03-29-2015, 06:28 PM | #1 |
Trader Rating: (43)
Feedback Score: 43 reviews
Storage Unit Clearout - Round Two!
So I have way too much crap sitting around and would like some space back, best way to get ahold of me is via PM, if you have any questions feel free to ask.
Prices - Pricing does not include shipping, if you're going to make me a shipped offer please keep this in mind. Some items have wiggle room while others do not, if you try and lowball me don't expect a response, simple as that. I accept payment via paypal, chase quickpay and cash for locals. Shipping - I tend to ship smaller items via USPS Priority due to the cost, integration with paypal and location as I can drop the packages off on my way to/from work. Larger items will be shipped via FedEx ground, I do not ship via UPS. Due to my work schedule and the fact that I have to pick up these items from my storage unit it may take me up to a week to ship items, please be aware of this. Local Pickup - Local pickup is preferred, I'm out in Chicago IL, I encourage locals to PM me if you're looking to meet up. Engine Braille B14115 Small Battery - 200.00 Battery is in great shape with very little low use time on it. Comes with the battery and an aluminum hold down. Mazworx Oil Block - 40.00 Brand new, does not come with fittings or hardware. HKS SR20 IN264/EX272 S14/S15 VCT Camshafts - 140.00 No longer need these, they are in good shape but a couple of lobes have some ware on them, they were running fine on my motor before I pulled it apart. Below are pictures of the ware. More pictures - http://zilvia.net/f/showthread.php?t=583989 SR20 FMIC Kit - 300.00 This was used on a S13 with a S14 SR20 motorset, comes with a CX racing core and modified piping. Comes with HKS SSQV listed below. Local pickup only item. SR20DET Downpipes - 50.00 Each Mixed bag of things, I think one is SPL, other is a megan and not sure about the third. One includes a cat delete. Shown test pipe is not for sale or included with downpipe. HKS Step2 Springs/Retainers - 200.00 Used but in great shape, ended up parting this motor. Exedy Hyper Single - 200.00 I loved this clutch and the way it drove, moving onto a twin. Clutch did not slip and can be used as is but it will need a new friction disk in the future as it's nearing the replacement thickness. XTD 6 Puck - 125.00 Clutch is in good shape with a ton of life left, 6 puck is nice and grippy! Stock flywheel in pictures is not included. Apexi NIOR Exhaust - 250.00 Super low key muffler, great sound, bottom is a little beat up but over all in good shape. Peak transmission mount - 75.00 Stock SR flywheel - 60.00 Stock S13 SR20DET flywheel, no hot spots. Cusco Engine Mounts - 100.00 Rubber is in great shape but the mounts do have some surface rust, price reflects the condition. Stock PS Reservoir- 25.00 In pretty good shape, pulled from my S13 coupe. S13 SR20DET Oil Catchcan - 15.00 OEM piece that mounts above the exhaust manifold. Oil Catchcan - 130.00 Custom piece that mounts behind the headlights, huge capacity, it no longer fits with my PBM highmount. RB25 Crank pulley - 60.00 OEM crank pulley in great shape, rubber is not cracked, purchased to replace a chipped pulley. Forge Intercooler - 180.00 Brand new Forge intercooler, fins are pretty much perfect! OEM nissan gasket kit for S13 SR20DET motors - 150.00 I no longer have a SR so this has to go. Opened for pictures but that's about it, all bags are still sealed and the kit is 100% complete. Electronics S13 Redtop Harness - 115.00 Complete and in ok shape, needs to have the ECU plug gone over, car had a SAFC tapped into the harness. Was running when pulled. S13 Redtop Harness #2 - 100.00 OEM harness, needs a O2 sensor plug and a MAF plug to be complete, pulled from a running motor. S14 Zenki to S13 Harness - 115.00 Was purchased new from nissan and was converted to be used in a S13 chassis along with a D-Jetro PFC, there is no MAF plug with this harness. Zeitronix ZX-2 Wideband - 250.00 Comes with everything needed for install along with the optional 50psi MAP sensor to view boost pressure. Worked great and keeps less gauge clutter in your interior. Old school HKS boost gauge - 80.00 Looks to be bigger than a 60mm gauge, units are in bar. Old school mechanical gauge. GReddy Profec B Spec II - 200.00 Complete and in good shape. Comes with controller, power harness, solenoid harness and solenoid. VDO Boost Gauge - 35.00 Mechanical boost gauge by VDO, black/white 52mm model. VDO Volt Gauge - 30.00 Black/white 52mm gauge. HUD Projector - 25.00 Each OEM HUD Projector, in working condition. I have two of these. Lamco Boost Gauge 70.00 OEM 04 STi boost gauge, bolts to your steering column. HellaHorns - 40.00 Powdercoated blue. Working shape, no relay. Interior Momo 280mm Wheel - 130.00 Genuine Momo wheel, comes with steering wheel and horn button, leather is in great shape! Z32 Shift Knob - 30.00 OEM weighted Z32 knob in good shape. OEM JDM Arm Rest - 125.00 OEM unit that is a bit higher and has the double cup holder above the arm rest. Suspension Project Silvia RUCAs - 125.00 Used but still have some life left in them, price reflects the condition of the parts. Unknown Tension Rods S13 - 125.00 They are in good shape and not sized, they look like first gen PBM. Cusco Tension Rods S13 - 175.00 Used but in great shape. SPL Eccentric Lockout Kit - 35.00 Brand new in box, for S13 HICAS model. Whiteline HICAS Bar - 115.00 Brand new, still in packaging. S13 5 Lug Swap - 240.00 One of the fronts needs a new bearing but all of the other bearings are in great shape. Conversion hubs up front and R32 GTS-T hubs for the rear. Z32 Rear E-Brake assembly - 150.00 Comes complete minus lines, shoes are in good shape with a ton of life left. Z32 Rear rotors - 50.00 No idea on brand, drilled and slotted and have a ton of life left. R32 GTS-T Rear Hubs - 125.00 Low miles and in good shape. JIC-Magic JIC FLT-A2 - 800.00 On the fence about selling these, PM me if seriously interested. HPS Z32 Pads - 125.00 Used for about 15 miles before switching to a more aggressive pad, both front and rears in pretty much new shape. Work RS Lug Nuts - 165.00 Brand new in box, never used, red in color. S13 OEM Driveshaft - 65.00 I have two of these, both came off non abs models. Body DorkiDorki silvia aero valances - 150.00 Brand new in box, great fitment. Silvia OEM Rain Guards - 250.00 Guards are in great shape, no cracks or discoloration, comes with OEM clips, will need new double sided tape. Ebay S13 FSB - 30.00 Ebay S13 RSB - 30.00 OEM SR20DET Parts OEM S13 SR20DET Parts - OEM intake manifold bare - 25.00 - IACV - 60.00 - Throttle body - 25.00 - Altenator - 80.00 - Coilpacks - 110.00 - OEM radiator hoses - 45.00 - OEM Fuel rail with FPR - 30.00 OEM S14 SR20DET Parts - OEM upper oil pan - 30.00 - SR20 Rockerarms - 80.00/set or 20.00/each - S14 Front cover/oil pump - 65.00 - 5 Speed transmission plate - 25.00 - Water pump - 25.00 - Intake manifold upper/lower - 75.00 - Throttle body - 45.00 - OEM exhaust manifold - 45.00 - S14 IACV - 80.00each - Knock sensor - 25.00 - Oil pickup - 35.00 - Oil filter housing - 25.00 - Coilpacks - 110.00 - Water outlet - 45.00 - Exhaust cam gear - 30.00 - VCT Solenoid - 75.00 OEM Chassis/Interior S13 Parts - Everything listed is from a S13 SE coupe, please keep this in mind. Crackless Non-HUD dash - 150.00 Fantastic shape for a S13 dash, no cracks or other damage. Cracked HUD dash - 125.00 Single crack right above the cluster hood, other than that the dash is in good shape. 'Tweed' door panels - 40.00 A slight tear on the drivers side and also missing the lower pocket. Vinyl door panels - 100.00 Door panels are in great shape, these are the OEM vinyl ones that have a smooth surface rather than the tweed inserts. Door sills - 25.00 In good shape, have them for both sides with hardware. Door finishing seals - 25.00 These slide onto the pinch welds in the door jam, also in good shape. Coupe rear seat finishing panels - 40.00 Good shape, no scratches or broken clips. Coupe rear deck lid - 20.00 Good shape, came off a SE model so no third brake light. 89-90 Carpet - 100.00 Carpet is in great shape, this is the darker gray carpet with large loops rather than the 91+ fuzzy carpet. No holes or even ware marks. Center console - 40.00 Have two of these, hinges are in good shape and come with ash trays. 5 Speed shifter surround - 20.00 Have two of these, faux leather is in good shape as well as the tabs. Coupe rear windows - 80.00 Have both sides, OEM nissan glass in good shape. Coupe sunroof glass - 80.00 In good shape, I do not have any other sunroof parts, just the glass. 92 SE chassis harness - 100.00 Complete from the SMJ back into the car, previous owner had an alarm installed and the plate light pigtails have been cut off. Other than that the harness is in great shape. Door gaskets - Offer I believe these are in good shape, may have tares near the mirrors as most do. Door/window gaskets upper - offer Complete with gaskets and metal retainers. Wingless coupe trunk - 75.00 In good shape, shaved spoiler holes and painted white. OEM rear bumper - Offer Have the bumper and rear foam, also white. OEM power mirrors - 50.00 In good shape, glass and power options all work. OEM tails - 60.00 Both sides with lenses and bulbs. Non-AC heater box/core - Offer Factory non AC heater core and box, good shape, all flaps and heater core did not leak. Last edited by hobbs; 04-22-2015 at 09:47 AM.. |
03-29-2015, 08:20 PM | #2 |
Hey, what do you mean by "Non-AC heater core". I'm looking for an S14 heater core with the 2 plastic connectors shown in the pic below. I really just need the connectors since one of mine broke.
4 SALE intercooler mafs valvecover rep fn01rc http://tinyurl.com/jmaxzilvia |
03-30-2015, 06:54 AM | #4 | |
Trader Rating: (43)
Pictures are posted above, it's the downpipe on the left/top. Price reflects the condition. |
03-30-2015, 07:46 AM | #5 |
Hobbs, I cannot find in on Mazworx website, but do you know what size fittings are used with the oil block?? I am assuming -10 AN (o-ring boss) fittings??
Also, is there an extra sensor (1/8npt) port I am on seeing on the side of it?? |
03-30-2015, 08:01 AM | #7 | |
Trader Rating: (43)
Nothing, replaces all of the brake lines in the engine bay and will bolt up to a stock or Z32 BMC and the stock lines or conversion lines on the caliper sides. |
03-30-2015, 08:05 AM | #8 |
Trader Rating: (68)
Feedback Score: 68 reviews
I will take the Mazworx oil block.
Please paypal invoice me at [email protected] Please put Mogli's Oil block adapter as the message so my shipping department understands what its for. I will give them the heads up that I will be using the shop's paypal. Thanks! PS - also interested in the custom catch can. Please pm me some photos and dimensions. Just want to make sure it will fit my setup.
Straight Outta The Slums of Shaolin |
03-30-2015, 08:20 AM | #9 | |
Trader Rating: (43)
04-01-2015, 04:28 PM | #14 |
Trader Rating: (48)
Feedback Score: 48 reviews
Interested in the 89-90 carpet, are you willing to ship it? Should be able to roll it up nice & small and put it on a Greyhound.
04-02-2015, 08:38 AM | #17 |
Trader Rating: (43)
PM'd.
Again, prices do not include shipping. Not quite sure why people are PMing me offering 30% less than my asking price and then looking for free shipping.... |
04-08-2015, 08:32 AM | #19 | |
PMed you about the consoles
I never knew you could do that with an eggplant |
04-08-2015, 10:35 PM | #21 | |
Trader Rating: (43)
Battery is sticking with the mount but I am willing to ship the battery.
04-09-2015, 06:58 AM | #23 |
Hobbs, you have been here long enough to know all the assholes and idiots of the 240 community shop here. This should be of no surprise
