that it’s all in and hooked up it starts right up by instantly drops idle till it dies. The only way to keep it running is unplugging the maf.
So far I’ve checked while it’s running for vaccine leaks and the idle doesn’t jump.
Is this a timing problem or am I going to have to bite the bullet and buy a new maf.
I have a video of it running with maf unplugged but I’m not sure how to post it and I also don’t have this hooked up due to not having a clue where it goes
*Edit* the engine also had new clutch header egr and emissions delete and inked intake as well all done with the engine I have fpr hooked to manifold, and Iacc and air regulator hooked to pipe leading to intake also brake booster is hooked to manifold and valve cover is hooked to intake. I think this layout is correct?
jtrav23 is offline   Reply With Quote
Old 10-20-2019, 08:26 PM   #2
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
I thought the EGR delete messes up idles a bit, I’m sure more experience guys will step in and help out
andisan is offline   Reply With Quote
Old 10-21-2019, 01:32 PM   #3
S14rebuild
More pics please, seems like this shouldnt be a huge issue to fix
Check voltage on the maf, and its ground
Old 10-21-2019, 02:36 PM   #4
jtrav23
I can get more, anything specific that could be helpful for pictures?
Old 10-21-2019, 03:53 PM   #5
S14rebuild
Just vacuum routing.
But if u sayn the car idles with the maf unplugged. Then that would be the direction i would head
Old 10-30-2019, 09:39 AM   #6
jtrav23
Sorry never got the pictures but I threw on a new tps I had lying around and unplugged the maf and it idles perfectly at 800, revs to limp and falls correctly so I’m gonna look for a replacement maf I guess, do you know of any that are good and not upwards of 300 dollars?
Old 10-30-2019, 05:56 PM   #7
S14rebuild
Post wtb, checknebay and ur local classifieds, offer up and cl
Old 11-01-2019, 06:14 PM   #8
jtrav23
Okay will keep updated! also found a dead injector of the 4 new ones I bought, now to figure out why my coolant gauge doesn’t work and why my room lamp fuse is leaving the running and tail lights on... ugh
