11-03-2014, 07:00 AM | #1 |
S14 KA24de problems after compression test
So my S14 KA24de was running and performing great up until I did a compression test.
I unplugged each fuel injector, unplugged each spark plug wire from all the plugs, removed 1 spark plug, inserted a compression gauge into the removed spark plug and cranked the engine over. I repeated this 4 times for each cylinder. After I was done I reinstalled all the spark plugs, wires, and plugged in all the injectors. Car is now running like crap, it sputters up to redline randomly at any rpm. Noticeable worse at lower rpms when coming from a stop. Heres a video of the problem while idling. http://youtu.be/uTocwInbQmI Ive tried swapping in a known good MAF, no change Checked all grounds, no change Im thinking because I left the ignition on while testing I might have shorted something? not sure... This problem happened right after the test so im thinking it has to be directly related |
11-03-2014, 07:07 AM | #2 |
if all you did was remove the spark plug wires, and injector wiring, did you not push the spark plug boots down far enough?
there isnt much that can go wrong by removing those items. sure you didnt do anything else?
11-03-2014, 07:11 AM | #3 | |
Could the plugs be bad? |
11-03-2014, 09:47 AM | #4 |
Just fyi, you should remove ALL spark plugs while doing a compression test. Makes it much easier on the starter.
NismotronicSA - Speed-Density Tuning for Nissans |
11-03-2014, 10:20 AM | #6 |
take all of the wires back off.
make sure they're all plugged into the correct plug. check your cap too. it may have the corresponding numbers on it depending on your application. also ensure the plugs are tightened properly. if it sounds like a miss (which it does to me), unplug each individual plug wire and check for rpm drop. (if the idle drops, then that cylinder is most likely not the issue). a miss on a four-cylinder is typically pretty dramatic.
93 coupe - AutoX/Fun summer daily/Eternal project |
11-03-2014, 10:25 AM | #7 | |
thanks! |
11-04-2014, 04:27 AM | #8 | |
11-05-2014, 11:25 AM | #9 |
So I did as cerealwars recommended
All the wires are plugged into the correct places, all the plugs are torqued properly, and I unplugged each wire individually and the idle dropped accordingly. This is blowing my mind...ugh |
11-05-2014, 12:02 PM | #10 |
do another compression test
When you tight the plugs, how tight do you go? And what is the gap, how do you "drop" the plugs back into their respective locations? Maybe you accidently re-gapped one of the plugs by dropping it. Maybe one of them is not tight. Beware overtightening them, I have seen the head stripped before. They don't need to be too tight. Always put a little anti seize on the threads too. |
11-05-2014, 03:41 PM | #12 |
Maybe when you pulled the injectors you might have broken the wires and the injectors are getting an intermittent signal.
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
11-06-2014, 07:01 AM | #14 |
Gave the injector harness a good visual inspection, it looks fine, just how it did before.
The injector plug on cylinder 2 looks slightly slightly melted, still tested good and got 12v though. I did however find the ground on the top driver side of the block (there are 2 there, the closest one to to firewall) to be very loose. Heres what I think happened, not sure how to fix it though I unplugged the injectors and the ground was loose when I was cranking the engine doing the compression test. Could this have shorted something out? any insight would be helpful. |
