03-07-2016, 07:41 AM | #1 |
FS: Coil Boots to use S15/Z33 coilpacks in S13/S14
SOLD!!
Used set available. Used less than a year. I traded for an S15 valve cover so no longer need these. Asking $35 shipped, includes hardware needed to bolt up coilpacks. See below for original post & info. Selling used set of boots to use S15 coilpacks in an S14/S13 valve cover. S15 coils have a skinny boot and you typically need an S15 valve cover to use them, instead swap on these boots and keep your current valve cover! S15 coil packs are also currently cheaper on frsport. It took me a while to track these down so I ordered two sets. I test fitted a Z33/G35 coil, and it seemed to work. New set - sold Used set - sold Used boots with hardware: Original test fit photos: Test fitting on a G35 (Z33) coilpack: I went this route after noticing that the Splitfire coils were nearly identical between the S13/14 and S15 kits with the exception of the rubber boots. I've yet to figure out what "stock equivalent" boots these are, so had to deal with several overseas vendors to find a match. Last edited by LoSt180; 01-29-2017 at 12:36 PM.. |
03-11-2016, 01:34 AM | #3 |
Looks like the z33 coilpack won't bolt down? Like it's not lined up with the bolt hole anymore after swapping the boots.
Sent from my iPhone using Tapatalk |
01-29-2017, 09:04 AM | #8 |
Bump, used set of boots and hardware available. Picked up an S15 valve cover locally so no longer need these.
Second chance if you missed these the first time! EDIT: Nevermind, Sold in record time. Last edited by LoSt180; 01-29-2017 at 12:37 PM.. |
