![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
S13 SOHC stock parts
2 S13 SOHC distributors
These are good working condition S13 SOHC distributors. Both came out of running cars with no issues. $30ea ![]() ![]() S13 SOHC alternator This is a good working condition alternator for S13 SOHC. It operated perfectly upon removal, no charging light. SOLD! KA24E fuel injectors These are 7 KA24E (sohc) fuel injectors. All 7 test good electrically and came off good running engines. $20ea ![]() SOHC power steering tensioner This is a good condition SOHC power steering belt tensioner. The pulley is undamaged, the bearing is nice and smooth, and the adjuster works perfectly. $15 ![]() SOHC water pump pulley This is a good condition SOHC water pump pulley, no damage. $10 ![]() SOHC fan/clutch This is a SOHC complete clutch fan. The fan blades have very minimal cracking and the clutch is still good. It's just a little dirty. $25 ![]() SOHC exhaust mani w/heatshield This is a good condition SOHC exhaust mani with the heat shield. No cracks or damage of any kind and the mani does not have any bolts broken off in it or broken studs. $25 ![]() SOHC distributor cover This is the cover that goes over the distributor on a SOHC KA. You hardly ever see these still on the cars and it adds a bit of a cleaner look to the plug wires. $10 ![]() SOHC crank pulley Good condition, no damage, not rusty. $20 ![]() SOHC ignition coil This is a SOHC ignition coil with the bracket and WITHOUT the igniter. Came off a running/driving car, no issues. $10 ![]() SOHC MAF sensor This is a good, working SOHC MAF sensor with a 3 pin connector. Came off a 100% running/driving car, 100% FOR SURE good. I will clean the MAF element before pick-up/shipping with MAF sensor cleaner. $25 ![]() 2 SOHC M/T ECU's This is an ecu for SOHC, M/T, CA emissions. I have 2 of these. 100% for sure good, came off running cars. $25 One SOLD, One Left ![]() SOHC plug wire set This is a used, but recently replaced, complete set of SOHC plug wires. The wires are good quality, no loose boots, no pulled out connectors. $10 ![]() SOHC intake air temp sensor This is a good working condition SOHC air temp sensor. It mounts in the airbox on SOHC cars. $10 ![]() SOHC complete intake mani/sensors This is a complete intake mani assembly with all the sensors. I am parting this out so PM me with what you need and we can work out a price. $offer$ ![]() Last edited by racepar1; 05-02-2015 at 10:16 PM.. |
#5 |
Are you selling the throttle body?
- Lexi 1989 Nissan 240sx Fastback. Under construction. Future Sil80. Last edited by EveryQuarterMile; 05-03-2015 at 06:56 PM.. |
#7 |
How much would you want for the throttle body, shipped to 78641?
- Lexi 1989 Nissan 240sx Fastback. Under construction. Future Sil80. |
#9 | |
I should have the knuckle bolts around somewhere. I for sure have whatever sohc power steering bolts you're looking for on the other engine as well. You've just gotta specify a little more clearly which power steering bolts you're looking for. |
