#1 | |
GM2 (SW/AW)
Not so mega s13 HB part out *PIC HEAVY
S13 Hatch partout[/B]
I have a 1993 s13 black hatch back I'm trying to get stripped down to donate the chassis to a friend. He basically said to get rid of everything on the car before he wants the chassis so I want to make sure everyone gets a chance at the parts on the car before It goes to him and he trashes everything he doesn't want! Basically has about everything left on it. few things are removed and gone; Door panels Driver seat Clutch pedal Brake master cylinder Climate control Dome light Glove box To add some body to this I'll try to list everything thats left. Prices are best offers ( I don't have set prices for anything so offer up, lowballs welcome ) **SHIPPING AVAILABLE** Starting at the rear; Stock tail light Rear Left Tail light SOLD tail light sockets tail light trim (under lights) Bumper cover Bumper support Bumper energy absorber (foam insert) Toe rods Traction rods Lower control arms RUCA's REAR R+L Spindles W/ hubs+dust shield attached REAR R+L Brake dust shield REAR R+L Calipers W/mounting bracketd REAR R+L Brake lines REAR R+L Marker Lights FRONT R+L CalipersSOLD FRONT R+L Brake linesSOLD ka24de Motor SOLD Ka24de Manual NON-ABS driveshaftSOLD Ka24de 6 bolt axles PASS. SOLD Ka24de STOCK open 6 bolt diff.SOLD Ka24de Lower manifold with all attachments excluding throttle body. Accessories fuse block with wires Brake BoosterSOLD Clutch master cylinder SOLD Clust Slave Cylinder SOLD Power steering pump SOLD Power steering reservoir SOLD Transmission cross member SOLD Transmission mount SOLD S13 speed sensorSOLD s13 chuki bumper vents s13 B piller outer covers R+L Z32 MaF pigtail Pass Headlight motor SOLD Wiper amp switch SOLD R+L window crank handles Assorted interior plastic paneling LEFT+RIGHT Head Light Assy (No bulbs) Rear R+L seat belts x2 (1) SOLD Stock 1 Piece Passenger seat Good condition no rips/tears Brake pedal Gas pedalSOLD *Stock Older style carpet Grey **Black newer style carpet Gauge Cluster SOLD Gauge Cluster surround trim LEFT+RIGHT Side Mirrors (No glass) Driver Side hood hinge x2 Pass side headlight cover Assorted rear end bolts (toe rod/tension rod/ruca) Rear subframe hardware (Nuts for all 4 posts, bottom plates/front side plates) Full set of megan tracks (2 struts are bent) Not sure if they're rebuild-able Various air filters Spectre air duct 36" extended Sunpro 3 gauge pod. Missing all bulbs & oil sensor. Brand new otherwise. Ecu kick panel in black AND brown options. Driver fuse panel with access door **Brand new Airtex stock fuel pump + strainer + gas tank seal **Brand new oxygen sensor **Brand new Knock sensor (Square plug) **Brand new knock sensor pigtail engine harness SOLD engine bay harness SOLD Body harness $95 + SHIPPING OBO 80k trans in good condition shirter needs grommetSOLD wiper motor Steering column & linkageSOLD radiator w/ single fan & hosesSOLD clutch slave cylinderSOLD Pignose bumper turn signal metal backings center console dash vents Turn Signal stalk wiper stalk ================================================== exedy pressure plate & clutch disc in awesome shape 3k miles ××make offer×× ================================================== Door bottom trim pieces ( bottom of door opening ) White plastic carpet hold down pieces Also have entire HVAC setup, blower/air mix servos, blend door actuators, ducting etc.. Also some bitchin' lame seat covers new. Few of the New NON 240sx stuff; NEW Metra Universal 1500watt amp wiring kit NEW Peak Performance 800 watt power inverter I literally have a ton of crap sitting in the house, I need to clean it out so I can condense down to only 3 cars instead of 4, Of course as always It's nearly impossible to think of every single thing I've got so I probably missed some stuff.. Like I said, MAKE AN OFFER. And ask if there's something you're looking for. You never know, I might have it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
KA-T for life! Current for sale advertisement ![]() Last edited by anti tyler; 05-01-2014 at 10:57 AM.. |
Looking for rear hatch plastic that goes over the bottom latch and a climate control shipped to 18326
They call me Dr. Frankenstein cuz I build monsters all night long.. |
#5 |
![]() Join Date: May 2013
Is the carpet straight up black? and is it in good condition?
Also what about the 5 speed transmission, did it work when the car was running? If no please list the problems it had. By the way if the transmission is in good condition I might just buy everything needed for a 5 speed swap. So let me know asap! |
#6 | |||
GM2 (SW/AW)
Yes, No lines for it though. $15 or $29 shipped priority to your door.
If you're pointing to the A piller, or whatever that is. Yes I do. I'd have to see how long it was before I gave you an exact price. Shoot me a PM with your info and that picture so I have a reminder when I get off work to check. Quote:
Climate control has been sold already Quote:
Carpet is straight up black as the night. Tranny worked in the car, Condition is unknown. When I originally bought the car, I never drove it except to put it on a trailer. Tranny felt like the grommet on the bottom of the shifter was gone, causing the loose shifter feel. It did go into gear and drive up the trailor fine.
KA-T for life! Current for sale advertisement ![]() |
#8 |
Yea the lower piece in the center. I think I see it laying in the hatch in the back of the 11th picture down.
#10 | |||
GM2 (SW/AW)
I do have a throttle cable but honestly it'd be easier to get a new one for the $40. If you do really need it though shoot me a PM we can work something out. Quote:
The black hatch pictured has not leaked any that I've noticed the 6 months of owning it. I can go out and take a closer look seeing as my DD hatch leaked & I just resealed it.
#12 |
Hard to tell in the first picture but it could be. How much would you want for it?
#13 | ||
GM2 (SW/AW)
You want the hatch shipped? Do you personally know of any company that would ship something of that size and weight for a decent price because I don't... I'll try to do some looking around though, but if you can find a good rate let me know through PM. Depending on shipping I'll take $8 for it. Because it's so light I couldn't imagine it costing more than $5-$9 to ship.
#17 | ||
GM2 (SW/AW)
PM sent but it wont let me reply to you anymore.
#19 | |
GM2 (SW/AW)
No sir, I'm pulling a motor at 1pm after work. If you're close you're more than welcome to grab the axles & diff
#20 | |
GM2 (SW/AW)
Bump couple things sold, new items listed in Magenta color, tons of available items
#22 | |
GM2 (SW/AW)
Which part the lap belt or the auto retracting shoulder belt?
#24 | |
GM2 (SW/AW)
If you're talking about the piece that keeps heat from entering the car I don't have that.
#25 | |
GM2 (SW/AW)
Bumping over the limit, someone needs some cheap stock replacement parts. come get them, I don't want to trash what little 240 parts are left on the market.
#28 | ||
GM2 (SW/AW)
Yeah full harness is available on the car. Diff is in good working order. Also have an axle available too
