Old 04-01-2018, 12:48 PM   #1
lazy_flip
lazy_flip's Avatar
lazy_flip is an unknown quantity at this point
Send a message via ICQ to lazy_flip Send a message via AIM to lazy_flip
s13 GKTech S/R/Z32 CHASSIS REAR KNUCKLES
I bought these brand new straight from GKTech, I only mounted them once and haven't driven on them at all. All bearings are still stiff and new, no bushings are missing, threads are clean as a whistle.
These will fit any S13, 14, 15, R32, 33, 34, and Z32 chassis. These retail $500, and that's before tax and shipping. I'd like to get $350 which I feel is extremely fair since they are practically brand new, zero miles.
Here's the link to their official page:
https://us.gktech.com/products/rear-...-rear-knuckles
After nearly 2 years in development, countless prototypes and revisions we have a lightweight yet strong drop knuckle for the S/R/Z32 chassis Nissan's. They come with dual caliper brackets as standard, high quality PTFE lined spherical bearings throughout and have all new kinematics to drastically improve anti-squat, bumpsteer, cambergain curves and raised roll center height.
- Ability to run dual caliper without spacing the rotor out
- Ability to run drum brake in standard position with dual calipers (or single caliper) installed
- The drop is 1.57'' (40mm) - optimized for cars 1.57'' (40mm) lower than factory ride height (more drop would have required proprietary arms)
- High quality PTFE lined spherical bearings throughout as standard, common bearing size so replacements are easy to get and affordable (QA1/FK part #COM10T)
- All new kinematics to significantly increase grip over regular drop knuckles
1) Optimized camber curve for more even tyre wear
2) Optimized bumpsteer for toe-in under compression without OEM arms' elastokinematics
3) Increased anti-squat for more rear weight transfer and traction
4) Raised roll center height for better handling
- Light weight sheet metal design optimized using finite element analyses for ultimate strength - fully dressed weight (bearings, spacers, circlips) 4.1kg (standard knuckle is 5.1kg)
- Clearance for larger GTR drive shafts
Installation notes:
- To be mounted with bearing mounting holes perpendicular to the ground in static height (extended LCA's that push the wheel out to the rear of the wheel arch will NOT work well, or at all if extended too far out). Note that our rear LCA's adjust perpendicular to the center line of the car, which makes sense.
- With standard lower control arm length on an S14/S15 subframe the ideal traction arm length is 7.83'' (199mm) (adjust toe and camber accordingly, best results should be at around 0 degrees camber/0mm toe), and on an S13/180sx subframe the ideal traction arm length is around 8.34'' (212mm), again 0 degrees camber and 0mm toe.
- Will fit all S, R and Z32 chassis' with the use of an S chassis style lower coilover mounting, S13/R32/Z32 and to get the most out of the kinematics improvements, an S14/S15/R33/R34 rear subframe is suggested. Alternatively the lower control arm front pivot point can be moved up.
- Will clear 17" rims (and even 16" rims with low offsets) and all 18" rims but please note that the closer the rim sits in the wheel-well, the greater the chance that the toe arm mount will come close to hitting. A 17x10.5 +22 Enkei RPF1 wheel was tested and still has around 0.19'' (5mm) of clearance (ample)
- Aftermarket camber, toe and traction rods ARE required and MUST have heim joints as the suspension mounting points on the knuckle are in significantly altered and rubber or similar wouldn't have enough misalignment to work. Lower control arms can be OEM or aftermarket and do not need to be changed. OEM bushings in lower control arms will produce different bumpsteer curves
- The Wilwood dual caliper bracket that we offer do NOT fit on these knuckles
lazy_flip is offline   Reply With Quote
Old 04-01-2018, 03:20 PM   #2
Judeasaurus
Judeasaurus is a well-known jackass
Damn, I would've bought these right away, but I'm deployed atm. Good luck with selling!
Judeasaurus is offline   Reply With Quote
Old 04-01-2018, 03:27 PM   #3
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (29)
mr.nismo. is a jewel in the roughmr.nismo. is a jewel in the roughmr.nismo. is a jewel in the roughmr.nismo. is a jewel in the roughmr.nismo. is a jewel in the roughmr.nismo. is a jewel in the roughmr.nismo. is a jewel in the rough
Feedback Score: 29 reviews
Damn. Wish you posted these a couple days ago lol
Sent from my SM-G955U using Tapatalk
mr.nismo. is online now   Reply With Quote
Old 04-01-2018, 03:44 PM   #4
djtoonjr
djtoonjr is an unknown quantity at this point
Ill take em. Pm an payment method
djtoonjr is offline   Reply With Quote
Old 04-01-2018, 04:04 PM   #5
lazy_flip
lazy_flip's Avatar
Sold! Thank you
Old 04-01-2018, 04:04 PM   #6
speedfiend
Trader Rating: (64)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 64 reviews
Send a message via AIM to speedfiend
These have already been paid for by "ME".
Let me know when you get these shipped out.
Thanx, Cameron
speedfiend is offline   Reply With Quote
Old 04-01-2018, 04:43 PM   #7
EliteGTR
EliteGTR's Avatar
Trader Rating: (18)
EliteGTR is an unknown quantity at this point
Feedback Score: 18 reviews
dammit!!!!
EliteGTR is offline   Reply With Quote
gktech, kinematics, knuckles, spindles, suspension
