![]() Join Date: Feb 2012
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
S13 suspension, doors, DRL, Innovate gauges, BMC stopper, zenki retainer, crash bar
Hey Zilvia, just trying to move some stuff out. If you have questions, just PM or thread reply. If you need shipping, we can get that set up as well.
Philips daylight 9 drl BNIB. Super freaking bright, legit drls if you're serious about it. It has a controller for it as well. 80$ Mishimoto oil catch can. Was going to use it, but I changed where it was mounted, and it'd be a pain to service, so I bought a different style of catch can. Does not come with fittings. 80$ S13 extended diff cover. Bought it new from FR ~4 years ago. Itll get cleaned up for the buyer. I moved to a GK tech cover. SOLD Innovate Motorsports MTX-D gauges: oil temp/pressure and water temp/voltage + Prosport clock + mounting. These gauges are legit and accurate. They obviously will come with all harnesses and sensors. I have the silver bezel/whiteface pieces for them as well. They will also have their serial cables. They are fully programmable for what you want them to show for warnings/outer LED ring. Also, I've wired them up so they have connectors (soldered/heatshrunk). You will obviously get the pigtails for the "body harness" side. If you want them without the connectors, I can remove them before hand. Theres nothing wrong with them, Im going to get an MFD setup. The clock is nothing crazy... Just a clock. Full setup sits nicely in the dash, and is angled. It makes a huge difference when glancing over at them. 320$ I can include an in-line rad hose adapter for the water temp sensor. S13 front/rear lower control arm combo. Rear control arms refreshed. Zero miles! They were mounted, but I decided to bite the bullet and get gk tech arms. These have new moog ball joints and whiteline bushings. I'm not kidding when I say they were a big bitch and a half to press in, but they're ready to go! They even have the plastic undercovers. Fronts are are moog replacement arms and they have about 20k miles on them. Pick them both up for SOLD S13 SR circuit sports coil pack cover. No scratches, looks mint. Nice ornament piece that doesn't trap hot air around your coil packs. 60$ Pineapple subframe tilt spacers. Perfect for those with an unmodified S13 subframe. They let adjust your anti squat to your need. 35$ S13 3x2 axles. Nothing wrong with them, just converted to Z33 axles. 100$ P2M braided clutch line. It's seen fluid, but no actual use. I converted back to a hard line and short soft line. I added a nylon sleeve to help protect it from rubbing. It will come with new crush washers. SOLD Modified S13 SR valve cover. This is the blu808 mod that reroutes your crank case ventilation to flow through more baffling. The side fitting is pressed, and the top fitting is NPT tapped. Both fittings have JB weld around the fitting itself to help reinforce around it for taking the hose on/off. The fitting sizes are 5/8 (oem), so you should be able to re-cut your current hoses. PCV valve on it was bought from FR Sport ~5 years ago. I never got to run it as I came up on a great deal for a 13.4 cover. SOLD I also have a spare top fitting and the tap/drill bit of someone wants to do it themselves for 20$ UAC wiper motor cover. Speaks for itself, it definitely is a nice touch. Small section chipped off. My new chassis has shakkito plates, and I cannot have the cover installed with them. 20$ GK Tech SR20 water neck adapter with 1/8 npt port. Literally brand new. Was going to use with my other adapter, but it is "taller" and does allow me to use the others' port. 25$ S13 rear subframe braces. Oem braces, I just cleaned the rust off of them and coated them with liner. Perfect if yours are rusted out or bent. 20$ S13 door shells, they're gray but have blue wrap on them. Each door has a very small pdr, but otherwise clean! 60$ Circuit sports BMC stopper. Comes with hardware. I'm getting a dual diaphragm brake booster, and will need to get a different one. SOLD S14 zenki bumper retainer. Im positive thats what it is. It's only one number off from the zenki retainer p/n but I could not find it searching the p/n stamped on it, but it looks just like others I've seen. (if something has Nissan FAST, pm me) 40$ S13 manual brake booster. Works great, I'm swapping out to an m195t - SOLD S13 rear crash bar with foam. The foam is broken in half but can be hot glued back together. SOLD No name strut bar. Anodized red with black spray paint on it (solvents will take it off easily) 20$ Silicone cobra head couplers (to the left in the picture). Perfect for tight clearance applications. 2.5" 60$ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G955U using Tapatalk ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by mr.nismo.; 08-10-2019 at 01:27 PM.. |
#8 | |
Trader Rating: (31)
Sent from my SM-G955U using Tapatalk |
#9 |
Hmm well fuck it i need it, my driver door is poop. How much do you think shipping would be. Ill be alright without the strut brace
Sent from my LM-X210(G) using Tapatalk |
#10 | |
Trader Rating: (31)
#17 |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
How much for just the s13 rear lower control arm shipped to 93436???
#23 | |
Trader Rating: (31)
Sent from my SM-G975U using Tapatalk |
#25 |
Trader Rating: (31)
Bump! Lots of people asking for shipped quotes and not replying after. Please pm me for a shipping quote only if you're really interested in buying something.
#27 |
i want the diff cover, how much shipped to 78738
https://www.instagram.com/200sx_type_x/ |
