![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
S13 240SX partout electrical brakes hubs suspension arms lower tension rods
Accept Bitcoin, cash, and paypal
. $25 pair Front brake rotors. do you need shipping? It's 35lbs and 1 square foot box from SF. Calculate it yourself please. It also fits inside FedEx XL flat rate $20 S13 hatch 240sx left and right tail lights and center. Good condition. One side is missing the bulb socket cover. (+$30 for shipping) ![]() ![]() ![]() $15 8 brand new and 1 used. (two are missing packaging but still brand new) $6 shipping. Rear: $20 hub. with extended studs. 4 lug. $20 pair of rotors. one track day $110 S13 Kazama Inner tie rods. Used for 2 track days. Boots included $20 Used inner tie rods. Can't remember what millage these have, but do appear to be good condition, no play. ![]() $80 2x Bolt on spacers. Comes with nuts $120 for 4 spacers. Comes with nuts 15mm 12x1.25mm 5x114 hub centric for Nissan Infiniti but adapter can be removed to fit any car if you don't want it hub centered. These have 50 miles on them. http://www.amazon.com/Nissan-ICHIBA-...ds=ichiba+15mm Tools for sale http://zilvia.net/f/showthread.php?t=478050 ![]() $25 Stainless Steel brake lines with clear protector for rear, have two track days. DOT certified. Made in Canada. I think this is sold? If you bought it please let me know. $20 Wilwood hydraulic cylinder for use with inline brakes to lock rear wheels. Like new, was only test fitted. SOLD$600 turbo GT2860RS $20 compressor outlet adapter for 2inch pipe has plug to tap wastegate into. ![]() ![]() $10 Pilot bushing or free with any other purchase ![]() $10 Brand new 40in Battery cable. Good for starter wire. etc ![]() $8 battery cut off switch Brand new $8 battery cable firewall mount through. $35 6 switches lighted with covers. Brand new. 5 are on/off and 1 is hold for on, it rocks back to off by itself. Great for starter. 20 amps Made in USA starter switch $10 Battery cable 45 inch $40 Battery cable 170 inch $4ea battery cable covers or all 4 for $8 Last edited by Hashiriya415; 02-09-2021 at 10:39 AM.. |
Trader Rating: (22)
$20 (Pair, both left and right) Great condition tail lights for S14 Zenki. Comes with bulb socket holders.
$24 to ship ![]() ![]() $10 Battery junction terminal. Near new condtion (Use this to connect cable through firewall) ![]() Picture from 2014 ![]() Picture from 2014 ![]() Picture from 2014 ![]() SOLD$55 rear traction arms MR SOLD$25 5 speed cross member SOLD$50 sr20det ecu. E6 SOLD$200 wildwood hydro rear brake kit : bolt on. SOLD$60 solid engine mounts. (+10 ship) SOLD$60 NISMO transmission mount SOLD$30 Clutch pedal SOLD$220 Engine bay wiring, with switches and kill switch. SOLD$140 Dashboard (slightly modified, cut at bottom of radio for easier removal and installation) SOLD$120 SR20DET wiring harness. SOLD$110 Starter. SOLD$100 Gas tank SOLD$60 Walboro fuel gas pump SOLD$240 Koyo 3 row radiator & Flex lite fans with shroud. SOLD$40 ignition coils SOLD$460 SR20DET longblock. With intake mani, throttle body, alternator, PS pump, CAS, and TRUST downpipe SOLD$80 Z32 MAF, pigtail about 6 inches. SOLD$10 Transmission MPH speed sensor. SOLD$240 5 speed tranny, shifts perfect in every gear. SOLD$50 NISMO tranny mounts. SOLD$30 NISMO tranny pivot for fork. (3 track days) SOLD$100 Shell only nothing attached SOLD$120 ~ Doors, hatch, ~ Hood ~ Quarter panel glass and windshield ~ Back bumper SOLDBumper $100 SOLD$150 NISMO power front brace. Tension rod brackets. SOLD$360 Front crossmember, knuckles, and F&R Sway bars. SOLD$15 NISMO Cap and Greddy Shift knob SOLD$900 NISMO 2 way LSD SOLD$100 Fenders SOLD$540 Enthalpy, 640 cc Deutschworks. NISMO regulator. Rail SOLD$200 Rear sub-frame. solid bushing SOLD$40 Passenger rear knuckle. SOLD$60 ARP flywheel bolts. SOLD$260 Flywheel and Brand new SS line SOLD$80 89K Gauge cluster SOLD$150 Origin rear bumper SOLD$20 SR fan shroud SOLD$180 FLCA SOLD$40 axles, RLCA SOLD$50 front hubs SOLD$175 COR Front tension rods SOLD$50 all 29 T-Clamps SOLD $20 for all 6 led bulbs. SOLD$90 Apexi AVCR AVC-R Electronic Boost Controller actuator valve type-r SOLD$160 B&M shifter kit. Best shifter! for Works for SR and KA SOLD$200 Re-manufactured rack&peanut SOLD$20 turn signals and wiper switch. SOLD$80 ~6-puck 450 ft lbs rated clutch kit by "SPEC". Kevlar friction material and high torque sprung hub. SOLD$35 Interior harness SOLD$58 .09BTC SS PS hose. 6/23/16 SOLD$600 Tein Type flex SOLD$20 x2 Pair of coilover Tein spanner wrench SOLD$60 brake calipers. Hawk pads. SOLD$80 KTS rear upper control arms. 7330 SOLD$600 turbo GT2860RS SOLD$35 BN oil cooler SOLD$24 Water & Oil lines for turbo. SOLD$50 intercooler piping & couplers & clamps SOLD$36 Custom made Headlights SOLD$150 Rear BNIB KTS Toe arms. SOLD$100 Sportline lower control arms SOLD$55 Wastegate actuator bnib SOLD$140 KTS Front T Rods SOLD$60 sportline RLCA SOLD$60 MR rear toe arms Last edited by Hashiriya415; 02-09-2021 at 10:40 AM.. |
#14 | |
Trader Rating: (22)
If you want me to properly package them so they don't get damaged in case somewhere it gets mishandled during shipping. $80 would be the cost to package and ship both panels properly.. Plus panels cost. Both look the same, I took pic of only one, but they are identical condition. |
#19 |
![]() Join Date: Oct 2004
Hey Hashi, you still around!! I haven't seen you in forever... You still going to THill? Still in the City! Good seeing around!
#25 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
is it jsut me or are those tension rods broken in half? lol
Will you ship Tein Flex and wastegate to NoVA?
HouseBuyers365.com Quote:
#26 |
Trader Rating: (22)
Engine harness is sold.
I have many different tension rods. Brand new KTS $180. COR have one track event $200. Broken ones and couple of cheap low end ones (cheap china) Shipping will be $35 for coil-overs and extra parts. |
