03-31-2018, 06:42 PM | #1 |
RB25DET cooling upgrades?
Hey guys, just bought a RB25DET swapped S14 last week. It has stock turbo and injectors etc. but I want to focus on cooling before I start on any of that. It currently has the stock S14 radiator and stock belt driven fan so I figure I should upgrade those first.
What is a good radiator/electric fan combo that should be pretty easy to swap in? What other cooling upgrades should I go for? This is my first RB25 and first swapped vehicle so this is going to be a bit of a learning experience. Appreciate any help! |
03-31-2018, 06:48 PM | #3 |
Someone mentioned I'd probably have clearance issues if I kept the stock fan? I haven't actually done any measurements though I was just going off of that so I thought I'd have to switch to like dual electric fans or something. I'll try to get measurements for a bigger aluminum one and see if it will fit I guess. Thanks.
03-31-2018, 06:50 PM | #4 |
Never ran into cooling issues. Will help a lot to remove your oil warmer underneath the plenum. Oil temps stay below 160F and water temps stay below 76c. |
03-31-2018, 06:58 PM | #5 | |
03-31-2018, 07:29 PM | #9 |
03-31-2018, 08:00 PM | #11 |
Stock clutch fan. It just has to be mounted on the oposite side of the clutch and shaved slightly to clear the damper. When i upgraded to a koyo performance radiator, i had to modify the radiator bottom brackets to make them shorter to move the radiator closer to the condenser. That and elongating the screw holes on the upper radiator brackets gave me just enough clearance (less than .25" on the upper tank) for the fan to clear. Motor only mover side to side so any clearance should be gtg.
I wouldnt recommend removing the oil warmer. I do believe it also helps maintain the oil temps down. I'll share some pix later. Only picture I have atm
Tuners are big bullies |
04-06-2018, 06:30 AM | #12 |
Man this is a tight fit.. How did you get the fan on? Was it installed prior to installing the radiator? What motor mounts are you using?
04-06-2018, 09:31 AM | #13 | |
Yep, fan went on the backside of the clutch, bolted to the pulley, then the radiator was installed. The mounts are custom made by me, intentionally to mount as far back as possible. There’s less than a centimeter between the firewall and the back of the head. |
04-06-2018, 10:03 AM | #14 |
Some people will notch the upper radiator support to tilt the radiator forward and make new bracket holes. If you take your time it actually can come out quite nicely.
Wish there was more info on clutch fan CFM ratings. Derale makes fans that pull 4,000CFMs and work stout. Although, controlling E-fans without a standalone is kind've a nitemare IMO. If you can stick with a clutch fan, do it. |
04-07-2018, 10:12 AM | #15 | |
