Old 10-05-2018, 07:27 PM   #1
surly
Trader Rating: (106)
surly is an unknown quantity at this point
Feedback Score: 106 reviews
300ZX Z32 Aluminum Calipers / 5 lug hubs / Q45 Diff Conv. Axle
UPDATED 1/20/2020
All parts were working when removed but as is. No trades needed, Thanks for looking!
300ZX Emergency Brake Conversion
If you are running rear z32 calipers brakes you need this.
Bolt on for S13/S14, converts to Z32 drum emergency brake.
I’ve installed 10+ sets if you need any install info lmk.
Includes all hardware and anchor bolts, springs, nuts, etc.
Pads have good meat on them, comes with 3ft of cut cable for splice method found here:
http://importnut.net/300zxbrakeswap-ebrake.htm
300ZX Ebrake Conversion
with cut cables - $185
300ZX NA Rear 5 Lug Hubs
S13/S14 Bolt on rear 5 Lug, No play on bearings. Ready to use.
Came off driving car. Non-tabbed $110[/B]
surly is offline   Reply With Quote
Old 10-05-2018, 08:04 PM   #2
Driftaholic84
Driftaholic84 is an unknown quantity at this point
I just Pm’d you
Driftaholic84 is offline   Reply With Quote
Old 10-09-2018, 04:37 PM   #3
surly
More Ebrake sets available!
Old 10-10-2018, 08:04 PM   #4
surly
Calipers, Hubs, and Ebrake ready to ship!
Old 10-10-2018, 08:50 PM   #5
cpl dozier
cpl dozier is an unknown quantity at this point
Got a z32 master cylinder?
Sent from my SAMSUNG-SM-G920A using Tapatalk
cpl dozier is offline   Reply With Quote
Old 10-10-2018, 10:10 PM   #6
surly
Not right now unfortunately
Old 10-11-2018, 03:55 PM   #7
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
pm sent. thanks
Pinggg is offline   Reply With Quote
Old 10-14-2018, 12:55 AM   #8
surly
Calipers, 5 lug and Ebrake still available!
Old 10-17-2018, 06:44 PM   #9
surly
300ZX Calipers, 5 Lug, and Twin Turbo Axle still available!
Ebrake sets sold out for now.
Old 10-20-2018, 12:31 AM   #10
surly
Best offer for TT Axle! Shipping available!
Old 10-20-2018, 09:57 AM   #11
1Badhatch
1Badhatch is on a distinguished road
I heard somewhere that j30 axles worked as well for the q45 diff in a s13 is that true
1Badhatch is offline   Reply With Quote
Old 10-20-2018, 05:41 PM   #12
surly
That’s only for S13/S14 which use a R200 diff, the j30 uses a R200 as well so the axles will work.
The Q45 uses the larger R230, the ring gear and casing is bigger and uses larger diameter axles. So to put it into a s chassis you need a Z32 TT drivers axle and a Q45 drivers axle. Also the larger Q45/TT hubs need to be used.
Hope this helps.
Old 10-21-2018, 05:50 PM   #13
surly
Caliper, 5 Lug, and TT Axle still available!
Old 10-22-2018, 07:53 AM   #14
Chris dz
Chris dz has a little shameless behavior in the past
300zx rear conversion
i sent you a PM
Chris dz is offline   Reply With Quote
Old 10-24-2018, 03:53 PM   #15
Laotian240
Laotian240's Avatar
Laotian240 is an unknown quantity at this point
Rear calipers still available? Where you located? PM me?
Laotian240 is offline   Reply With Quote
Old 10-26-2018, 10:27 PM   #16
surly
Just Hubs and Axle still available!
Old 11-10-2018, 06:00 PM   #17
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Hope this helps.
I'm a little late to the party but the G50 Q45 uses an R200 differential. Only the Z32TT uses the R230. Both use the same 6x1 bolt pattern for the output shafts / axles however.
Old 11-17-2018, 12:23 PM   #18
Mikes67
Mikes67 is an unknown quantity at this point
Do you expect to have E-brake assemblies back in stock soon?
Mikes67 is offline   Reply With Quote
Old 11-19-2018, 09:32 PM   #19
Gon_z183
Gon_z183 is an unknown quantity at this point
300zx Axle
Hey hows it going, is your axle for the 300zx still available ?
Gon_z183 is offline   Reply With Quote
Old 11-20-2018, 10:51 PM   #20
surly
Sent you a PM
Old 01-10-2019, 12:55 AM   #21
surly
Updated 1/10/2019!
More Ebrake sets and Hubs available!
Old 01-10-2019, 06:15 AM   #22
Cas240sx
Cas240sx is an unknown quantity at this point
Sent you pm....
Cas240sx is offline   Reply With Quote
Old 01-11-2019, 07:42 PM   #23
surly
Just have a few more Ebrake sets, hubs and axle also still available
Old 01-14-2019, 09:14 PM   #24
surly
Shipping available!
Old 01-17-2019, 09:58 PM   #25
surly
One Ebrake set left!
Hubs and axle also available.
Old 01-20-2019, 09:44 PM   #26
surly
5 Lug Hubs and Axle still available!
Old 01-23-2019, 06:37 PM   #27
surly
Still got Hubs!
Old 04-16-2019, 05:56 PM   #28
surly
Updated 4/16/2019!!
Old 04-16-2019, 06:12 PM   #29
StraightLine240
StraightLine240 is an unknown quantity at this point
What’s the difference between tabbed and non tabbed? Looking for a cheap 5 lug swap for my s13
StraightLine240 is offline   Reply With Quote
Old 04-16-2019, 09:41 PM   #30
surly
If you’re doing the Ebrake it’s just for matching the anchor bolts. For 5 Lug either types works
Copyright ©2000 - 2023, vBulletin Solutions Inc.
