Banned from the Marketplace
SAI way off... Alignment question
Alright so I have a s13 240sx and my SAI and included angle is way off. I'm not exactly sure what I should look into to fix this or if it is even worth my time to fix. Here are my specs. I know my car was in a small collision previously but it was only the radiator support being a little bent on the left side so I do not think it affects this. Any input would be great.
Front Left Camber -3.1 (spec is 0- 1.5) Caster 6.9 (Spec is 6.0-7.5) Toe 0.10 (Spec is .02-.11) SAI 16.6(Spec is 12.5- 14.0) Included Angle 13.6 (spec is 11.0 to 14.0) Front Right Camber -3.1 (spec is 0- 1.5) Caster 7.1 (Spec is 6.0-7.5) Toe 0.10 (Spec is .02-.11) SAI 22.1 (Spec is 12.5 - 14.0) Included Angle 19.0 (spec is 11-14.0) |
![]() Join Date: Apr 2006
google is your friend, bud
http://www.aligncraft.com/terms/term...%20Inclination |
#3 | |
![]() Join Date: Apr 2004
If you have slotted coilover brackets, make sure they're pulled to the same location (I shim mine so I pull out as hard as I can so I get a consistent attachment there). This could be why yours is off.
I'd also zero out that toe. Over 3 deg camber plus that much toe is going to chew through your tires in no time.
#6 |
#7 |
![]() Join Date: Nov 2004
Changing your wheels offsets and widths has an effect on your scrub radius and SAI.
You're moving the steering centerline around. Though I might be confusing the two.
#8 |
Well the thing is the offset of the wheels is the same on both sides, but the sai has over a 8 degree difference
#10 |
#12 |
#13 |
![]() Join Date: Aug 2011
meaning the car is seriously bent (SAI is around 15° ). It can be from a bent knuckle, upper chassis mount, or really crappy coilovers with poorly slotted mounts. My money would be on the knuckle though.
#14 |
Good input I'm going to be changing the spindle on that side along with both of the lower control arms. Doubt the stance coils are causing anything. Do you think I will be able to see a bend on the spindle?
#15 |
Your best bet is to measure from hole to hole on a known good knucke, then check yours. i don't think you can see that by eye unless you have already seen that kind of damage, it could be just a millimeter here and there.
alignment, sai |
