04-12-2014, 12:05 AM | #1 |
S13 SR20 partout. If not listed ask.
BUMP!!!!! LOWERED PRICES
I'm buying anew engine and I'm going broke, so I need to make money so I don't have to live off ramen noodles LOL Contact me at 562 382 7868 (text) or pm me. Not to desperate to sell but willing to work out a deal if you send me links to similarly priced items. Saying that your buddy's buddy's uncle', neighbor's, cat's, nephew sold the same parts at X amount is just talk. If you want to send me a link to at thread/something that is recent and I will work with you on price. Pick up is available at my local target at 8800 Whittier BLVD Pico Rivera, CA 90660. OR in Pomona at 2100 Murchison Ave, Pomona, CA 91768 Shipping is available at your (buyers expense) but don't offer me something lower than the asking price and expect shipping. The engine threw a rod so the bottom end is pretty much done. However a friend of mine has a stock shortblock so I can make a motor set. -COMPLETE SR HEAD $250 There was no damage to this and the head was perfect. Engine had 150 compression across the board so there's no leaking on the valves. Everything was fine. Camshaft oil tubes were replaced with OEM parts along with the valve cover seal. The valves on cylinder 1 touched the piston when the rod went to the block but here is no damage to the valves them self, they just have the very small markings/debris on them. Includes OEM chain tensioner. **No intake or exhaust manifold nor cas. FOLLOWING PARTS WERE TAKEN OFF THE ENGINE, S13 SR20 BLACKTOP, AFTER THE FAILURE. ALL WERE WORKING GREAT. Valve cover Wrinkle black paint $50 Knock sensor with harness $50 Cas $65 Starter $70 IVAC $75 Exhaust manifold $40 fuel rail w/fpr $20 Water pump $30 SMIC with piping & BOV. Missing a hose for the BOV. $75 Engine harness $150 Coilpack harness $30 Coilpacks (4) $100 Stock oil catch can $15 Power steering pump $40 Random intake brakets - $10 Flywheel bolts $10 Lines beneath the intake manifold -$20 SOLD LIST: Injectors T25 Alternator intake tube upper oil pan O2 sensor ECU Elbow Radiator Fan/fan shroud Intake Manifold Anything else just ask. Some Items were pictured and I'm sure I'm missing some. if interested in them and a pictures isn't up/want more pictures let me know. Last edited by dluevanos01; 05-17-2014 at 04:22 PM.. |
04-17-2014, 12:41 AM | #20 | |
PM'd
I think I had texted you before (thin I remember the screenname) but never got a reply. PM'd though Quote:
Injectors were routed under between the intake manifold, and cas and maf plugs were routed through the front under the stock SMIC cold side pipe. Yes, You're local too. I'mm be back in town friday night. Let me know |
05-10-2014, 12:40 AM | #28 |
i need the power steering pump i would also need the power steering pump brackets if available and do you have coolant neck that goes from the head to the upper radiator hose?
