Old 11-22-2015, 01:04 AM   #1
R2RO
R2RO is an unknown quantity at this point
s13 S13 Drift Car SR20DET Partout (PBM, Tomei, Apexi, B&M)
Hey everyone! Made a different thread for my part out, going a different route with my build i'm selling off all parts on this car that are SR20 related.
Parts location: Palmdale, CA 93551
Huge parts list, Please comment in what you're interested in below! Any specific SR20 parts that are on the motor that you're interested in that aren't listed PM me and I can give you a price for it.
PM me for Shipping costs if you want anything below!
Parts list as of December 20, 2016
Engine
-Takata Race 4 ASM Green Harnesses - $280/Each
-CP Pistons & Eagle Rods (Came out of my blown SR, I'm not sure if they're even good; Sold as is) $200obo
-A'PEXi Power Intake for Z32 MAF(Almost new condition) - $55
-Nissan S13 SR20DET Coil Packs (4) - $50
-GSWerks Custom Baffled Oil Catch can - $40
-Circuit Sports Oil Cooler Adapter with Oil cooler lines, all you need is a new oil cooler core - $50
No photos as of Dec.20(Will upload some soon)
-Nissan S13 SR20DET 5-Speed transmission, 2nd grinds $50 Picked up
-VIS Carbon Fiber Trunk(Needs Work) - $100 Picked up
-Greddy Oil Filter SR20- $6
Parts Sold as of December.20.2016
-Tanabe Revel ELS Gauge (Boost)(SOLD)
-AEM Wideband Air/Fuel Ratio Gauge(SOLD)
-Tanabe Revel ELS Gauge (Oil Pressure)(SOLD)
-9K Racing 150mm Shift knob(SOLD)
-Koyo Racing Radiator Cap(SOLD)
-Koyorad Radiator w/Electric Fans & Shroud(SOLD)
-Samco Silicon Radiator Hoses w/ Greddy Thermostat Sensor(SOLD)
-Z32 MAF(SOLD)
-S13 SR20DET Power Steering pump(SOLD)
-Nismo Adjustable Fuel Pressure Regulator-Type B(SOLD)
-S15 SpecR Dual Ball bearing T28 Turbo without other stuff(No shaft play)(SOLD)
-555cc Tomei Fuel Injectors(SOLD)
-Apexi Power FC L-jetro(MAF) for Nissan 240sx SR20DET w/FC Commander(REDTOP, Model #414-N014)(SOLD)
-Greddy SR20DET Oil pan(SOLD)
-B&M Short Shifter(SOLD)
-S13 Radio Bezel(SOLD)
-Circuit Sports Engine mounts(SOLD)
-Parts by Max HMIC Complete Kit(T28 Turbo, OEM S13 SR or Greddy Intake manifold)(SOLD)
-Nissan Z32 BM-57 Master Brake Cylinder(SOLD)
-Parts by Max Super Angle Knuckle(SOLD)
-Parts by Max Front Lower Control Arm + Tension Rod Combo (BENT)(SOLD)
-Parts by Max Traction Rod(SOLD)
-Gramlights 57DR 17x9 +22 Square(SOLD)
-SPL Pro V5 Outer Tie Rod Ends(SOLD)
-TEIN Hardened Inner Tie Rods(SOLD)
-Parts by Max Pro Toe Rod(SOLD)
-Parts by Max Rear Upper Control Arms(SOLD)
-Uncracked S13 Dash(SOLD)
-Siliva S13 Brick's Headlights(SOLD)
-Parts by Max Flex Cobra Downpipe(For T28 Turbos) wrapped in Mishimoto heat wrap(SOLD)
-Circuit Sports Brake Master Cylinder Heat Shield S13 with Mishimoto Thermal Tape(SOLD)
-Parts by Max Turbo Inlet pipe for T28 style turbo for Z32 MAF(SOLD)
-Mishimoto X-Line Aluminum Radiator(MMRAD-S13-89SRX), 1989-1994(SOLD)
-Bride Seat Rails Pair(Passenger & Driver)(SOLD)
-Parts by Max MaxPro Coil-Overs(less then 30 miles)(SOLD)
-Parts by Max Rear Drop Knuckles(less then 30 miles)(SOLD)
-S13 Chase Bays Fender well Brake Lines for Z32 Calipers(SOLD)
-Hydro Dual Caliper Full Bolt On Set-up: (ASD 16’’ Pull back Universal Hydraulic E-Brake 3/4 , Custom Lines Included)(SOLD)
-89-99 Kaaz 2-Way Diff 240sx (Great Condition, Low miles) with Final Drive & 5 Bolt output shafts(SOLD)
-Nissan SR20DET T28 Compressor inlet(SOLD)
-Nissan SR20DET T28 Compressor Outlet(SOLD)
-Nissan Z32 Aluminum 30mm Front Caliper Pair(SOLD)
-Nissan Z32 Aluminum Rear Caliper Pair(Comes with hardware and stock pads)(SOLD)
-Parts By Max S13 Skid Plate (Gold)(SOLD)
-Nissan SR20 Notchtop Valve cover Black(SOLD)
-Nissan S13 Door covers(SOLD)
-ATP Manual Boost controller(SOLD)
-Nissan SR20DET T25 Compressor inlet(SOLD)
-Mishimoto S13 Aluminum Fan Shroud (#MMFS-S13-89SR)(SOLD)
-NRG Steering Hub lock(SOLD)
-Frozen boost 31”x11.75”x3” Bar and Plate 600HP Capable intercooler with new Silicon couplers(SOLD)
-Nissan Z32 Aluminum Rear Caliper Pair(Comes with hardware no pads(SOLD)
-Porterfield R4 AP460 Front brake pads for z32(SOLD)
-Porterfield R4 AP461 Rear brake pads for z32(SOLD)
-Parts by Max RLCA(less then 30 miles)(SOLD)
Enjoy!
R2RO is offline   Reply With Quote
Old 11-22-2015, 07:01 PM   #2
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
how much for the shipping on the skid plate to 33304?
240knockout is offline   Reply With Quote
Old 11-23-2015, 04:00 PM   #3
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Bookmarking this
S14kouki805 is offline   Reply With Quote
Old 11-23-2015, 04:31 PM   #4
s14Irvin
s14Irvin is an unknown quantity at this point
I'll take the samco hoses! What's your PayPal ����
s14Irvin is offline   Reply With Quote
Old 11-23-2015, 06:24 PM   #5
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
Apexi Power intake and z32 maf 170 shipped plus fees. If thats good with you pm and i will give you my pay pal info.
lewisfk is offline   Reply With Quote
Old 11-24-2015, 02:00 PM   #6
R2RO
Bump, Parts sold recently
-Greddy SR20 Oil pan
-Z32 MAF
-Samco Radiator hoses.
Pm me if your interested in any item on the list above or message me if you want a part from the motor.
Old 11-25-2015, 06:59 PM   #7
R2RO
Bump, Parts sold yesterday
Pm me if you want any and all parts SR related, thanks guys
Old 11-25-2015, 08:33 PM   #8
Zenkiii
Zenkiii is an unknown quantity at this point
What's a deal you can make for the l jetro and 555cc injectors and the turbo itself
Zenkiii is offline   Reply With Quote
Old 11-26-2015, 10:22 PM   #9
soCALsx
soCALsx is an unknown quantity at this point
You selling the hydro?
soCALsx is offline   Reply With Quote
Old 11-26-2015, 11:16 PM   #10
Po_31
Po_31's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
Do you still have the short shifter
Old 11-27-2015, 01:57 AM   #11
R2RO
Sorry Im not, Im keeping it for what I have in store for the build.
Old 11-27-2015, 02:03 AM   #12
R2RO
Pm me if you want any and all parts SR related, thanks guys!
Old 11-28-2015, 09:14 AM   #13
soCALsx
I pmd you with my number about the gauges
Old 11-28-2015, 07:17 PM   #14
R2RO
Bump, Parts sold today!
-APEXI Power FC L-Jetro
PM me for any parts requests above.
Old 11-28-2015, 07:44 PM   #15
aguo
aguo is an unknown quantity at this point
interested in the pbm skid plate... pm'd you but no reply
aguo is offline   Reply With Quote
Old 11-29-2015, 09:45 AM   #16
soCALsx
Ah man �� I wanted both the gauges
Old 11-30-2015, 12:53 PM   #17
R2RO
Bump, Parts Sold today!
-9k Racing 150mm Shift Knob
Please message me if you want any parts still for sale, PMs get priority
Old 12-01-2015, 09:17 PM   #18
R2RO
Bump added photos of the B&M Shifter.
Also I cannot ship out the PBM Skid Plate & Cobra Flex Downpipe, since I don't have boxes big enough to fit them in. Sorry for the inconvenience! Those Items are reserved for Pick up in Southern California only at the moment.
Old 12-02-2015, 01:16 AM   #19
Lpn26
Lpn26 is an unknown quantity at this point
How much for the short shifter picked up
Lpn26 is offline   Reply With Quote
Old 12-06-2015, 11:13 PM   #20
R2RO
Bump, all parts listed above are still available unless otherwise stated as sold.
Parts only available for pick up in Southern California:
-PBM Skid Plate(Gold) $80 Picked up
-PBM Cobra Flex Downpipe $260 Picked up
Available in Northridge, CA or Palmdale, CA.
Old 12-06-2015, 11:37 PM   #21
TheRealSy90
TheRealSy90's Avatar
I need the rubber injector insulators and metal washers that are underneath the injector caps.
Such a good signature.
Old 12-09-2015, 11:46 AM   #22
R2RO
Decided to sell the PBM HMIC complete set
$330 shipped
Less then 10 miles on it, perfect running order
Its specifically spec'd for S13 SR20DET's With T28 Turbo and Stock intake manifold(I have an optional pipe for those running the Greddy/Freddy Intake manifolds).
Comes with:
-PBM HMIC Core
-PBM Cold Pipe for OEM S13 SR20DET & KA intake Manifolds(Wrapped with Mishimoto Gold heat tape)(I have Greddy Style Cold pipe too)
-PBM Hot Pipe for T28 Turbo(Wrapped with Mishimoto Gold heat tape)
Awesome setup but I rather part with the whole system, since I wont be using the pipes for my new build.
Picture of it is the first on the thread, More coming soon.
Old 12-09-2015, 12:29 PM   #23
DopeSpike
DopeSpike is an unknown quantity at this point
Not willing to ship the PBM Cobra Downpipe?
I saw you put pick up only.
DopeSpike is online now   Reply With Quote
Old 12-09-2015, 12:34 PM   #24
R2RO
Currently don't have a box big enough to ship it in, because of its a weird shape.
Old 12-15-2015, 01:49 AM   #25
R2RO
Decided to just part out the whole car, All parts up for grabs! PM Quick! Photos of the parts will be available later this week! Still have Finals till thursday.
Old 12-15-2015, 01:57 PM   #26
Avyar
Avyar is an unknown quantity at this point
Selling radio/shifter bezel?
Avyar is offline   Reply With Quote
Old 12-16-2015, 04:35 PM   #27
R2RO
Parts sold yesterday:
-B&M Short Shifter
-S13 Radio Bezel
Will upload more photos of the parts, when I have time to take them off later this week.
Old 12-17-2015, 09:30 PM   #28
R2RO
Random bump for the parts
Old 12-18-2015, 11:10 AM   #29
sleeper108
sleeper108 is an unknown quantity at this point
Can you cut a package deal for the rear PBM suspension links and the inner and outer tie rods shipped to 87107 (business address)
What gen are the super angle knuckles?
sleeper108 is offline   Reply With Quote
Old 12-20-2015, 01:07 AM   #30
R2RO
Bump hmic sold
california, drift car, drifting, s13, sr20det 240sx s13
Copyright ©2000 - 2021, vBulletin Solutions Inc.
